Engine revving, but no acceleration - Solved
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by er86, Aug 31, 2015.
  1. er86
    er86 Junior Member
    42
    Austin, TX USA
    A couple of miles into my normal drive this morning the car's engine began to rev, but did NOT accelerate. The car did this about 5-6 times on a road at 35 MPH that is mostly flat, with a slight descent where one would expect the car to glide in electric mode if possible. Battery pack was 4 or 5 bars. Each time I shifted into neutral since I was afraid of acceleration and feathered the pedal to see if it was somehow stuck (ignoring for the moment I was using constant pressure on the accelerator while driving). Also looked down at the first red light to verify the silly floor mats were "locked" into position. No "check engine" type lights ever turned on.
    After these events happened the car did NOT stop the engine at the red lights, despite the battery level of 4 to 5 bars. After about 10 minutes of driving the car returned to its normal operation with the engine turning off at the lights and no more revving. After dropping off my passenger I carefully to the dealer who says there is nothing wrong with the car (also said they have never heard of this type of complaint). I only noticed the revving because the engine should have been quiet/off during the stretch of the road and the MPG dropped from where it should be to zero as the engine revved.
    My 2012 Prius has almost 45,000 miles and this is the first time it has ever behaved like this. Have I overlooked others with similar symptoms? (Only found the one posting where someone's intake vent was dirty.)
    Should I be purchasing some type of OBD device to collect data to prove I am not making this up? :cool:
    49,797
    was it hot out? maybe something in the fuel system. did the dealer look for codes? if not, you would need mini vci and old windows laptop.
    #2 bisco, Aug 31, 2015
  3. er86
    er86 Junior Member
    42
    Austin, TX USA
    No, it was not hot out although those of you outside of Texas may disagree. :cool: Below 80 degrees unlike now where it is upper 90s.
    The dealer said they ran full diagnostics and there is no indicate of any issue.
    49,797
    intermittent problems with no lights or codes are troubling. i hope it was a one off!
    might be worth checking your 12 volt, as a precaution.
  5. er86
    er86 Junior Member
    42
    Austin, TX USA
    Well, the issue returned today, but MUCH milder than it was yesterday. I recorded some video and the dealer's chief hybrid tech says the car is behaving normally. The video is very short, but the car was doing this on/off for about 10 minutes as I drove through traffic in less than 80 degree weather mostly flat with a short incline and nice decline... consistently behaving odd. Again, after reaching my destination, which was at the end of a 35 mile zone the engine refused to shutdown. I stepped outside the vehicle, dropped off my passenger and several minutes later the engine still ran for several minutes before returning to normal operation.
    The dealer said the 12 volt battery is good and said they cannot test the hybrid pack. They said the older models of the Prius had issues with the 12 volt, but not the 3rd generation. He said they have to wait for the car to tell us there is a problem and this should happen before I notice anything (passed full diagnostics yesterday). Yet, I have noticed something. 8-( He said it might be a cell that is going bad and the car is actually turning the engine off/on to charge even though the hybrid battery is half-full, but then he said he would deny saying this if I repeated it... I have ordered a 12 volt battery at a non-dealer location and OUCH!
    I tried and failed to get YouTube to process the small video I have (stops at 95% for hours). This site will not let me post a hyperlink, but if you add http to the start of the text below a video should be available:
    skippingpebbles.com/2012Prius-0901.mp4
    dougie likes this.
  6. bisco
    49,797
    unlikely the hybrid battery at that mileage, but not unheard of. testing the cells requires hooking up tech stream and going for a ride. it would probably cost a few hundred dollars, and you'd have to pay if there wasn't a problem. but sop is wait until codes show up, so you can't make them do it. is your inverter fluid moving okay?
  7. er86
    er86 Junior Member
    42
    Austin, TX USA
    Inverter fluid is about 3/4 of the way between L and H when driven over 30 minutes. I will have to see what happens when the car cools. A dealer has done all maintenance since I purchased the vehicle so one would hope they would notice a problem since they see the car every 5000 miles.
    EXPENSIVE 12 volt battery was replaced last night by a non-dealer (the battery was not expected until today). I guess that was not the cause. 8-(
    First Issue returned this morning (revving). A couple miles into driving the same 35 MPH road with a slight slope downhill the engine revved and did not accelerate as I approached the red light. Cyclist must have thought I was nuts with a hybrid roaring at a red light. I continued to my destination, dropped off my passenger and the car did not exhibit any other symptoms than the one occurrence so I shutdown the car when I unloaded my passenger.
    Second issue (gentle up/down as if tapping on accelerator) returned on the return trip after a hard brake due to a cyclist believing he could just walk into traffic. Issue appeared to return 3 or 4 times while driving under 30 MPH - the issue is so subtle you can miss it over the road noise and when in stop and go traffic you cannot rely solely on the MPG gauge.
