Electric Heating Elements for those cold mornings
Discussion in 'Gen 3 Prius Main Forum' started by FireEngineer, May 21, 2009.
  1. FireEngineer
    FireEngineer
    Expand Collapse
    Active Member
    1,246
    119
    SW-Side of Chicago, IL
    The 2010 also has the PTC heating element like the Iconic Prius had. They are located above the heater core. There are 3 different circuit connections going to the PTC element. The PTC element will operate when;
    1) The engine coolant temp is less than 149F (65C) AND
    2) The setting on the climate controls is MAX HOT AND
    3) The outside temperature is less than 50F (10C)
    The climate setting can be any combination of defrost/vent/foot/bi-level.
    Also the output to the heaters is dependent on the available power from the 12 volt converter of the inverter, so when more of the 12 volt output is used by lights, radio, seat heaters, etc. the less heat will be produced from the PTC elements.
    Wayne
  2. markderail
    markderail
    Expand Collapse
    I do 45 mins @ 3200 PSI
    2,260
    158
    Pierrefonds (Montreal) Quebec Canada
    ...but the 2010 recoups waste heat going out the exhaust, making it 20% better for heating in the winter.
    I gave up on my 2006 G2 Prius and use a 500w 'cube' heater connected to the house with an outdoor timer. So for the first 10 mins of driving, I leave the heater of the car off completely.
    Next step is to also add the engine block heater, which I've procrastinated to do. They should offer it at the dealer ALL THE TIME and not just for the hybrids.
  3. a priori
    a priori
    Expand Collapse
    Canonus Curiosus
    3,083
    403
    23
    Chicagoland (West)
    Try going to a Toyota dealership in most of the U.S. and asking for an engine block heater! It is a Toyota Canada part, and the dealerships around here don't even know it is available.
  4. HTMLSpinnr
    HTMLSpinnr
    Expand Collapse
    Moderator
    5,332
    894
    251
    Surprise, AZ (Phoenix)
    MAX HOT can be triggered by the setpoint being substantially higher than ambient. Forcing to MAX HOT shouldn't be required (at least that isn't the case in the current gen).
    In other words, the system is set it and forget it - the PTC's will kick in when needed.
  5. prius2x
    prius2x
    Expand Collapse
    New Member
    50
    Minneapolis, MN
    I'm newer around here, and notice all the abbreviated terms that folks use. Some seem more obvious than others... Can you tell me what "PTC" is?
    Thanks
  6. HTMLSpinnr
    HTMLSpinnr
    Expand Collapse
    Moderator
    5,332
    894
    251
    While the acronym escapes me, it's basically an electric heater within the A/C system to help warm the air somewhat until the engine heat takes over. They're designed to only get "so hot".
  7. FireEngineer
    FireEngineer
    Expand Collapse
    Active Member
    1,246
    119
    PTC stands for Positive Temperature Coefficient. The PTC heater has a PTC element, an aluminum fin and a brass plate attached to one side of the heater core.
    Wayne
  8. diamondlarry
    diamondlarry
    Expand Collapse
    EPA MPG #'s killer
    559
    Elkhart, IN
    Is the block heater for the '10 the same one as it is for an '07?
  9. FireEngineer
    FireEngineer
    Expand Collapse
    Active Member
    1,246
    119
    Yes.
    Wayne
  10. qbee42
    qbee42
    Expand Collapse
    My other car is a boat
    18,040
    2,981
    Northern Michigan
    Positive Temperature Coefficient means that the resistance of the device goes up as its temperature rises. This is true for all normal resistive heaters and incandescent lamps.
    Tom
  11. swich2mac
    swich2mac
    Expand Collapse
    Go Hard or Go Home!
    330
    40
    Franklin, TN
    Why do those of you who have block heaters use them? I mean, what is the real advantage of having to plug-in the heater over night? Especially, if you have a garage? This reminds me of "old school" diesels having to be plugged-in overnight so they would start in the morning! :) Just curious so please don't flame my question!
  12. FireEngineer
    FireEngineer
    Expand Collapse
    Active Member
    1,246
    119
    There are a number of threads discussing the advantages in the Classic and Iconic Prius. The new one is unknown, although from the info seen it will help until the exhaust heat recovery system fully contributes.
    It gets your coolant about 50F above ambient outside temp. Since the Prius uses the coolant as a factor in deciding when to allow full hybrid operation, by starting off warmer you get into full hybrid mode faster. Usually only 3 hour of pre-heat is necessary before starting, more if the ambient is below 20F. Depending on your electric rates it either makes sense or is a wash economically. Environmentally it is a no brainer win-win.
    Wayne
