Electric bill up 20% from $120 to $145
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Don C, Apr 13, 2012.
  1. Don C
    Don C New Member
    Newport Beach, CA
    My March SCE bill is $145 up from $120 in Feb. March was the first full month using the Plugin. I avg'ed 25 kwh daily vs. 18 in the previous 2 years.
    I charge the Plugin about 2x per day - once in the day and once at night. I'm in the middle of Tier 4 now which is 29 cents per kwh.
    I declined switching to TOU (discount night electricity) because I want the convenience of charging whenever I want. The TOU day rate is 50 cent kwh.
  2. JimboPalmer
    JimboPalmer Friend to those who want no friends
    9,236
    3,056
    Greenwood MS USA
    I would be interested in knowing where on earth you are, it would make the post more relevant.
    Also as a curiosity, what kind of a plug in car do you have?
  3. cwerdna
    cwerdna Senior Member
    12,484
    2,024
    SF Bay Area, CA
    I think he's talking about Southern California Edison.
    But yes, it would help if EVERYONE at least indicated the state they're in, if they're in the US.
  4. Don C
    Don C New Member
    Newport Beach, CA
    I have a plugin Prius in Newport Beach, CA.
  5. cwerdna
    12,484
    2,024
    SF Bay Area, CA
  6. john1701a
    john1701a Prius Guru
    9,545
    2,626
    Mine actually went down.
    30 kWh less than last month's bill, accounting for 21 nightly recharges.
    It must be the draw from the gas furnace & electric oven having more of an influence than the PHV. When the margin-of-error is greater than total consumption, there isn't much to discuss. It's basically a wash. I wasn't expecting that.
  7. devprius
    devprius /dev/geek
    979
    286
    San Francisco Bay Area, CA
    You shouldn't compare March to February, necessarily. You need to compare March 2011 to March 2012. You should also consider if you used other stuff more in March of this year compared to last year (ran the A/C more, etc).
    Still, 25 dollars a month to charge twice a day is not a terrible increase. If we assume 10 miles per charge, and you charge twice a day 5 days a week, that's 100 miles per week, or about 450 miles per month for 25$. To go 450 miles in a regular Prius would be 9 or 10 gallons of gas, which would be $36 to $40 with gas at $4 a gallon. If if gas drops to $3 a gallon, yer still ahead...
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,479
    Southwest Colorado
    Hi, Don
    I'm interested to hear what energy substitutions or conservation measures you have chosen to avoid high tier rates, and what measures you are considering.
  9. devprius
    devprius /dev/geek
    979
    286
    We have tiered rates in California. They start out at a baseline of somewhere around 11 cents a KWh and go up as you exceed your baseline amount. He's gotten himself up into Tier 4 which means he's exceeding his baseline by a significant amount. When you consider the total bill, he's actually only paying about 19 cents a KWh on average: (145.00 / 25) / 30 = 19.33333
  10. CharlesH
    CharlesH CA HOV Decal #00005
    1,741
    393
    Roseville, CA
    But his (and my) marginal cost for charging the PiP is the Tier 4 = $0.294/KWh rate, which is around $0.92 per charge, assuming 3.1 KWh for a full charge.
    You folks in the Northwest have the advantage of not having to burn fuel for your electricity. But down here, we see that big yellow glowing object in the sky a bit more than you do. :)
    There are a some municipal-owned utilities around here that have significantly lower rates, I understand.
  11. cproaudio
    cproaudio Speedlock Overrider
    2,311
    636
    CA
    base line in California is a freaking joke. it's in mid 300 kW. for PG&E tier 4 tops out at 200% of base line. tier 5 is 200% or over.
  12. Tracksyde
    Tracksyde Member
    1,380
    670
    So Cal
    The baseline actually depends on where you live in Southern Cal. But it is a joke here as well..
    My mother lives in Walnut, CA.. her baseline is somewhere around 715kW per month. I live in the Tustin/Irvine area and my baseline is 235kW, even though my house is probably 4-5 times bigger than my mother's apartment. From what I read, it depends on the homes in the area, how extensively the homes use gas, etc etc. So Cal is divided into zones this way and your baseline depends on your zone.
  13. Vege-Taco
    Vege-Taco Junior Member
    74
    16
    Arizona
    I haven't payed an electric bill since last November... I love solar panels... ;)
  14. crewdog
    crewdog AARPrius User
    325
    107
    Woodstock, GA
    As luck would have it, my electric meter in Woodstock, GA was read the day before I drove my Pip home.
    The EMC here charges 11.8 cents/kwh including taxes and fees.
    I should have an electric bill next week.
    It's been a funny month though; ran the A/C for a few days, ran the heat for a couple of days.
    April '11 was $90 and 758 kwh, last month was 120 and 1059 kwh. peak usage last 12 months was Aug '11 with 1974 kwh for 249.
    there's no tiers available, only "budget billing" with same amount each month based on previous 12 months usage average for the year.
  15. Don C
    Don C New Member
    Newport Beach, CA
    As David pointed out, electricity is cheaper than gas. Last year, I paid about $80 for March. Going forward, I'm expecting about $150/month vs my normal $110/month.
    I'm not planning on changing my lifestyle. If I wanted to reduce my electricity bill, I would stop charging:D. I love the Prius plugin and will continue to charge whenever and as frequent as possible.
    My baseline is 278kWh.
  16. SageBrush
    11,627
    2,479
    Southwest Colorado
    Thanks devPrius. I realized that tiers must be the answer a couple minutes after I posted, and erased that question. Not quick enough :D
  17. SageBrush
    11,627
    2,479
    Southwest Colorado
    You are probably saying that $40 is cheap, and I agree. My point is that you may be able to pay even less than that, and clean up your energy source too.There are lots of ways to decrease electricity use by substitution that do not change lifestyle. I'm in the middle of a couple for our house:
    1.Windows to replace gas heating of the house space
    2. Water heating by gas instead of electric
    Also, depending how many monthly kwh are tier 3 and 4 you may save money with PV or solar water heating.
  18. devprius
    devprius /dev/geek
    979
    286
    Even if I go with the biggest system they can put on my roof (4.94Kw), I still can't eliminate my electric bill. What it will do, however, is drop me out of the 2 top tiers which are both 34 cents a KWh. Between the solar lease and the reduced electric bill, I should save $70 or more a month.
  19. bfd
    bfd Plug-In Perpetuator
    616
    128
    Close to SDSU in the Far Southwest Corner of Calif
    That's pretty much the answer, short of going off the grid completely. If you can drop yourself out of the top-most tiers, you are still paying - in my case SDG&E - but not paying as much. Our lowest bills are always May/June/July, because we don't need AC, don't need heat from natural gas, and don't need as much electricity for lighting. But I am a little concerned about what will happen once it heats up in July-October and how many $600 bills we'll see.
    Solar is still expensive to install, the payback is minimal, and unless you lease the equipment, you own obsolete gear a year after it's installed. Even with government subsidies, it's still quite a lot.
    New Prius or install a Solar array on the roof?
    Maybe after a few "gag me" bills this summer, I will change my tune. Stay tuned, indeed!
  20. Sandiegomom
    Sandiegomom New Member
    109
    28
    San Diego
    I have a 4 bedroom house in San Diego and (pre-PIP) we use 250 kWh/mo max. Usually closer to 200. So it's only a joke if you run lots of computers, TVs, A/C, have older appliances, etc. I have all Energy Star, CFL, no desktop computers, no AC, and we're gone all day (that also makes a big difference).
