Do you use a paper shredder?
Discussion in 'Environmental Discussion' started by burritos, Sep 20, 2011.
  1. burritos
    burritos Senior Member
    4,946
    252
    Ours broke. Now all my sensitive material is hand ripped into quarters and then tossed into my compost bin. My wife thinks this is unsafe. I think this thought is crazy. I'm right, right?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I use a shredder. When mine broke while I was cleaning up for a move two states away, I bought another pronto. I think you are crazy. Go buy a reasonably durable one before you throw out anymore sensitive stuff ripped that way.
    AGES (10+ years) ago, before I had a shredder, I'd seen some news stories on TV of showing stuff reconstructed from what I believe was pretty well destroyed or shredded with a strip shredder. Don't underestimate the amount of free time out there by the determined...
    edit: Whoops... I didn't notice the compost bin part. I still think you're semi-crazy. Buy a replacement shredder.
  3. darelldd
    6,057
    388
    Northern CA
    I guess I'd only worry about the worms finding out your net worth.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    maybe it's time to go paperless?
  5. eaglesight333
    eaglesight333 Senior Member
    6,310
    77
    Northern, IL
    Shred and recycle. I think it is actually safer to shred and recycle than it is to shred and garbage. Now if shreading is not an option, compost bin is probably a decent way to go. Other options are: burning (if you can), or look to see if your bank holds a "shreading event". mine does about every 6 months.
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    FWIW, some areas will unfortunately NOT accepted shredded paper in the reycling bin. See http://www.wmnorthwest.com/redmond/recycling.html, for example.
  7. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    I shred and recycle. Some day I will have a separated house and I will shred and compost. Wouldn't the shredding be better for the composting?
  8. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    I'd think quarters aren't enough in case some blow away.
    May matter to some, others not: one of the negative things about composting shredded paper is you are introducing chemical agents used to manufacture the paper. I found this out when I was using our shredded paper as bedding for composting worms. They protested by escaping.
  9. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Your worms shouldn't be so picky! We shred as well, but haven't used it in compost...
  10. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    Buy another shredder and recycle. I am not sure that toner as a synthetic polymer is such a good idea for the garden.
  11. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I shred and recycle. I don't compost, mostly because I live alone and there isn't much food waste - I get angry when I have to throw food away. I would imagine that shredding would make the composting more efficient, but I really have no clue. I would agree that ripping into quarters may not be enough. Then again, I'd be pretty surprised if someone made an effort to look through a compost bin to get papers. Most thieves want the easiest and quickest, and I don't know that they'd go that route to do it. That doesn't mean they won't, but I'd imagine going through trash would be the first choice then moving to a neighbors.
  12. bisco
    48,944
    fireplace.:flame:
  13. TonyPSchaefer
    14,816
    2,496
    66
    It was just a matter of time before this turned into a flaming thread.
  14. burritos
    4,946
    252
    I don't really take the compost out of the composter much. Maybe once a year. It just shrinks and shrinks. Quite an amazing illusion.
  15. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I usually only compost newspaper as I know that is made with soy ink.
    I don't compost other types of shredded mailings because I'm not sure what type of ink, pigments and toner they used.
    Just buy a new shredder. I own several.
  16. Mendel Leisk
    38,205
    One of my sons was recalling when he got a shredder: set it up, plugged it in, then started looking around for something to shred: the only thing he could find was the shredder instructions...
    Not that shredder operation is rocket science. Basically: don't dangle your tie over it and you'll be fine. Still...
  17. wick1ert
    1,311
    183
    Delawhere
    ^^ a lot have a touch sensor now that the slightest touch and it'll shut the operation. I was quite surprised how little pressure it needed. Luckily I've never dangled a tie into one before, but I can just imagine a video is probably out there on YouTube of someone that did...
  18. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    My favorite, and I'm not making this up, was the temp gal asking "Where does the paper come out of the fax at?" as I watched her shred away.
  19. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Our local voting center uses a paper scanning voting machine, where each voter inserts his or her ballot. I've always wanted to rig up a sound effect generator to make it sound like a cross cut paper shredder.
    :D
    Tom
  20. barcelona11
    barcelona11 New Member
    71
    Central NC, USA
    I vote for a new shredder or holding it for the event at the bank. If thieves will go through trash/garbage looking for credit card offers, account numbers, etc. I would think curbside recycling would be an easy place to find some financial treasures. Shredding is alot less trouble than correcting identity theft.
