Eibach lowering springs installed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by indyV, May 7, 2011.
  1. indyV
    indyV Junior Member
    58
    NorCal
    Hi guys, I got my springs installed yesterday. Here are some before and after shots for those of you interested:
    Before:
    After:
    Before:
    After:
    2 people like this.
  2. 32kcolors
    32kcolors Senior Member
    5,728
    937
    124
    Redondo Beach, CA
    Very nice! Red taillights look good on BP too.
  3. Blueranger
    Blueranger Junior Member
    28
    Albuquerque
    Looks good!
    How many inches was the drop and how is the ride feel?
  4. indyV
    indyV Junior Member
    58
    NorCal
    The drop was 1.2" in the front and 0.8" in the back.
    The ride is definitely has a much tighter feel compared to stock. Lower stance, less body roll. Hard to tell how much the springs alone helped out handling-- I also had a rear sway bar and a front strut tower brace put in within the same week. Overall the car handles much better.
  5. F8L
    19,149
    4,040
    50
    Sacramento, CA.
    2013 Chevy Volt
    Thanks for posting up your results.
    I just purchased a Pro-Kit and KYB struts for my GenII. I'm excited to get rid of excess wheel gap and body roll.
  6. casualvic
    casualvic Junior Member
    48
    Kansas
    I
    I am waiting for my Eibachs and front lower bar (Tanabe) and upper (Tanabe) hopefully I don't wobble in windy weather!!
  7. a1rjumpman23
    a1rjumpman23 Junior Member
    65
    If you dont mind me asking, how much did you pay and where did you buy it? This is exactly what i want for my setup
  8. indyV
    indyV Junior Member
    58
    NorCal
    I got the Eibach pro-kit from tirerack.com for about $230 shipped. They had to special order 'em because they didn't have a set in-stock for the Prius. Someone else posted on here that you can get them for about $200 shipped (unfortunately, mine were already on their way to the shop).
    I got them installed at a local shop for $200.
  9. robby3
    robby3 Member
    181
    23
    Switzerland
    Only 0.8" in the rear ? It looks lower, more like 1.2" in the rear too. I heard that the Eibach indeed are 1.2" drop front and rear even the description says 0.8" Have you measured the height before and after?
    Thanks for the pics :)
  10. indyV
    indyV Junior Member
    58
    NorCal
    No, I forgot to. I should've. Currently the rear sits 650mm (25.6 inches) from the rear bottom-center of the wheel to the rear fender. You can check it with your stock height.
  11. Blueranger
    28
    Albuquerque
    Did you have to do a new alignment after the install?
  12. ocblackpriusii
    ocblackpriusii Junior Member
    77
    OC/So Cal
    Yes, drive 500 miles or so to let the springs "settle" and then get an alignment.
    I got the Eibach Pro-Kit Lowering Springs for $200 shipped from AutoAnything with the use of a 10% off coupon and free shipping (advertised on their site).
    I'll be getting mine installed this week.
