Econ mode at higher speeds?
Discussion in 'Gen 3 Prius Main Forum' started by harper42, Jul 2, 2010.
  1. harper42
    harper42 Member
    226
    Ok, I didn't know what I was doing. I just bought my new 2010 Prius the day before I went on a 300 mile trip out of state. Dealer showed me the eco mode, which sounded like a good idea to me. Drove on the expressway, about 70 mph, decided lots of power was not necessary and I wanted the best mpg so I put the car in Eco mode. Drove great for about 250 miles, then all of a sudden, I began to lose power. Fortunately, I was nearing a rest park. Pulled in, was there long enought to take care a Rest Park business, started back up and car ran fine. BUT I did not use Eco mode. Question: When should I use this mode and when should I not?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If I was your dealer I would have panicked that you were not doing the proper break in for the first 600 miles. (no high speeds and vary speeds frequently)
    Eco mode, however, would not produce the symptoms you had.
    You never need to take it out of Eco.
  3. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Agree w/ JP. ECO mainly just changes the response of the throttle to give finer control in the first 1/2 of throttle movement. PWR does the opposite. Exactly the same amount of power is available in all 3 modes (ECO, Normal, PWR). I run ECO all the time including sustained 70 mph freeways.
    I have no idea what the problem was, but feel it was not ECO.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    My personal experience is to use Eco in town/heavy traffic and leave 'normal' mode on the open road with Power used for overtaking or motorway slip roads.
    The different modes do just affect the throttle response and if you floor it in eco you will get the same power output as power mode. I do find normal more more responsive for open road/highway driving.
    I'd experiment with the different modes and find which works best for you for your own circumstances.
  5. Thai
    Thai Prius Neophyte
    1,197
    89
    x2.
  6. fuzzy1
    10,045
    Mine has not been out of ECO mode in almost 9 months.
  7. Ads_green
    Ads_green New Member
    23
    Oxford, uk
    Also Eco mode runs the aircon and fans at a much lower speed
  8. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    The best answer is when ever you want to use it. You can use any mode you want when ever your want.
  9. G3priusV
    G3priusV Member
    131
    17
    UT
    Harper42, actually similar stalling happened to my prius about a month or two ago but I always drive on PWR mode and it happened at around my 14000 miles. But since then oil changed once and no problems found. Other than that I really didn't have any problem with my prius and love my car so much!
    iPhone ?
  10. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    The ECO mode can be used whenever you want. There are those that never use it because they don't like the response of it, there are those who use it all the time. There are even those who use PWR mode all the time.
    I use ECO mode (and the other modes, actually) like GrumpyCabbie does.
    What you describe though, has nothing to do with the mode and it seems more an issue with the car itself. Did you try to floor the accelerator when you started to lose power to see if it would work again properly, or it is simply waned down? did any warning lights in the dashboard go off?
  11. harper42
    harper42 Member
    226
    THE DEALER NEVER MENTIONED BREAK IN!! Well, mine got broke in the hard way I guess. I do love my Prius. That's why I traded in my 2006, at almost 100,000 miles, for a new one. Dealer said he couldn't give me nearly as much in trade if I waited till it crossed the 100,000 mark.
  12. pakitt
    2,173
    1,311
    Colorado
    The dealer could but he doesn't have to - it is written clearly in the manual...page 151 to be precise. The manual, that is something a user should read, and with the Prius, *must* read, IMO. Many questions in this forum come from people who never took the time to read the manual or even go through it. You buy a 20k$+ "thing" and you don't read the manual?!? ("you" I mean, all those who buy a car, and don't even bother to "look" at the manual).
