"DOH" Recall - Brake Booster Pump Assembly (Accumulator)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Den49, Aug 6, 2013.
  1. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Still no notice or phone call for me. :(
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Is your build date prior to mid-October 2009?
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Got the notice yesterday and have an appointment Sat. No loaner. :(
    I suspect they may not petform the work for whatever reason, like the undercover, and I.M. ordeal. So I was hoping to appeal to those who had it performed if they would be so kind as to list the dealer's name and a contact # so I can use that to convince.
    Thanks
  4. Dark_matter_doesn't
    691
    151
    Seattle, WA
    My VIN number is in the recall range according to the Toyota website.
  5. jdcollins5
    5,131
    1,338
    Wilmington, NC
    OK. Contact your dealer, you do not have to wait or the letter.
  6. tjherndo
    tjherndo Junior Member
    Tennessee
    2019 Prius
    Took my 2010 Pirus III in at 7:00 am. It was not ready until 5:00 pm. They changed the booster and Master Cylinder. I was not aware of any problems beforehand.
  7. drive till it HERTZ
    drive till it HERTZ New Member
    What is the brake pedal travel, when the car is turned off after the recall is done? The pedal travels to the floor. After pumping the pedal there is about a 1 inch to the floor then slowly travel to the floor. Is this right? The dealer is telling me that's the way it should be.
  8. Mendel Leisk
    38,214
    We got ours done today. They replaced Brake Booster Pump Assembly and Brake Fluid.
    Went ok I think. I haven't driven it yet, but my wife thinks EVERYTHING feels better, the ride, the brakes, and so on, LOL.
    spiderman likes this.
  9. DavidA
    2,325
    1,811
    Chicago western burbs
    Nothing about that sounds right. "Pumping"? You mean repeatedly?
  10. Kevine64
    Kevine64 Junior Member
    87
    Not right at all. I'd go back and request in writing signed documentation stating your exact complaint and them stating it's normal. Then go to another dealership or a third party shop to have them diagnose the issue. After that call up Toyota and make a complaint.
    I understand but don't agree with dealerships saying things are normal to avoid paying for warranty repairs but brakes are nothing to mess around with. Huge safety issue.
    Keep us posted!
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Took my car in yesterday and they verified that I needed the new assembly by checking the part number of the old one. Put the new one on order gave me a free car wash and said they would call when it came in, probably next week. I was also told that I would get a brake fluid change to go with the new booster pump/accumulator.
  12. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    Bringing mine in on Wednesday. Build date 05/09. I'll let you know how it goes.
  13. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    not to mention the soundsystem improvements :)
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just dropped mine off. When I called yesterday to make the appointment the lady said that it would just be an hour or so to determine if it "needed" it. I get there and the SA said, oh it will take all day if not into tomorrow! What? He said they will just do the work. He said all that have come it needed to be replaced. Great, I wish the lady just mentioned that yesterday. Had to call the wife to come get me (out of range of the courtesy van and no loaner). But I am glad they are going to do the work.
  15. drive till it HERTZ
    Repeatedly - Several time in a row.
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Work done, accumulator and brake fluid replaced. No real noticeable difference thought the pump seems to run less and pumps up faster... Anyway all my stats were wiped because the battery was disconnected... be sure to get the information down before surrendering the car.
  17. DavidA
    2,325
    1,811
    If you go back there, or another dealer who might want your business more, then have the service guy try the brake action and then immediately try a new showroom car to compare. Since the brake systems would then be "new" in both cars, theirs and yours, it should compare exactly.
  18. Kevine64
    87
    And ask for stuff signed and in writing. Once people know your documenting or have something with Thier john Hancock on it they change.
  19. Dark_matter_doesn't
    691
    151
    Seattle, WA
    I finally received my notice yesterday, and I can't find any mention of a possible brake master cylinder replacement.
    I'll schedule the work this coming week.
  20. szgabor
    993
    175
    Oceanside NY
    my letter said it will be inspected and replaced if necessary whatever that means... but someone pointed out that if the problem is not there now but occurs later the same rules apply namely they will fix/replace at no cost to you.. I know it is somewhat scary to have a possible break issue
    The car I got the letter for WAS replaced already and I have a 2012 model which do not have this issue... the older was 2009 april-may build I got it in July ...
