1. Offline
    navguy12 Junior Member
    Start a Conversation
    Jan 20, 2012
    179
    24
    Batawa Ontario
    Your Vehicle Year:
    Help!!
    Putting in an LED into the dome light (over the back seat area) and my smart key system as well as my interior lights do not work.
    I couldn't even turn on my head-lamps until I put smart key into dash-board and now I get head-lamps when manually turned on.
    The fuse for the smart key is good and the other items on that fuse all work. Can't sort out what fuse would tie the smart key system to the interior lamp system, but those 2 systems are not working.
    I undid the negative wire from the 12 volt battery in an attempt to 're-boot' the car, but still no luck.
    I'm about to go on a test drive to see if I can actually drive the car....
    Again, I think I may have created a momentary short across the leads for the ceiling light bulb in the dome light as I was trying to install an LED with a festoon bulb adapter.....
    Thanks
    Cheers
    Mike
  2. Offline
    Jan 20, 2012
    179
    24
    Batawa Ontario
    Your Vehicle Year:
    After my test drive, the "VSC" warning lamp is glowing on the dash-board....so no smart key, no stereo system, no interior lights and no VSC.......
    ....please pipe in if you think you know what it would be.......
    Thanks
    Cheers
    Mike
  3. Offline
    Jan 20, 2012
    179
    24
    Batawa Ontario
    Your Vehicle Year:
    no clock...must use mechanical key to lock or unlock doors....
    ...have I fried my "Body ECU"?
    I ask because looking at my Bentley's manual, all these items tie together at the "Body ECU".
    Scan Guage II does work, I get my 'numbers' on my test drive....and it says 'no codes' and 'no pending codes'.
    Help....:(
  4. Online
    koolingit Member
    Mar 17, 2009
    111
    27
    Mocksville NC, USA
    Your Vehicle Year:
    Dome lamp fuse in engine compartment fuse box?
  5. Offline
    Jan 20, 2012
    179
    24
    Batawa Ontario
    Your Vehicle Year:
    I checked EVERY single fuse in this car. No fuses are blown.
    • no auto-dimming mirror
    • no Home-Link
    • no Smart Key
    • no interior lights
    • no exterior lights or headlights unless key fob in slot and power button pushed on
    • no power locks via power lock button unless key fob in slot and power button pushed on
    • no access thru rear hatch unless key fob in slot and power button pushed on
    • no clock
    • no stereo
    • VSC warning when car is driven
    • hybrid system works, AC works, electric steering works, multi-disply works
    :eek:
  6. Offline
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
    It is hard to believe that some fuses are not out, given so many systems are not working. I hope that you used an ohmmeter to verify each fuse is good - do not rely upon visual inspection. Also note that the car has a fuse box under the dashboard as well as the main relay/fuse box near the inverter.
    If you still do not find a fuse problem, then I suggest that you obtain the electrical wiring diagram for your car from techinfo.toyota.com
    Then start with a simple system like interior lights or the clock, and work from that system backwards towards the 12V battery until you find where 12V power is available. That will be the point where that particular problem resides. Good luck.
  7. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,918
    Northern Michigan
    Your Vehicle Year:
    This is a fuse problem, regardless of the OP's comments to the contrary. Clear the short, if it still exists, and replace the bad fuse or fuses.
    Tom
  8. Offline
    Jan 20, 2012
    179
    24
    Batawa Ontario
    Your Vehicle Year:
    100% correct. I rechecked the fuse I logically thought it should be, the 15 amp 'dome' with an ohmmeter and sure enough, it was blown......
    Thanks folks, new fuse in and all is well in my world again :)
    1 people like this.
Share This Page
