Do you power wash your engine compartment?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scott.in.colorado, Feb 15, 2013.
  1. scott.in.colorado
    scott.in.colorado Junior Member
    My car, a late model 2008, has just been at the dealer for recall service. Now that its all done I'm thinking of power washing the engine area. There is a fair amount fine dirt laying around. Any reasons not to do this?
    Scott
  2. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Not a good idea, there is a post about using simple green and a garden hose.
  3. southernguy
    southernguy Junior Member
    55
    Simple green isn't a great idea as it isn't friendly to some metals
    fotomoto likes this.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I typed a long response to this question, only to have my computer freeze up and lose it. But I rambled on too long so it probably was a good thing.
    Basically, I live near one of those coin operated power wash car wash stations and I would recommend against it. I see people all the time stranded or fighting to get their vehicle started because they have pulled in, power washed their engine and then done some inadvertent damage.
    I recommend the most conservative approach possible. I personally use a small bucket, water, a few rags and a sponge. Then I carefully wipe down the surfaces. The only chemicals I use, are on rare occasions if an area is especially dirty? I have a spray bottle of diluted Dawn Dish washing liquid and water, even then, I rinse whatever surface I spray that on, as thoroughly as possible.
    So my recommendation is no, I wouldn't do it, and just be as conservative and non-intrusive as possible in cleaning your engine area. Maintenance is really the key. Once you get it clean, you can usually keep it clean by simply wiping down surfaces about once a month.
    Good Luck.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    No power washing. No washing at all. If anything use steam. Like a house water is the most harmful thing to a car.
    In fact you should be lubricating everything under. Buy CSP spay from HD and spray lube lightly all bolt heads and connectors. Keeps everything from getting rusted and keeps water out of connectors. Spray lube suspension. Spray Black Magic Protectant on the cv boots and all rubber trim. Spray lube all door hinges and door jam rubber boots. Its a metal machine and needs to be lubricated.
    My car is 6 years old and no rust or corrosion anywhere. Top or bottom.
  6. scott.in.colorado
    Thanks for the comments. I'll rethink this. Perhaps a brush and light spray / 409 type would be the best solution. I have done other conbustion engines in the past, making sure I don't power wash the spark plugs / electrical connections and never had a problem, but not looking to induce issues, just clear the car a bit..
  7. PriusCamper
    PriusCamper Senior Member
    10,897
    4,418
    Pacific Northwest, USA
    a simple all purpose cleaner on a clean towel is the way to go... Also after washing outside of car there is usually a bit of water in the engine compartment and wiping it dry is another good way to keep the engine compartment clean.
  8. Fore
    Fore Don't look back!
    494
    107
    ^^^ I agree with the last post ^^^ Once you have it clean just ripe off every time you wash your car. It only takes me 5 to 10 minutes tops to keep it show room shine.
    PriusCamper likes this.
  9. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    If it ain't broke, don't fix it.
    Don't spray anything on the engine if it isn't lubricant.
    If you want to use a cleaner, Simple Green Aircraft formula. Or kerosene.
  10. PriusCamper
    10,897
    4,418
    Kerosene? That's crazy talk... Take care of your lungs and don't risk setting your engine bay on fire by only using non-toxic all purpose cleaner sprayed on a towel not sprayed directly on the engine? I use Clorox "Green Works" It's soap made out of coconut and smells like lemon-lime and works great on interior fabric stains too! Unlike most all purpose cleaners if you accidentally breathe it in it won't make you sick.
  11. wjtracy
    wjtracy Senior Member
    11,312
    3,588
    Northern VA (NoVA)
    ...one recent post another guy washed the engine and got water condensation into his headlight. He was able to get the condensation out by taking the bulb out overnite
  12. maestro8
    471
    109
    nor cal
    It's what my grandpa used, for everything from aftershave to weed killer to parts cleaner.
    In a pinch, I have no qualms using it. But as I said before, spray NOTHING in your engine compartment, not even compressed air. Only wipe / brush on, and wipe / brush off.
  13. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Your Grandpa used kerosene 'cause that's all they had back then. Don't use kerosene that stuff really stinks.
    Leaf blower works best to dry the engine and the car after a wash. Works really good for the interior, open all the doors, remove mats and loose stuff and go at it.
    After a wash use California Water blade than a blower in the crevices. Hardly have to use but one small mf towel to dry the entire car.
  14. Mendel Leisk
    38,207
    One of these works good, get's in the corners:
    Then I'll damp cloth the readily accessible top surfaces, take off the bogus engine cover and dampcloth it.
    I don't like the idea of washing solvents and strong detergents into nearby streams.
  15. edthefox5
    10,096
    4,795
    Clearwater, Florida
    What is that thing supposed to do?
  16. PriusCamper
    10,897
    4,418
    It makes rainbows come out of the exhaust pipe! :)
    xpcman and edthefox5 like this.
  17. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Bwaaaaaaaaaahahahahahaaaaaaaaaaaaaaaa
  18. edthefox5
    10,096
    4,795
    Clearwater, Florida
    I bet it came with his Honda.
  19. Mendel Leisk
    38,207
    skeptics :rolleyes:
  20. edthefox5
    10,096
    4,795
    Clearwater, Florida
