1. Offline
    ftl Researcher
    Start a Conversation
    Jun 2, 2009
    573
    183
    Long Island NY
    Your Vehicle Year:
    I haven't seen this mentioned anywhere else, but over in SquallLHeart's interesting thread: LED swap! color change green to blue (in progress), we've been wondering why his Two has lights behind all its steering wheel controls and my Three doesn't.
    I've surmised that the Three and Four have the Touch Tracer display instead, which eliminates the need to be able to see the steering wheel buttons in the dark; can other Three/Four owners confirm that they don't have these lights?
  2. Offline
    ianblake Junior Member
    Apr 12, 2012
    52
    PR
    Your Vehicle Year:
    i have the lights on the steering wheel i have a C4
  3. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    I have all lights working on my steering wheel. Did you try to adjust brightness of your backlit with a help of a handwheel located on the left handside? And touch tracing dispaly has a bit diffrent function IMHO. Touch tracing display helps to keep your eyes on the road instead of the dashboard and steering wheel.
  4. Offline
    ddblue01 New Member
    May 27, 2012
    Orange County, CA
    Your Vehicle Year:
    I agree with Mik1. Check your brightness level. Also, are you using DRL? None of the controls light up when using DRL. The first two days I owned the car I thought Toyota was super cheap not making any of the controls light up and then I realized I didn't have my headlights all the way on. :LOL:
    taco4267 likes this.
  5. Offline
    ftl Researcher
    Jun 2, 2009
    573
    183
    Long Island NY
    Your Vehicle Year:
    OK, it's now completely dark outside and I turned off all the lights in my driveway. Here's what I found:
    With either the parking lights or headlights turned on, the steering wheel lights are on, but so dim that I can only just see them in complete darkness.
    The dashboard lights can be adjusted using the dimmer control, but this has no effect on the steering wheel lights.
    The steering wheel lights are dimmer than the dashboard lights set to their lowest brightness, so dim that I can't even photograph them.
    How does that compare with what you guys are seeing?
  6. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    Here is what I found in my PC4:
    1. Scrolling the dimmer is actually has no affect on the steering wheel controls brightness, it only change the brightness of the dashboard controls
    2. It is difficult to explan how brighter the dashboard lights compared to my steering wheel, but what I noticed that when the dimmer scroller is all the way down, the backlit of the steering controls looks as bright as a dashboard, but when I scroll the dimmer all the way up, the dashboard brightness is couple times better compaired to the steering wheel.
  7. Offline
    ftl Researcher
    Jun 2, 2009
    573
    183
    Long Island NY
    Your Vehicle Year:
    OK, that sounds pretty well like what I'm seeing, although the dash lights look to me a bit brighter than the wheel lights even at the lowest setting.
    I guess I should go to a dealer at night and check the lights on another c.
  8. Offline
    SquallLHeart The Techie Guy
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    the lights on the steering wheel are not controlled by the dimmer circuit.. that's definitely true.. as sometimes i wish i could turn mine down because it's so bright and shiny... it can be distracting sometimes.. :ROFLMAO:
    but yea.. the stock leds in the controls are pretty dim in there for the most part.. i was slightly concerned when you said you didn't see them light up at all... but now the mystery is solved.. they do work.. just yea.. it's dim..
  9. Offline
    Mik1 Member
    Apr 17, 2012
    335
    49
    Houston, TX
    Your Vehicle Year:
    That's a good point Squall, I guess that might be a reason behind it. If the lights on steering wheel are not dimable, I would prefer to have what I have instead of always be pissed and distracted with too bright and shiny controls....
  10. Offline
    Apr 12, 2012
    52
    PR
    Your Vehicle Year:
    the brightness level don't work w/ the steering wheel lights
  11. Offline
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    umm.. yea... i already said that.
  12. Offline
    col127 Member
    Apr 4, 2012
    230
    Your Vehicle Year:
    so is there any way to increase the brightness of the steering wheel controls? mine are really dim too... :p almost as if they're not even on!!
  13. Offline
    ftl Researcher
    Jun 2, 2009
    573
    183
    Long Island NY
    Your Vehicle Year:
    You'd have to replace the LEDs with brighter ones. See the link to SquallLHeart's project in the first post in this thread.
  14. Offline
    col127 Member
    Apr 4, 2012
    230
    Your Vehicle Year:
    bah.... :) i don't have the technical know-how to do that, nor would i want to pay for it... :p but i do love that blue!!!! not a fan of the green at all.. yuck! :)
    ChuckGVT likes this.
  15. Offline
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    it's not too hard to do... (at least for me.. lol..)... but uhh... as long as you're handy with a soldering iron.. and know how to use a screwdriver... that's pretty much all you need.
  16. Offline
    ksor New Member
    Nov 3, 2012
    28
    Aarhus V, Denmark
    Your Vehicle Year:
    I have a 2008 model and want to find out how to change the LEDs in the steering wheel - how can I take the buttons apart to change the LED in there - or maybe the whole cover in one peace ?
    Any of you done it on a 2008 model ?
  17. Offline
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    The process would be similar. After removing them from the car, it's all little screws that hold the pieces together.
  18. Offline
    ksor New Member
    Nov 3, 2012
    28
    Aarhus V, Denmark
    Your Vehicle Year:
    Yeah, but how should I START removing them
Share This Page
