1. Offline
    cycledrum I like Prius
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    **** www.extendmyseat.com brackets for Gen2 Prius' became available July 2009. Use them for more seat travel instead of this difficult modification ****
    ** Project Completed! Done on used 06 Prius seat from salvage yard. Can slide back 2 5/8" further. Legroom improved! 2 5/8" equivalent to a bit over 4 extra clicks back, using 2 clicks and can comfortably reach the steering wheel. See post #28 for pics of four settings.
    I would do this mod again, totally worth it! Original seat in my house. **
    Project started by purchasing the only used Prius driver's seat w/airbag within 60 miles (San Francisco Bay Area), tough to find, but seat in very good condition. Next, removal of the four mounting feet (removal of rivets, spot welds, must be very careful not to bend seat rails!). Gave drawing to metal shop to fabricate braces for 'extending' rails to front feet. Drill holes in braces, bolt, check fit, tack, then seat professionally TIG welded at metal shop. Sand, paint, grease rails, mount in car, connect, done.
    Easy? Ah, no. This and more took place over 2 weeks in spare time after work.
    PC member nyprius was about first to have this done through a handicapped retrofitter type business. Some have done it themselves also.
    Passenger seat all the way back -
    There are 2 bends in the front braces to leave the rails in same plane as stock. Left rear foot does not allow lifting of front of rails much, or that foot may deform. (when folks put 1 1/2" of washers under front feet to lift for thigh support, seems a possibility of bending left rear foot).
    Seat rails and feet are strong metal as they are pretty tough to drill through.
    http://priuschat.com/forums/prius-m...ving-feet-off-seat-rails-drilling-tricky.html
    I chose a seat remount over height adjuster addition (PCers jelloslug , Solar_Powered did this) because it's easier and more seat travel a top priority (height adjuster mod does not give more legroom as Prius upper seat bottom frame already set 1/4" from fully back)
    http://priuschat.com/forums/prius-m...juster-vs-seat-remount-checking-them-out.html
    Here's a front brace before welding. Technician said gray epoxy 'popped' right off during tack welding. Good. Can see '06 Pri' upside down -
    Notice sanded portion on bottom of rail. This is new location for rear foot. Once rear feet welded, left rear bolt will be 'sandwiched' permanently between mount foot and rail.
    Back mount feet prepped (paint sanded off) and in car. After front mounts loosely bolted in place, lifted rear rails and applied epoxy to set rear mounts in place. Left rear foot fell off during seat removal, but left an imprint to clamp in position for welding (far away from car of course).
    ** Disclaimer - If you should decide to do a modification like this, it is at your own risk. It could damage your vehicle, you could be seriously injured or killed from failure of seat mount. Toyota sells no replacement parts for a Prius driver's seat with airbag, and such seat assemblies cost over $2,500 from Toyota. My modification was done on a 2006 Prius driver's seat with airbag which cost $300 from an auto salvage yard. **
    ** Note - my insurance carrier confirmed the car is still fully covered. A Toyota service advisor looked at the seat mod briefly and said should not be a safety problem long as it's electrically connected which it is. **
    1 people like this.
  2. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    post deleted. project continued post #7
  3. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    Priuschat is a great and valuable resource. I might not have embarked on this project without seeing other's examples too.
    So thanks to Danny and all the other contributors. :rockon:
  4. Offline
    Feb 26, 2007
    7,432
    984
    Carmichael, CA
    Your Vehicle Year:
    Yep, that's the part that sucks about arc welding. I think they have helmets now that automatically darken when you strike the arc. I liked gas welding better because I could actually see what I was doing.
  5. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    Lowe's had an auto darkening helmet for sale - $199 !!
  6. Offline
    Feb 26, 2007
    7,432
    984
    Carmichael, CA
    Your Vehicle Year:
    Kind of pricey unless you are planning to become a pro. They didn't even have those helmets back when I took the welding class in college.
  7. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    Project car
    Epoxy has been drying 11 hrs. so far. Seat should come out with feet exactly where they ought to be ... ready for welding.
  8. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    I had it professionally TIG welded. I'll keep an eye on these welds from time to time, but I doubt they'll ever break. Looks ugly, but sanding, painting makes it all nice again.
    Time to sand, paint, grease the rails and drop it in! Well, after work.
  9. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    I grabbed gloss black in haste other morning, painted. Darn, Satin Black was the paint to get. No big deal.
    Tire screw jack doubles as seat lifter (or should I say lowerer?)
    Got to be inline, no cross-threading allowed! Thread lube helps out. Meanwhile I'm doing gymnastics to get right body position to turn ....
  10. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    ... this handy wrench found laying around.
    And the right bolt lines up too!
    Feet, braces and rails all welded on 3 sides.
  11. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    Time to plug-in the seat, then drive with more legroom!
  12. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Lol -- tool from Ikea furniture?
  13. Offline
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Looks like you're free at last, free at last ....
    1 people like this.
  14. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    I did it! Woohoo!!
    Tom, thanks so much for your suggestions !!
    btw, I don't have any Ikea furniture ... but I do have a motorcycle tool kit around. :)
  15. Offline
    brick New Member
    Dec 10, 2006
    1,033
    53
    Upstate NY
    Your Vehicle Year:
    How is that mod working out in terms of comfort? Is the reach to the steering wheel OK?
  16. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    Before - 90 deg. leg bend
    After - < 90 deg. bend
    I've driven the car several times since Saturday, and it feels so much better to sit and drive in. I was just too darn close to the dash before, legs kinked up to use the pedals. Not anymore:)
    I moved the seatback forward one notch today while retaining same headroom as before the modification. So my reach to the steering wheel is almost as good as before. Reach to steering wheel is not a safety hazard.
    As one wise man said - "I've never heard a tall person complain after getting more legroom"
  17. Offline
    Feb 26, 2007
    7,432
    984
    Carmichael, CA
    Your Vehicle Year:
    Or headroom.
  18. Offline
    Apr 9, 2008
    5,266
    432
    NorCal
    Your Vehicle Year:
    A remounted-Corolla-height-adjustable seat mounted in 04 -09 Prius ...
    breath... would be doable. Lot of work, but doable. (My work plus PCer's jelloslug or Solar_Powered's mod).
    I'm not doing it ! :fear:
  19. Offline
    Feb 26, 2007
    7,432
    984
    Carmichael, CA
    Your Vehicle Year:
    I already lowered my seat by almost an inch at the rear. I was considering making it adjustable, but I'm ok with it now as is and I don't have any money to spend on it now (currently unemployed)
  20. Offline
    brick New Member
    Dec 10, 2006
    1,033
    53
    Upstate NY
    Your Vehicle Year:
    I followed your instructions last summer. It worked wonders for both leg comfort and headroom! A little more leg room would be nice but I don't think it would work out in my case. Unlike cycledrum I would need some telescope on the steering wheel to be comfortable. Different proportions I guess.
Share This Page
