EMW Juicebox Level 2 Charging Station
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iplug, Dec 5, 2013.
  1. bisco
    48,934
    his first sentence says 'four full four hour charges.'
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I fully charged the Volt four times in four days with the JuiceBox before packing it up. I sold it to a fellow with a Volt who is going to use it daily.
  3. iplug
    iplug Senior Member
    2,447
    1,695
    Rocklin, CA
    Yes, that is why the question. I understand ny_rob did 4 full charges but did not know if he did several other partial charges.
    I'm looking to see if others with the JuiceBox have done at least 30 total charges. If they are having the same problem, there's a good chance it will happen by then.
  4. ny_rob
    1,968
    813
    L.I.- NY
    If it helps- I didn't run my JuiceBox off a GFCI protected 240v outlet...
    The JuiceBox already has built-in GFCI so running it off a GFCI protected circuit can be problematic.
  5. bisco
    48,934
    yes, i do not have my L2 on gfci either.
  6. iplug
    iplug Senior Member
    2,447
    1,695
    Rocklin, CA
    No GFCI on my 240V outlet either. Bisco, do you have the JuiceBox or other open EVSE?
  7. bisco
    48,934
    i have the diy one called 'open evse' that was popular back in the day. (2012):cool:
  8. Camry101
    Camry101 Junior Member
    InAHybridStateOfMind
    The JuiceBox has a program with Ohm Connect to collect utility rebates. Free money.
    Has anybody used it yet?
