Durability of hatchback struts tied open/down?
Discussion in 'Gen 3 Prius Main Forum' started by j0mb00, Sep 1, 2015.
  1. j0mb00
    j0mb00 Junior Member
    usa
    Hello all, quick question...
    I haven't had to do much work to my 2010 prius, luckily. One thing I had to replace were the original failing hatchback struts. I put new ones in (aftermarket) that are much stronger and harder to close. But my question is...If I were to tie a rope to keep the hatch open, but not fully open (to make it level with the roof) for about 8 hours and 8 hours over 2 days...Does this cause stress to the struts/possibly causing them or more prone to failure?
    sorry, i'm not much of a car person, but I thought I read somewhere about the effect of having struts open, but not completely open...I just wanted to get your opinions. Thanks!
  2. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    I think you are over thinking it... after all, in the closed state, the hatch is keeping the strut cylinders fully compressed. Therefore, keeping them tied off in any other position will put less stress on the seals.
  3. Tideland Prius
    16,016
    I don't think the strut cylinders are fully compressed when closed. There's a point where the hatch will stop holding its position and will just fall to the close position, indicating that the struts are no longer supporting the hatch (i.e. the air is released)
  4. CR94
    CR94 Senior Member
    2,642
    1,133
    Northwestern S.C.
    That behaviour results from the geometry and kinematics of the hatch-strut-body system. It's unlikely that "the air is released," especially since gas struts are filled with nitrogen, as far as I've heard.
    Tideland Prius and xliderider like this.
  5. Tideland Prius
    16,016
    Ahh I see. Thanks!
  6. 348
    348 Junior Member
    71
    36
    Central Oregon
    Correct. Most here are victims of our Public Education system but Pascal's Law s always in force.
    Having been a 4 cyl Toyota owner and a professional aircraft mechanic for almost 30 years I would recommend replacing the struts with the factory part.
