1. Offline
    Allison C New Member
    Start a Conversation
    May 3, 2012
    Lancaster, CA
    Your Vehicle Year:
    My gas engine seems to rev up right before shutting off and transitioning to EV mode. Is this to make sure there is adequate fuel ready for immediate demand when the gas engine starts again? Or does anyone know the reason for this or if it is normal? Thanks.
    minkus likes this.
  2. Offline
    Oldwolf Prius Enthusiast
    Feb 15, 2011
    569
    49
    NC
    Your Vehicle Year:
    My C is always in EV mode when I shut down so I don't even hear the ICE. Are you shutting down with a cold engine or a HV battery in a low state of charge? That might explain what you are hearing.
  3. Offline
    May 3, 2012
    Lancaster, CA
    Your Vehicle Year:
    It's not at shutoff, it's normally when I stop at a traffic light and after a second the ICE shuts off, but before it does it always seems to rev up before it enters EV drive. I think the battery is normally at least 50% charged. I think it probably does the same thing if I am setting in the parking lot, when the battery gets low and the ICE kicks on, it revs higher than you would think (more than a typical gas engine at idle), but it shuts off in a couple minutes once it gets a little more charge. Maybe the ICE charges the hybrid battery more efficiently at a higher engine speed. Not sure...
  4. Offline
    SquallLHeart The Techie Guy
    Mar 10, 2012
    747
    180
    San Jose, CA
    Your Vehicle Year:
    well.. yes.. but most times when i hear the ICE really rev up when i come to a stop is when the ICE is still cold.
  5. Offline
    BrunoPuntzJones Member
    Feb 29, 2012
    100
    24
    Your Vehicle Year:
    Normal for mine. Pull up to red light, engine revs, then shuts off.
    RocMills likes this.
  6. Offline
    chicagoaficionado Junior Member
    Aug 26, 2012
    56
    Chicagoland
    Your Vehicle Year:
    I just noticed the same thing after more than six months of use. I'm assuming its normal? Is there any follow up with this?
    The RPMs rev up right before the car transitions into EV mode when still moving. Any new insight out there?
  7. Offline
    minkus Junior Member
    Jan 4, 2013
    83
    24
    Cleveland, OH
    Your Vehicle Year:
    I've also noticed this, so it seems to be normal. I'll pay more attention to see if it happens more when the engine is cold. Not sure about the reason why.
  8. Online
    MotorcycleGoat Junior Member
    Jan 27, 2013
    49
    23
    Your Vehicle Year:
    I wonder if this is a cut off of the fuel supply. Just a theory, but if the fuel supply is cut to an engine, it will run leaner and leaner until it can't run any more. A lean engine runs hotter and faster...so, that could be what its doing. Cutting the fuel supply as a method of shutting down the ICE and therefore causing a lean condition right before it dies. I experienced this with many a small engine. Lawn mowers, weed whackers and RC cars. Thoughts?
Share This Page
