Door Lock on back order
Discussion in 'Gen 2 Prius Technical Discussion' started by pgc100, Jun 19, 2007.
  1. pgc100
    pgc100 Junior Member
    So after a week or driving my new 2007, I was still trying to work out why the lights didn't flash when I locked the car. They would flash anytime I unlocked from the remote. When I went to troubleshoot the alarm not priming, I found out that the rear driver side door lock was jammed. It would not move either manually or with the remote.
    It went back to the dealer yesterday. They are saying that the actuator is broken and that the part is on national back order. They can't bypass the actuator to get the rest of the doors to lock and the alarm to prime.So it looks loike I'm in a service loaner for a few weeks.
    Not a great start to my Prius experience.
  2. pgc100
    So a week later, there is still no sign of the part. I had to chase down the service rep at the dealer to get a status. There is still no due date on the actuator. The rep was not exactly sympathetic. His attitude is "what’s your problem we gave you a loaner car". My problem is that the loaner car is not the car I bought; it has been broken into at least once (before I got it), someone had been smoking in the car (a big annoyance) and I hate the way it drives. Its a “Fly by wire throttle†and the car just suffers from throttle surges. When you ask for power there is a delay and the computer will decide if it wants to give you it. Sometimes it waits and then gives you more that you want. Very annoying. I know these systems are supposed to “learn the driver†but this one is failing ME-101 very badly.
    One bright note was that the first tank of Gas returned 28MPG which is more than I was expecting.
    Would anyone have a parts list for the 07 Prius. I wonder if I can get the part number, I could source the actuator myself.
    I will have to work out when my 20 days are up as I can see me ending up filing a “Lemon Law†claim against Toyota.
  3. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(PGC100 @ Jun 26 2007, 02:08 PM) [snapback]468416[/snapback]</div>
    I had the search set for my 2006, but it should be the same part:
    http://www.trademotion.com/partlocator/ind...amp;catalogid=2
    Here's another source, but it uses the same database:
    https://www.trademotion.com/partlocator/ind...m?siteid=213804
    Kind of expensive at $213. I'd call them to check on availability and to be sure to get the right part. If they have it in stock, try to get your dealer to buy it from them.
    Seems like part look-ups is about the only kind of post I do anymore.
    - Tom
  4. pgc100
    Thanks for the quick response. I'll give them a call and see what I can set up.
  5. swc001
    swc001 Junior Member
    Westerville, OH
    Odd... I have a 2007 with a jammed driver-side rear door actuator. I took the inside skin off and was able to verify this. I need to get the right size spline tool to take it off. Maybe I can get it apart and repair it rather than replace it, but it sure seems like there are a number of posts of 2007s with rear door lock issues!
    No, it's not under warranty (salvage/rebuilt). Wish there'd be a recall though.. seems to be a common enough thing...
