Does your Prius shudder?
Discussion in 'Gen 3 Prius Main Forum' started by xvs, Sep 10, 2009.
  1. Yes I notice at least a slight shudder
    26 vote(s)
    48.1%
  2. No, I don't notice it turning off at all
    28 vote(s)
    51.9%
  1. xvs
    xvs
    Expand Collapse
    Junior Member
    52
    san francisco
    I have a new 2010 Prius with about 150 miles on it so far, and I'm noticing that when the IC engine shuts itself off there is a noticeable shudder.
    I don't think this was happening for the first 80 or so miles, so I'm curious: does your Prius have a little shudder when the ICE goes off?
    It's the same kind of shudder you'd notice in some normal cars when turning off the engine, but I didn't expect it in the Prius.
    Edit: I made it into a poll. Please vote!
  2. DavidA
    DavidA
    Expand Collapse
    Prius owner since July 2009
    833
    353
    17
    Chicago western burbs
    Mine doesn't shudder, but with 600 miles on it I now notice the ICE turning on or off more than the silky smooth trasition when the car was new a month ago.
  3. Econ
    Econ
    Expand Collapse
    Member
    329
    24
    East of the Berkshires - MA
    Mine does not shutter.. smooth as glass all modes.
  4. Spartane
    Spartane
    Expand Collapse
    Member
    149
    40
    Mississauga, Canada
    I often feel a minor bump on my 2010 when the engine starts up (similar to driving over a small bump on the road, or maybe a transmission shifting gears in a normal car), but so far after about 3500 miles there's not even a hint of a shudder for either the start-up or the shut-down cycles.
    I remember renting a previous generation Prius (maybe a 2008?) last year with about 35,000 miles on it that did have a pronounced shudder that was a bit annoying, so I think I would notice it in the 2010 if it existed.
  5. PriMPG
    PriMPG
    Expand Collapse
    New Member
    Southern Cali
    Yeah, it's definitely noticable on my GenIII Prius both when the ICE turns on and off. Definitely not as bad as a normal car turning on/off but it's somewhat annoying since the Prius does it a lot more often.
  6. maledyris
    maledyris
    Expand Collapse
    New Member
    77
    Burnaby, BC, Canada
    There's definitely a noticeable transition between the engine running and not running. Sometimes it's more obvious than other times. I figured it was probably normal. Afterall, it may be an efficient ICE, but it's still an ICE.
  7. anniea
    anniea
    Expand Collapse
    New Member
    59
    Atlanta
    I've had my car for three months and about 2300 miles--I feel nothing when the ICE comes on and off--completely smooth transition. When I first start the car, I do feel it come on initially, and I understand that's to help it warm up. But after that, there's no indication of whether or not the engine is on.
  8. a64pilot
    a64pilot
    Expand Collapse
    Active Member
    771
    59
    Albany Ga.
    Yep, definite shudder, not as pronounced as in a Gen II though, but still there. Nature of the beast, I believe
  9. energyandair
    energyandair
    Expand Collapse
    Active Member
    881
    300
    Victoria BC Canada
    I generally have to look at the display to know if the engine is on or off
  10. jay_man2
    jay_man2
    Expand Collapse
    jay_man_also
    1,246
    141
    Manassas, VA
    I went from an '08 Highlander Hybrid where shudder was putting it mildly to the Prius, which by comparison is smooth as glass. But after 12 weeks, I am noticing the transitions more than when I first got the vehicle.
  11. Old Bald Guy
    Old Bald Guy
    Expand Collapse
    Old Bald Guy
    89
    Ft. Worth, TX
    My 2008 did have a noticable shudder on starting and stopping of the motor ... my 2010 is smooth as silk .... there is definately a much less noticeable transition on the new car. We noticed the difference almost immediately, because of the difference in feel from the 2008.
    We just finished a 3500 mile trip through several western states ... crossing the Rockies both ways ... smooth as glass ... no shudders at all ... and 80+ MPH for hours at a time is a piece of cake.
  12. tumbleweed
    tumbleweed
    Expand Collapse
    Senior Member
    4,067
    651
    Eastern Oregon
    Very slight on shutdown when stopped but yes it is noticeable, someone not familiar with the car might not notice at all. I also feel it restart when I am driving, at least sometimes. In fact if you have good hearing you can hear it restart.
  13. a priori
    a priori
    Expand Collapse
    Canonus Curiosus
    3,083
    403
    23
    Chicagoland (West)
    The "shudder" you feel is going to be more pronounced the "colder" the engine. The first time the ICE turns off after a cold start is the most likely one to provide a noticeable shudder. The ICE needs to stop in an optimal position for restart, and it is a bit more difficult, it appears, for the ICE to reach that spot when the engine is cold.
    The longer you drive (per excursion) and the more miles you put on the car (per drive and overall), the less noticeable the shudder. Ambient temps also had an effect in the Gen2, and I am expecting the same in the Gen3.
    I will say that the ICE on/off transition is much more difficult to determine in the Gen3 than in the Gen2, all things being equal.
  14. PriusSport
    PriusSport
    Expand Collapse
    senior member
    1,475
    SE PA
    Sometimes. Not often. Doesn't seem to be a concern.
  15. tumbleweed
    tumbleweed
    Expand Collapse
    Senior Member
    4,067
    651
    Eastern Oregon
    Not a concern at all, I'd miss it if it didn't do it. I like it, I also like all those inverter and motor/genertor noises. If it quit doing those things I would think something was broken.
  16. spiderman
    spiderman
    Expand Collapse
    wretched
    7,473
    1,450
    Alaska
    I have about 2K miles now and the "shudder" has been getting more pronounced (over that last 1K). The first 1K it was very smooth. Of course it has been getting colder up here so I suspect that might have something to do with it. I wonder what it is going to be like at -10 or -20 below! :eek: I can't even imagine taking my baby out in that cold of weather.
  17. jay_man2
    jay_man2
    Expand Collapse
    jay_man_also
    1,246
    141
    Manassas, VA
    Roger that. :tea:
  18. garygid
    garygid
    Expand Collapse
    Senior Member - Blizzard Pearl
    379
    22
    Orange County, CA
    Three weeks, 1300 miles, 100 degree daytime temps, and no noticable shudder is felt.
    Also, I can barely hear it, but my hearing is low frequency only.
    Except when using significant power (when the ICE can be heard easily), it is tough to tell if the ICE is running or not. The only real indication is that the display shows the little red "moving" arrows.
    But the red arrows are almost too dim to see, much dimmer than the white arrows. Is that normal? Seems like a design flaw. Is there a way to make them more visible? Thanks.
  19. 32kcolors
    32kcolors
    Expand Collapse
    Senior Member
    5,728
    934
    124
    Redondo Beach, CA
    Ditto. The only times I can notice the shudder is upon first starting the ICE and when it first shuts off after a cold start. I can't detect it at all once the engine is warmed up.
    However, I do shudder noticeably at some of the posts on this forum.
  20. radiocycle
    radiocycle
    Expand Collapse
    Active Member
    548
    77
    Vallejo, CA
    A little over 3200 miles here and I listened, and felt, very carefully this morning when out and about. Smooth as glass, don't feel a thing. I'm aware of the ICE shutting down but no 'shudder'.
