Engine hesitation after cold start.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FishHawk, Jan 2, 2012.
  1. FishHawk
    FishHawk New Member
    176
    Anyone experiencing a engine hesitation after a cold start? I've have noticed this and after the engine is warm there is no hesitation.
    Any recommended cures for this condition?
    FishHawk
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Move to a warmer climate, or install a block heater. I suppose you could also heat your garage.
    Seriously, though, the cold engine hesitation is built into the design of the Prius. The top priority for a Prius is low emissions, and heavy use of a cold ICE goes against that. All Prius will rely heavily on the battery for the initial warm-up stage. If you insist with your foot, the Prius will draw power from a cold ICE, but only reluctantly.
    Tom
  3. FishHawk
    FishHawk New Member
    176
    Thanks Tom . Did you see that rock climber on 60 minutes? Amazing.
    FishHawk
