door lock "beep" stopped working!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jonb505, Jun 16, 2014.
  1. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Ok so my v no longer beeps or flashes the lights when i lock it using the sks touch sensors or key fob.
    I just loaded up my prius v at my storage unit full of stuff to bring back to the house. It is packed to the ceiling. I had a small camping cooler at about ceiling height right behind the drivers seat on top of some other stuff. I thought if I drove gently it would be ok, well i stopped a little too fast and the camping cooler launched itself into the dash/center console, bounced off it and landed on the passenger seat. I didn't see exactly where it impacted on the dash but there appears to be no marks or damage on the climate control or display audio. So the problem is now, maybe this just a coincidence, but when i lock the car from the outside using the FOB or the touch sensor on the door handle I just hear a faint click of the doors locking,(they doors still lock like normal) but no beep or flashing lights like before. I still get the flashing lights and beep sound when unlocking the doors.
    Any idea what I could have done? :confused:
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    There is a setting available for this function. Hard telling what the issue is for you. Coincidence is always a possibility.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I think that signal also indicates that the vehicle is, in fact, secure.
    Maybe one of the doors or hatch isn't closing properly......or the associated switch thinks that it isn't.
  4. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Right you are. Thanks for replies.
    I locked it this morning and turns out the rear driver side door was not locking. I have the seats folded flat and stuff on top, nothing really heavy but enough that it must have triggered the rear occupancy sensor?? Or maybe the load was sitting on the rear seat headrest and triggered something to prevent the door from locking? I shifted the load around and then it locked like normal. Didn't even realize there was any kind of sensor for the rear seats. I'm 100% certain that door was closed fully, there was nothing resting against it. Weird.
  5. Easy Rider
    982
    210
    N. Central Florida
    I'll believe wierd; I do NOT believe there are any "sensors" in the back.......and even if there were, the presence of a person in the back seat shouldn't prevent it from locking.
    I think it's more likely that your 100% really is 99%. :)
  6. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    I don't know, i'm starting to think this car has a mind of its own. :unsure:
    I still don't know what would cause only the rear driver side door to not lock when locking all doors on the key fob/sks sensor. would this happen if the door wasn't fully closed?(weather seal lose, seat belt stuck in the door, etc).I do have trouble with the rear hatch not closing sometimes(i don't slam it hard enough or the weather seal pops off when unloading stuff) but the dash lights up showing a door is open in that case. Do the rear passenger doors have a sensor to tell if the door is open like the front doors do?
  7. rdgrimes
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Most likely something was pressing on the unlock button on the rear door.
  8. Easy Rider
    982
    210
    N. Central Florida
    Brilliant.
    A perfect example of "don't overlook the obvious". (y)
    Yes, I'm pretty sure there are "sensors" on the back doors too.....just like the front.
