Double vision, cleaning instrument panel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JB88, May 28, 2013.
  1. JB88
    JB88 Junior Member
    Bought a '13 Prius four less than a week ago and while driving home tonight could have sworn I was seeing double vision - only in the instrument panel - speed, fuel gauge, etc. The thing is, is it not odd that I just noticed it? Is it likely that this just cropped up after five days of driving, or did I just not see it before?
    I know this issue has been chronicled, but has anyone come up with a fix? I just so happen to be going to the dealer tomorrow for something else and may bring this issue up.
    Also, what is the best way to clean this display - both the part that reflects the actual image and the display itself...
    Thank you!
  2. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    If you close one eye, do you still see two of everything?:p This is the first I heard of this problem. I didn't have the double image problem with the dash instrumentation during the 30 months I had my '10 Prius IV.
  3. slfarooqui
    slfarooqui New Member
    Land O' Lakes, Florida
    Mine is the same way. What did the dealer say?
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I'd be interested in any real suggestions about cleaning the display.
    So far, I've been lucky and my display is clear. But I have treated it with a lot of "fear". It's basically been, I keep hoping it stays clear...and I don't touch it at all because I'm afraid if I do anything I could make it worse.
    If there is a safe and recommended procedure for cleaning the displays...or even things I really DON'T want to do, I would be interested in knowing.
    Right now it's hands off.. and both eyes open.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Just use a microfiber towel to clean it. If you have stuff on it that doesn't not come off, like someone sneezed in there, spray a mist of water on the microfiber and use it. That's about as real as you can get. That's from cleaning them on 5 various prius now over 2 generations and never had an issue except clean displays be it dust removal or removing something on there.