    Outside temperature under 80 degrees. Hybrid battery pack at 4 to 5 bars. Prior to driving 30 MPH there is one stretch where I reach 45MPH after leaving the neighborhood. So far both issues (or two sides of the same coin) have appeared only in the first 30 minutes of driving each day.
  8. bisco
    49,797
    yes, but with the car 'ready', if you take the cap off the inverter fluid reservoir, it should be swirling/bubbling. id not, the pump is shot.
  9. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Clean battery fan. Seems it must be clogged and thus battery is hot. Just a guess...
    iPhone ?
  10. FuelMiser
    FuelMiser Senior Member
    1,304
    891
    Monument, CO
    does your energy flow display (the one with the arrows) show the battery is charging? does your battery ever get above 4-5 bars? if you turn your climate control off, does anything change? this is not a conventional drivetrain. the throttle is not connected to the gas engine. the computer decides when to activate the gas engine. your right foot only gets one vote.
  11. Mendel Leisk
    38,953
    Our previous Civic Hybrid had one serious high revving incident, and a few less severe ones. In the worst case, we were stopped at a red, engine did not auto-stop, started climbing, got over 3000 rpm. I stayed in Drive, and kinda stood on the brake. As soon as we got rolling with green light rpm fell off, went back to normal
    I put it down to a bug in the computer controlled, drive-by-wire system. Never did find out for sure.
  12. PriusInParadise
    180
    91
    Hawaii
    Another possibility is the hybrid battery is running hot.
    The vehicle will attempt to protect it by using the engine to generate electricity instead of charging/discharging the hybrid battery.
    Make sure nothing is blocking the air intake vent for the hybrid battery cooling fan.
    This is the grill on the right side of the rear seat back.
    There may be debris in the air duct or cooling fan. Do you carry shedding pets?
  13. er86
    er86 Junior Member
    42
    Austin, TX USA
    After living with this issue for 8 days, on day 9 the car failed in spectacular fashion! On day 9 as I approached red lights on the same route the engine did not rev, but appeared to shake violently. At red light number 3 the "check engine" light, "triangle" light and a message about the hybrid system failing and to pull the car over when safe. About a mile into this condition the car turned off without any warning. Luckily, I waited a few minutes and was able to reboot the car to continue to the dealership.
    Hybrid tech at dealership said the code was one related to the engine failing to start. Paperwork shows codes 3191 and 171. They replaced a vacuum valve assembly, part number 25860-37020 at no cost to me and provided me a rental from Enterprise for two days as the part was not expected for 4 days (I assume Toyota America reimburses the dealership). I was verbally told the part is $85 and from when I dropped the car off the tech skimmed the tech article which also mentioned updating some firmware when replacing the part. I have no idea what the repair would have cost was it not part of the car's basic warranty.
    Brian Hurst likes this.
  14. bisco
    49,797
    congrats, thanks for reporting back!(y)
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    Thats the purge valve for vapor canister. Fume recovery for the gas tank. Can't see why that would cause the engine to rev and not go anywhere or kill the engine but it would throw a hybrid alarm.
    In the Gen 2 world any issues with emissions systems at the gas tank were sometimes caused by people who continually top off the gas tank upon fueling and over fill the tank causing gas to spill out the fill hole and into the recovery bladder which contaminated the system.
  16. 88skisupreme
    88skisupreme Junior Member
    Austin, Texas
    My wife just complained of the engine revving in our 2012, took a test drive and noticed it once myself. Also noticed how loud the cooling fan in the back seat was! Thanks to this thread I have a fan cleaning chore this weekend. Thanks guys, hopefully this fixes it, the maintenance warranty just expired....
  17. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    How does one clean the fan? Dealer said they have to dismantle the reat seat and it would cost upwards of $300.
  18. Mendel Leisk
    38,953
    You can DIY in about an hour. You do not need to remove rear seat: there's one bolt that needs to be removed, just below the vent in the rear seat back. It's just below the seat back grill, on passenger side. You can access it by pushing apart the seat back and seat, reaching through with a ratchet with extensions (maybe a 6" and 3") and a 12 mm socket (IIRC). Use a light too, to see where you're going. Sneak a hand in too, to grab the bolt when it comes off, you don't want to drop it.
    Watch too, the @NutzAboutBolts video, pinned at top of 3rd gen maintenance forum. They DO remove the seat, but yeah it's not really necessary. The video shows all the steps. You need to pry the hatch deck off the the top of the hybrid battery, pull back carpetting, remove that seat back grill, some plastic conduits. All in all not too hard.
    I found you can clean the fan without complete removal too. Also I run a dusting boa through all the plastic conduits. And blow everything out with a leaf blower (redneck compressed air). Or my shop vac on blow.
    #18 Mendel Leisk, Aug 20, 2019
    NutzAboutBolts and Robert Holt like this.
  19. 88skisupreme
    Austin, Texas
    Cleaned mine out and it seems to have done the trick, no more phantom acceleration.
    Grit likes this.
