Enginer 4Kw PHEV DIY install
Discussion in 'Prius PHEV Plug-In Modifications' started by NortTexSalv04Prius, Feb 11, 2012.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    is this english "stud"
  2. NortTexSalv04Prius
    915
    114
    Final thoughts
    I never thought this thread would go "negative" so fast. I want to thank "Jack" with "Enginer" for his post. I have no personal interest in the success or failure of any PHEV "supplier" or "conversion" corporate group. I am sure every1 is famliar with phev eaa and calcars and their knowledge base and would behove some of us to "study" that before making some fairly obvious or just plain negative posts.
    Enginer attracts the end user with both cost and simplicity with some drawbacks. Plug in Supply attracts end users as well with drawbacks. For me these two (Enginer or PIS) would be my choice. The 4KW Enginer kit has been shown on both Gen 1 and 2 Prius to have achieved success(three examples) IMHO
    Plug in Supply 10KW as well IMHO.
  3. Flying White Dutchman
    4,374
    313
    topics only get negative if people respond neg. on post that seem or are negative because that causes the negativity to prolong.
    so just don't take it to harch
  4. usnavystgc
    3,159
    988
    Tucson, AZ
    Yes, let's try to stay positive. I like positive.
  5. mrbigh
    3,686
    699
    Long Island, NY
    My apologies to the readers for the misspelled word, I hate typing on my cellular phone with auto word insertion.
    My expression meant to be " stand" behind their product.
    NortTexSalv04Prius, for being a newbie, you are coming to strong to the board.
  6. pjc
    pjc Member
    139
    46
    Bloomington, MN
    Going back to the original question (how hard is it to install Enginer kit DIY): I have had a positive experience doing it myself. That being said, I didn't buy the kit directly from Enginer, but rather through a local installer, who bench tested it for me to make sure (presumably, they didn't itemize exactly what they did) all the components were working properly. I suspect they did some of the aforementioned "calibration" work, too. I took the kit home, disassembled the car interior and put the whole thing in myself with the help of a (very non-technical) buddy. I do have a technical background so I wasn't intimidated by HV, voltmeters, or soldering irons. The installer also gave me some additional pointers on how to start up the pack and make sure it was working correctly. They were great.
    It probably took me 12 hours or so total (mostly just my own labor, buddy helped mainly only with the heavy lifting), including install of EV button, tachometer (my add-on based on Hobbit's directions -- involves same ECU area) and scangauge. I'd say at least 4 of those hours were the EV button install. The hardest parts were the pulling and prying at plastic trim while not breaking too many plastic fasteners. If you've done any work on your dash already, it will be easier.
    I've been running for 2+ weeks now with only 1 triangle of death (not a big deal if you have a scangauge!)
    Much to my pleasant surprise, it worked right off the bat, no issues. Saved some $$$. Plus, it was fun. :rockon:
    2 people like this.
  7. Flying White Dutchman
    4,374
    313
    what was the dtc / cause of that dead traingle?
  8. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    I am in the semiconductor business. And, of course everything fails with time. Even granite.
  9. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    I am not aware of PIS having any drawbacks. What drawbacks are you referring to?
  10. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    Are you talking about 3 per million in manufacturer's defect caught at the factory? or 3 per million in real world operation? You just said everything fails with time so that means the semiconductors in your business has a much higher failure rate than 3 per mil.
  11. mrbigh
    3,686
    699
    Long Island, NY
    I imagine at manufacturer's production level.
  12. bisco
    48,985
    without both positive AND negative, we wouldn't even be having this discussion!:shocked: (sorry, couldn't resist.:p)
  13. pjc
    pjc Member
    139
    46
    Bloomington, MN
    Flying White Dutchman,
    My red triangle was a P0000 code (which I gather is caused by when the current from the Enginer pack to the OEM battery is too high and the Prius freaks out). I was stomping on the accelerator pretty hard at the time while the SOC was low.
  14. Flying White Dutchman
    4,374
    313
    thats a funny code 0000 is it real?
  15. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Dutch,
    0000 is the "other" code. This is what you get when the computer does not know what code to give. So P0000 is "Powersystem Other".
    Thanks,
    Dan
    2 people like this.
  16. Flying White Dutchman
    4,374
    313
    never got that one
    funny ;-) a DTC design toyota did not think about.
  17. NortTexSalv04Prius
    915
    114
    The DTC code 0000 I have gotten this code on my vehicle too. My first thoughts where what is the meaning and more important what would the code mean to a qualified toyota hybrid "mech" or "tech".
    In my case I had other codes and componet failures and the 0000 end up being of no significant interpretation.
  18. NortTexSalv04Prius
    915
    114
    Yes is real if you have real scangauge..
  19. chenyj
    chenyj Member
    96
    115
    Troy, Michigan
    When getting DTC with Enginer kit in Gen 2 Prius, it is most likely the traction battery is drained too low in EV mode or the converter output exceeds 15A. The converter current can be adjusted downward to prevent over current DTC.
    2 people like this.
  20. fjpod
    fjpod Member
    419
    72
    New York
    on a positive note...electrons are very negative.
