Engine won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hamilton Keogan, Mar 26, 2011.
  1. Hamilton Keogan
    Hamilton Keogan New Member
    I have a 2005 Prius. This morning the engine would not start. The lights came on for about a minute, then flickered, then went dead. I did not leave the fob in the car overnight or the lights on or the door opened, so I'm not sure if the battery could have drained.
    About 15 minutes before this happened my husand opened the back hatch by opening a door and pressing the "open" button. He did not have his fob and wonders if he somehow triggered a security mechanism that shut the car down?
  2. uart
    uart Senior Member
    4,215
    1,200
    Australia
    What did you do during that minute. Was the car in "ready" mode? Did you drive it? Or something else.
    Maybe the battery was weak and the hatch light or door light on for 15 minutes was enough to finish it. It's hard to know unless we have more information about what happened in the minute prior to going dead.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Most likely it's a dead 12V battery. When was it last replaced?
    Tom
  4. richard schumacher
    7,663
    1,038
    United States
  5. Calliber
    Calliber New Member
    Uk
    Hello i have problems with toyota prius 2005 1.5 its wont start up when press brake and start button its just show on dashboard all lights and triangle and nothing else i change battery in new one but its not help the same on the screen whrite only problem nothing more maybe somebody have this problem before and know how to fix it . the same as in video.
    #5 Calliber, Mar 1, 2016
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    When you say you changed the battery, do you mean the 12v battery or the big hybrid battery?
  7. Calliber
    Calliber New Member
    Uk
    I mean 12v battery Some people say that need to change hybrid inverter or relays but where i can find it and how can check it ? How can check brake pedal sensor maybe its not working?
  8. Patrick Wong
    18,199
    6,464
    You need to get Mini VCI so that you can read any logged DTC.
    While you are waiting to get that, put the 12V battery on a charger to make sure it is fully-charged before you continue troubleshooting.
    Press hard on the brake pedal when you are trying to start the car. I noticed the READY light flickering a few times in your video, so the brake light sensor is probably working OK.
    It is premature for you to be talking about replacing parts like the inverter or the system main relays, lacking any clue about what is actually wrong with your car. That is why you need to retrieve the DTC.
    You can obtain factory service manual info at the Toyota Europe techinfo site, once you know what the DTC are:
    Toyota Service Information
  9. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    Agreed. You need to get the codes read.
    The car's diagnostic code(s) will help pinpoint the problem.
  10. Calliber
    Calliber New Member
    Uk
    Ok thanks guys now im looking who can come to my home to do it later when i know fault code whrite here thanks anyway now for help I try this to press hard edal and start its not help
  11. Calliber
    Calliber New Member
    Uk
    Hi read faults its P0A0D high voltage system interlock circuit high . maybe somebody have this fault before?
  12. Patrick Wong
    18,199
    6,464
    The problem is that your interlock switch is not correctly installed.
  13. Calliber
    Calliber New Member
    Uk
    I found problem the main power fuse was blow off 125a . maybe somebovdy know where can buy this fuse ??
    #13 Calliber, Mar 4, 2016
  14. Patrick Wong
    18,199
    6,464
    Your local Toyota dealer. An electronics supply house.
  15. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    Or you might be able to get an entire service plug from a scrap yard or used parts reseller.
    I see used ones on ebay for $20 - $30
    search for: prius battery plug
  16. Calliber
    Calliber New Member
    Uk
  17. Patrick Wong
    18,199
    6,464
    Yes
    Of course, the question is why the fuse was blown. It is not easy to make that happen.
    So it is a good idea that you are going to get Mini VCI as you will probably need that to retrieve the DTC again after you install a new fuse and it blows.
  18. Calliber
    Calliber New Member
    Uk
    Thanks guys i found fuse now waiting while send it to me :) thanks for help
