1. Offline
    alfon New Member
    May 17, 2009
    Message Count:
    925
    126
    seaside, oregon
    Your Vehicle Year:
    Well, pretty soon the EPA will test the new 2010 thru 2011 cars for Miles per gallon.
    Does the EPA use the required gas mixture of 10% Ethanol mandated by several states, Oregon, where I live, is one of them?
    This could be the reason why many 2010 Prius owners are not getting the average benchmark by EPA of 50 MPG.
    If the gas used for testing was pure regular unadulterated gasoline the EPA figure of 50 MPG average would be easlily attainable.
    But with Ethanol there is a loss of MPG's. That could be the reason why so many people only report in the high 40's MPG for their 2010 Prius.
    I bet if you did a poll states with mandated 10% Ethanol would get less MPG than those states where regular gas is allowed.
    alfon
  2. Online
    Apr 14, 2009
    Message Count:
    3,988
    937
    Greenwood MS USA
    Your Vehicle Year:
    In theory, in general, ethanol has higher octane, but lower energy, by 30% (many premium blends have less energy than regular, they just resist knock better.
    So again in theory, in general you would expect a 3% reduction in mileage with 10% ethanol. The various Prius engines, (Gen I to Gen III) may do better or worse than 3%, like all engines. Engines that like higher octanes will do better, but the Gen II has no preference for higher octane. So far as I know, no one has exhaustively tested Gen III.
    http://en.wikipedia.org/wiki/Ethanol#As_a_fuel
  3. Offline
    Celtic Blue New Member
    Aug 4, 2008
    Message Count:
    2,224
    129
    Midwest
    Your Vehicle Year:
    The impression I've had with several vehicles (single tank measurements) is that ethanol mpg loss exceeds 5% and is not compensated for by reduced price.
  4. Offline
    john1701a New Member
    Jan 6, 2004
    Message Count:
    5,511
    968
    Your Vehicle Year:
    You'd likely not have a large & accurate enough sampling to properly conclude that.
    The average for my Prius is 54.3 MPG, despite only using E10 and just driving it.
  5. Offline
    angelrob New Member
    Aug 1, 2009
    Message Count:
    94
    Rochester, NY
    Your Vehicle Year:
    In Illinois, where I visit my family, the E10 is cheaper. In upstate New York, where I live, only a few stations have E10 and the price is the same as regular gas. :mad:
    The last 3 half tanks I had (I was traveling) ended up being E10 and my mileage dropped from 58ish to 53ish. Note that it may have been due to the different driving (almost entirely highway/thruway and a bit hillier vs my normal 50/50 with a few small hills) but I didn't spend time searching for regular gas, just chose the closest stations.
    On another note, my latest full tank, purchased at my regular station is yielding in the low 50s on my regular commute. A coworker (Prius II driver) stopped by yesterday and asked if my mileage had dropped in the last week. His did and he thinks that the winter formulations have been started :eek:
    Robbin
  6. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    The original question is a good one. I would doubt they use E10. Good question though, and one I would like to have the answer too also.
  7. Offline
    mikepaul New Member
    Dec 2, 2003
    Message Count:
    1,764
    Columbia, SC
    Your Vehicle Year:
    Now that it's hard to find 'real' gas anymore, perhaps that's why I only average like 43MPG anymore. It was 50MPG up near Buffalo in August, but now I can't recall what those pumps said. I thought it was the terrain.
    Where do you FIND non-E10 gas anymore? I thought the required pollution-reducer they used to use was banned?...
  8. Online
    cwerdna New Member
    Sep 4, 2005
    Message Count:
    8,538
    985
    SF Bay Area, CA
    Your Vehicle Year:
    Don't know the answer but they use a special blend of gasoline for the test.
    Why do you think that owners of any car should necessarily get EPA "benchmark" mileage? See the two links at http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html for info about the test.
  9. Offline
    angelrob New Member
    Aug 1, 2009
    Message Count:
    94
    Rochester, NY
    Your Vehicle Year:
    I'm near Rochester and I've only seen a few stations with E10 (Delta Sonic was one, a local Gulf was the other). I usually go to BJ's since the price is good and I was just below 55 calculated MPG (58.x reported)
    Robbin
  10. Offline
    alfon New Member
    May 17, 2009
    Message Count:
    925
    126
    seaside, oregon
    Your Vehicle Year:
    Sure would be nice if the EPA advised us consumers, who pay for the EPA, if they use 10% Ethanol in their testing as many states in the U.S. now require, mine included, all year long, not just winter.
    I believe if the EPA did you would see a 5-8 % drop in MPG across the board.
    Look at E-85 the so called enviormentaly friend gas that gets nearly 40% less mpg than regular gas.
    So you use nearly twice as much gas to go the same distance. That is really saving the enviorment.
    alfon
    1 people like this.
Share This Page
