1. Offline
    PriusRoadWarrior Professional Driver
    Jun 14, 2009
    Message Count:
    68
    Appleton, Wisconsin
    Your Vehicle Year:
    Do you use the emergecy brake when parking or do most of you just use the "P" button? When using the "P" button, does it lock on the brakes? I have been just using the "P" button so far and my car doesn't seem to have moved when I get back. I guess I take Park in the Prius is like Park in any other car in that it will lock it down when in there. I have never used my emergency brake in any of my other cars. Responses please!
  2. Offline
    anne1965 Gotta love the game...
    May 23, 2009
    Message Count:
    131
    16
    Leiden, The Netherlands
    Your Vehicle Year:
    I
    You can save even more effort :) by not putting it in 'P'. The car puts itself in 'P' automatically on shutdown. The 'P' button does not activate the brakes, it blocks the transmission.
  3. Offline
    eaglesight333 New Member
    Apr 23, 2009
    Message Count:
    952
    33
    Northern, IL
    Your Vehicle Year:
    Just use the emergency brake like you normally would, when parked on a steep hill or driveway. No need to use it for anything else. The P is all you need when parking normally.
  4. Offline
    mikepaul New Member
    Dec 2, 2003
    Message Count:
    1,764
    Columbia, SC
    Your Vehicle Year:
    I always set the 'emergency' brake before I emerge from the car.
    It seems to rock somewhat if I don't and I can't imagine that being good for the transmission.
    I'm always annoyed when the oil-change guys forget to do it, but they must fix their own cars or something so it doesn't bother them...
  5. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    I do use it, but it's just out of habit more than anything else.
  6. Offline
    Bobsprius BobPrius
    Jul 23, 2009
    Message Count:
    679
    79
    Buffalo
    Your Vehicle Year:
    I use the "P" button and not the Emergency Brake. I would as someone else suggested to use that on non-level road conditions.
    The little give for the normal "P" does not seem to bother me. In fact, I think it may be minute but minute enough that if someone should "Tap" you the give be it ever so small might be a benefit to avoid a "Tap" to a car that has the Emergency Brake engaged with no slight give...
    My personal opinion only...
    :eek:
  7. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    South Puget Sound, WA
    Your Vehicle Year:
    i never use the parking brake unless i feel it necessary for complete safety precautions. iow, if parked on a slope.
    unfortunately, the parking brake is using 130 year old technology. its 100% mechanical and therefore it will wear out. for those of you that do it "by habit"...i suggest a 12 step program ASAP
  8. Online
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    This is my approach as well. On a steep hill, or somewhere that rolling is likely to be catastrophic, I will use the parking brake. Otherwise I don't.
    As for wearing out the parking brake, I have also had them fail from lack of use. I try to strike a balance.
    Tom
  9. Offline
    prioki New Member
    May 30, 2009
    Message Count:
    102
    CA
    Your Vehicle Year:
    2001 Prius
  10. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    well i also agree with that...my suggestion only goes to "habitual use". now i am located about 4 miles from the very southern tip of Puget Sound AND, i cannot swim. which means that all ground slopes toward the water. so yes, i do have a use for parking brakes anywhere from 2-10 times a month or so.
  11. Offline
    spiderman wretched
    Jul 5, 2009
    Message Count:
    5,625
    803
    Alaska
    Your Vehicle Year:
    Hi I am Peter, I use my parking brake habitually. Please forgive me. lol
  12. Offline
    yardman 49 New Member
    Mar 26, 2009
    Message Count:
    606
    68
    Northern Kentucky
    Your Vehicle Year:
    For those who live in areas where there is snow and ice, not using the parking brake is a worse thing to do. On some cars, if the parking brake is not regularly "exercised", it can become "frozen" as the linkage or cables rust. Then when you actually need it and apply it, it sometimes will not release properly, causing the rear brakes to drag, overheating the brakes, bearings, and causing a loss in gas mileage.
    Using it helps prevent such "freezing" of the mechanism. An added benefit is that if you have rear drum brakes, it lets you know if the rear pad adjuster is doing its job.
    Both Toyota and GM use a really "user friendly" parking brake: you step on it to set it, and step on it again to release it. It's so easy to do that I usually don't even think about it.
    As "exercising" the parking brake is a good thing, I will not be going to 12-step for this one. :)
  13. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    Your Vehicle Year:
    ummm Peter?? i think the correct phrase is;
    "Hi, my name is Peter and i am a "brakeaholic"
  14. Offline
    ecrider New Member
    Jul 31, 2009
    Message Count:
    Maryland
    Your Vehicle Year:
    I only use Park in my own garage but use my emergency brake when parked everywhere else. Probably just superstition, but my concern with only using Park elsewhere is that a bump from another car could damage the transmission.
    By the way, the emergency brake is one of the few things I find awkward about my Prius. I often end up kicking the vinyl trim when trying to engage the brake pedal with my foot, and/or accidentally double tapping the pedal and disengaging it. Much prefer the old hand brake or foot pedal with a hand release.
  15. Offline
    Mar 27, 2004
    Message Count:
    7,384
    760
    United States
    Your Vehicle Year:
    Yes. Would you rather have two tires holding your car motionless, or four? One mechanism, or two? Redundancy in safety is a good thing, and consistent use keeps it from freezing up.
  16. Offline
    Sneezy New Member
    Jul 13, 2009
    Message Count:
    181
    Upstate NY
    Your Vehicle Year:
    We have always used them on all of our cars and will continue to. Here in the great north east if you don't, 1 winter will cure it of working at all.
    I don't need no stinkin 12 step program.
  17. Offline
    SureValla New Member
    Jul 13, 2007
    Message Count:
    584
    White Plains, NY
    Your Vehicle Year:
    I've also heard using the break is a good thing. If you don't do it it won't work when you need it. I used to use it all the time when I parked on a slight incline. Now I only use it occasionally.
  18. Offline
    oxnardprof New Member
    Feb 27, 2004
    Message Count:
    240
    Oxnard, CA
    Your Vehicle Year:
    I always use the parking brake and push the P button.
    I notice that if I just shut the car off, it does go to P - but the car jerks or shudders slightly.
    I see no reason why I should not use the mechanical brake - I think of it (obviously) as a parking brake and not an emergency brake. I think the Prius design is particularly easy to use.
  19. Offline
    PriusRos A Fairly Senior Member
    Jun 22, 2006
    Message Count:
    1,666
    69
    Rockville, MD
    Your Vehicle Year:
    My name is Priusros and I use the parking brake.
    And I'm proud of it.
  20. Offline
    pdxrose New Member
    Jul 5, 2009
    Message Count:
    174
    23
    Vancouver, WA
    Your Vehicle Year:
    I use it most of the time; ever since a friend's BMW rolled in to his garage wall a few years ago, I always hear his voice saying...I probably should stop on flat ground. If I fail 12 step, guess I know what my first extended warranty repair will be :D I was surprised to see all the items below covered, whereas virtually all of the regular breaks would not be due to wear and tear. I am not a techie so wonder if parking breaks have pads that wear out too or just the stuff below?
    Parking Brake Cable• Parking Brake Control Handle Assembly• Parking Brake Lever Subassembly• Parking Brake Pedal Subassembly•
Share This Page
