Door Opening "Buzz"
Discussion in 'Gen 3 Prius Technical Discussion' started by Maine Pilot, Apr 10, 2011.
  1. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    When opening the driver's door after the car has been sitting all night, a buzzing sound from the engine compartment can be heard, lasting from 5-10 seconds. What is it?
    Yes, I've tried doing several searches, but nothing describing this noise has come up.
  2. Mark57
    2,945
    2,735
    OK
    What you are hearing is the brake pump, as it starts to build up pressure, in preparation for you to use the brakes.
  3. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Watch the DVD that came with the owners manual.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
  5. Maine Pilot
    166
    504
    Saco, Maine
    Thanks for your responses and patience.
    Tried searching for "Buzz", "Noise" and a few others, but the search function didn't give me any responses. I did view the CD that came with the vehicle, but don't remember a reference to that noise.
    Now, does opening the door actually activate the brake hydraulic pump (via a microswitch) or does it activate automatically as the pressure decreases below a certain point?
  6. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    I'm not a technician and my explanations tend to be simplistic but it's my understanding that the Prius prepares to be driven and then shuts down when driving if finished. This is why there are noises prior to driving and noises afterwards.
    So to answer your question, it's the recognition that the driver is entering the car that initiates the preparation cycle.
  7. qbee42
    18,058
    3,073
    Northern Michigan
    Yes to both. Low pressure causes the pump to activate when the Prius is Ready. Opening the driver's door also enables the pump, since one of the first things drivers do is step on the brake.
    Normally the pressure bleeds off during the night, so the pump will cycle as soon as you open the door. During driving, the pump will cycle roughly every third time you brake, give or take a few.
    Tom
