1. Offline
    zcat3 New Member
    May 4, 2008
    117
    35
    SF Bay Area
    Your Vehicle Year:
    So with gas now below $2 - I think the national average is about $1.75, I was curious what the cost of just driving with gas vs. PHEV vs. electric is. I know everyone pays different amounts for electricity, but here in the San Francisco Bay Area, PG&E currently list an average residential rate of $.175 per kWh.
    So using 200 miles as a baseline. This is what I get:
    Pure Gas at 45 MPG = 4.44 gallons x $1.75 = $7.77
    Hymotion PHEV: 200 at 100 MPG = 2 gallons gas = $3.50 + 32 kWh x .175= $5.60 = $9.10
    Pure Electric (based on a Tesla getting 200 miles on a 55 kWH charge) = 55 x .175 = $9.625
    For the Hymotion I am using my number of close to 100 MPG and 4 kWh every 25 miles.
    Are these numbers wrong? Is electric currently more expensive than gas?
  2. Offline
    bedrock8x New Member
    Jul 8, 2008
    1,111
    64
    Your Vehicle Year:
    It depends how much you paid for electricity. In your case it is very close but you also need to amortize the replacement cost of the battery for HEV, PHEV and EV. Many tend to ignore it to make the cost of electricity cheaper and some has solar power and claim the electricity is free without considering the initial investment.
  3. Offline
    dr_d12 New Member
    May 26, 2008
    151
    Your Vehicle Year:
    Aren't you underestimating the cost of the electricity by assuming a kW in the battery costs a kW at the wall? What is the charging efficiency of a lithium battery?
    Oh, Wikipedia says 99.8%. That surprises me. I read that our NiMH are only about 60% efficient.
  4. Offline
    ibcs New Member
    Aug 26, 2005
    351
    31
    Englewood , Ohio
    Your Vehicle Year:
    I guess I feel lucky, my electric is only .09 per KWH.
    Hymotion PHEV: 200 at 100 MPG = 2 gallons gas = $3.50 + 32 kWh x .09 = $2.88 = $6.38. Hymotions saves $1.39 per 200 miles, but I send less money overseas for oil.
    ---Kent
  5. Offline
    ghb101 New Member
    Jun 28, 2006
    I'm no expert but from what I've read I'm thinking that your 4 kWh for 25 miles would be valid if it was all electric driving since the pack is about 5kW. However then you wouldn't need to include the gas for the calculation and you would come out with $5.60. If you using 100 MPG for the Hymotion, then I believe that the kWh would be less that 4kW per 25 miles since the ICE is working as well. Would be useful to know how many miles people with Hymotion installed travel at approximately 100 MPG before battery runs out. I'll be it is a bit farther than 25 miles ( or their MPG is higher than 100).
  6. Offline
    ibcs New Member
    Aug 26, 2005
    351
    31
    Englewood , Ohio
    Your Vehicle Year:
    For me it works out to be about 28 miles for highway driving.
    ---Kent
  7. Offline
    PeakOilGarage Nothing less than 99.9
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    I pay 8 or 9 cents per kwh. Mostly hydro electricity up here in the Seattle region.
    For me I can achieve 41 miles from Hymotion if it is 100% highway.
    My Hymotion does 23 miles if it is 100% EV on city roads under 33 mph.
    Since my driving is typically a combination of both city/highway, I typically get 30 to 32 miles from the battery.
    On cost of electricity, (zcat3) are you on the EV schedule with PG&E? I thought that the cost per kwh was 9 cents on the E9 schedule based on time of use costs. People who have an EV get charged the cheap rate if they recharge at night.
    Martin Eberhard (Tesla Founder) has a few posts on this topic related to recharging his Tesla. Tesla Founders Blog
  8. Offline
    Codyroo New Member
    Oct 24, 2007
    1,192
    199
    Pleasanton, Ca
    Your Vehicle Year:
    A quick check of PG&E's site turned up this....
    For the typical PG&E residential customer that uses 550 kilowatt hours (kWh) per month, October bill increases will be roughly 95 cents from $72.13 to $73.08. In January, the bill for a typical residential customer would increase by about 35 cents more
    That would be a rate of $0.133 (for Oct 2008) to $0.134 (Jan 2009). Also, the plan you are on makes a difference in rates too.
    If you sign up for the E-9 rate program (available if you have an Electric Vehicle) EV, you can charge up for even less (under $0.06 at the lowest). The rates are calculated as a time of use.
    Electric Vehicle Charging Rate and Economics
    Finally, when we put solar panels up on our house, we switched from an E-1 rate schedule to E-7 (time of use). Off peak rates (6 pm - noon) are typically when you would be "recharging". Off peak rates are around $0.11 in the "summer" and $0.09 in the "winter" (winter = Nov - March or so). I'd have to look it up on our bills from last year.
  9. Offline
    boxer93 Psyched for PHEV
    May 9, 2008
    155
    22
    Southern NH
    Your Vehicle Year:
    ghb101,
    In my experience the 4kWh is for 25 miles of combined ICE and EV Only travel. Plus like your standard Prius MPG varies greatly on conditions. Yesterday My 10Mi morning commute 15 deg F 82MPG Today same commute 55 deg F 178MPG. I run with EBH and full grill Block. Also remember the MPG is only for the fuel used for the ICE. MPG calculation for kWh vary greatly. Again in my experience I use 150-200kWh/Mi.
    Chris
  10. Offline
    zcat3 New Member
    May 4, 2008
    117
    35
    SF Bay Area
    Your Vehicle Year:
    I am on a E-7 meter as we have solar on our house, so yes, my cost of electricity is .09 per kWh in the evening (or hopefully free if we generate enough power for our house).
    I looked at the E-1 PG&E standard tariff schedule, where they state the average cost of electricity in Region T (the SF Bay Area) is 17.5 cents.
    I wonder if it is possible to have two meters - one E-7 meter for the solar and the house and an E-9 meter for charging the car as that is still a better rate than the E-7 solar rate?
  11. Offline
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    I would read the Martin Eberhard Tesla Founders blog. He has some spreadsheets on there to figure out the details.
  12. Offline
    zcat3 New Member
    May 4, 2008
    117
    35
    SF Bay Area
    Your Vehicle Year:
    Yeah - I read it - not sure it helps me. There is a big difference in the amount of electricity the Tesla uses vs. a Hymotion Prius. Just the extra $8 a month I would pay for the E-9 meter probably makes it not worth doing.
    As an aside, I see you are in line for a Tesla. My wife and I plunked down our 75K deposit about 2.5 years ago and were number 139. After our daughter was born and we saw the opportunity for PHEV's was getting close we decided to cancel our order and get the Prius (all of us can ride at the same time). I was one of the first customers to get to test drive the Tesla - very nice car. My review is still soemwehere in the Tesla Blogs.
  13. Offline
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    You should have taken delivery of the Tesla, then sold it at a premium. :)
    Or you could have sold your place on the list to someone looking to move up.
Share This Page
