Enginer 2010 PHEV Technical Information
Discussion in 'Gen 3 Prius Accessories and Modifications' started by atfsi, Aug 31, 2009.
  1. atfsi
    atfsi New Member
    91
    96
    47
    I don't think Medusa is going out of business...just not selling direct. I got mine from one of the model aircraft supply houses.
    The 2 red wires are just for the + side of the power pack. They are connected to the same place...so I just cut one of them off. The black wires are connected in series with the shunt. I replaced the #10 wires with #6 and added an Anderson connector.
    The other option would have been to remove the shunt from the board and move the display to the front of the car.
    The hardest part was de-soldering the display from the board to access the shunt.
    The software is easy to use, logs the data, and the display can be customized by selecting from menus.
    I've ordered 2 of the thermocouples (?) to add battery temperature.
    2 people like this.
  2. atfsi
    atfsi New Member
    91
    96
    47
    Just heard from Jack...the GenIII case is on it's way....I'll be posting the install photos when it gets here....
    Jack B
  3. atfsi
    atfsi New Member
    91
    96
    47
    Progress ! Finally used the monitor to get a discharge curve for the Mottcells. The result is surprising. It looks like the charge and discharge voltages are too low. The chart shows the average discharge curve for a balanced (low) set (16 cells) of 40AHr Mottcells. The vertical lines are the open (no load) voltages at those points. Ooops...the horizontal axis is AmpHrs.
    3 people like this.
  4. atfsi
    atfsi New Member
    91
    96
    47
    Next step....charge curve of Volts/cell vs Amp Hours for the same 16 cells. The vertical lines are again the open circuit voltages. Note the constant current then constant voltage type of behavior.
    When I checked the cells after the initial discharge and sitting overnight, they were in better balance than I started with !
    I'm going to do another discharge curve then balance the second string of batteries. Finally, I'll do the same thing w/ the full 4KWH pack of Mottcells.
    The discharge is done w/ a nominal 2.5 ohm nichrome resistor.
    3 people like this.
  5. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Argh, I want to do this, and it's so cheap. I just worry about the warranty on my brand new car.
  6. atfsi
    atfsi New Member
    91
    96
    47
    This discharge curve completes a full cycle starting w/ the discharge to 46V (pack voltage cutoff for the DC/DC converter), charging w/ the Enginer charger (~35AH) and discharging again to 46V (~32AH) If the cells are in great balance again tomorrow I'll be getting rather enthusiastic about this balance low business.
    PS: The new case is due here Nov. 30......
  7. atfsi
    atfsi New Member
    91
    96
    47
    Here's a shot of the installation the new case for the 2010 Prius.
    The "x"ed out areas are pieces I removed for my first attempt at a fit w/o cutting any of the Prius plastic. It fit, but wasn't really centered. Jack suggested cutting back the plastic exhaust vent. I cut it back 1.5" and thinks fit ok. You want to note that the hold down for the wire harness had to be removed and I will have to put some sort of pad there to keep that harness from chaffing against the case.
    I also cut away the forward leg of the 12v battery cover to give more room for the muffin fan exhaust out of the case. It only supports that very small area.
  8. atfsi
    atfsi New Member
    91
    96
    47
    OK, here's the way I installed the prototype 2010 case.
    I decided that the nut plates that came w/ the case would be tough to get into the support beams from the inside so instead I used KLIK Rivet Nuts that I had on hand.
    Two problems, the sheet metal is not thick enough for the grip range on these nuts and the metal can flex around a hole of that size. The cure to both of these was to add 2 fender washers under each nut (and drill a 1/2" hole instead of 17/32 and drive the inserts in w/ a hammer)
    To set these inserts, I use my homebrew setup....
    I use a socket head bolt with a heavy nut and 2 spacer washers ..... lubricate w/ grease ......this picture doesn't show the fender washers.
    Installing looks like this......
    Notice that there are 3 torque arms in this picture: the allen wrench to hold the bolt from turning, the wrench w/ a pipe on it to tighten the nut and draw the insert into the locked position, and another arm (I used one of the mounting rails) which keeps the nut from turning the insert while you are setting it.
    Here's the right hand anchors as installed....
    Here's the right hand rail bolted in position. Note the bent up flap to clear the 12V battery tie-down mount.
    The left side inserts installed....
    The left mounting rail (adjustable) bolted in w/ more fender washers ...
    AND it all fits !
    2 people like this.
  9. atfsi
    atfsi New Member
    91
    96
    47
    Here's a shot of the "buddy" cell setup. The Anderson connectors are for testing and balancing, NOT the main current flow. This cell is a left-handed setup. I'll use 4 right and 4 left to minimize the length of the high current wiring.
  10. atfsi
    atfsi New Member
    91
    96
    47
    The full set... (note the 5 temporary "straps")
  11. atfsi
    atfsi New Member
    91
    96
    47
    Made up some permanent straps (Jack is out of them) to replace the temporary ones. Made from scraps of 0.065" copper electrical buss strap.
    2 people like this.
  12. atfsi
    atfsi New Member
    91
    96
    47
    Playing the initial balancing game.....
    3 people like this.
  13. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Jack,
    How many amps is that pulling?? I have a H7 halogen stuck on mine pulling some 4amps. 2 amps at 3.3volts.
    Chan
  14. atfsi
    atfsi New Member
    91
    96
    47
    That's 0.4 ohms..or ~15 amps on a 6 volt "battery". (~7.5A on the 3 volt parallel cells)
    The load I use on the whole 48V pack is ~ 2.5 ohms or ~19 amps.
  15. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Nice. What I did was put 32 cells in parallel and put 5 H7 halogen (about 10 amps) in parallel to the pack and am letting the cells discharge to about 3.0V. It has taken some 4 days but it is almost there. I wish I could draw more amps to speed this up but those are the only discharge devices I could find. I have 4 KWH that I let sit this way for a week and now they all charge and discharge together very well on the 2 cell buddy system. I plan to put my 8KWh in a 4 cell buddy system. That should really help to reduce the balance issues.
    Thanks,
    Chan
  16. atfsi
    atfsi New Member
    91
    96
    47
    That's what I should have done, but I already had a well balanced 2KWH string...it took 4 days anyway.....with a little luck it will be back in the car this weekend, or at least given a full bench cycle.
  17. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Although you are right. It is a game we are playing... hahaha..:D
    Balancing these cells seems to be an art form. But just wondering where did you get those rivet bults. I still have not mount my box yet and really want to use your method. Also where did you get those nice anderson plugs for your pack?
  18. atfsi
    atfsi New Member
    91
    96
    47
    I get virtually everything on EBay.............
  19. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Atfsi,
    I have really appreciated your thread with all the technical details. I am planing to install into my 2010 soon. Jack said the kit will be sent Monday.
    Have not heard from you for a while. How is your project going? Did you get the buddy cells up and running. Does it work better? Are you using 2 balancers or all 4? I think Jack is planning to run this in all new kits so It is important for us to know the positive and negative impact of this change.
    I assume the pack is easier to balance. Howerver I expect that a weak cell could be hidden. How would you know if you have a weak cell buddied with a stronger cell? Or do you beleive that the buddying prevents having weak cells?
    Thanks,
    Dan
  20. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Dan2l,
    From what I have seen in my buddy cell set, the weak cell will still show it self. You still need to be alert to the low voltage alarm. It just doesn't bring down the entire string as fast. I found 2 more weak cells in my string but was able to turn off the system before the entire string was stressed also. The good cell in the system can keep the system running but not for very long. What I have done this morning is to put two balancers to each buddy cell and see if that will help to balance the string faster. I have enough balancers right now.
