Enginer PHEV kits for PRC Prius
Discussion in 'Prius PHEV Plug-In Modifications' started by Huibin, Jan 10, 2010.
  1. Huibin
    Huibin Junior Member
    Beiijing
    I've purchased the 4kwh version last week, hopefully the kit can be arrived next week.
    Now, I have few questions as follows:
    1. As the EV button is default configure for PRC Prius, so do I need to remove the EV button and install switch on-off button, or I can just install switch on-off button beside the EV button?
    2. As there are no authorized installer in China, so I need to install it by myself, so could anyone recommend some pics or videos during the installation? ps, youtube.com is banned in China so I can not access it.
    3. For the first one or two charges, do I just plug-in overnight and then turn off in the morning or I need to check the battery (balancer)? I only have private parking area with power supply (public parking zone).
    4. More questions may raise during the installation as the PRC version is a little bit difference between the US and Europe version.
    Thanks in advance!
    Huibin
  2. Daox
    Daox Member
    196
    58
    US, Wisconsin
    Hello Huibin,
    I too had an EV button already. I just wired up their switch in addition to it. I just didn't hook up the EV pin switch.
    All the videos I"m aware of are on youtube. Sorry.
    Charging must be monitored right now as there is no automatic shut off if one cell's voltage gets too high. You need to attend to it as it nears the end of the cycle.
    Post your additional questions here and we'll try to answer what we can.
  3. dan2l
    dan2l 2014 Prius v wagon
    654
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Doax,
    Ben has the origonal files for your videos. Could Ben just attach the origonal file to an Email to Huibin?
    By the way thanks for you help on the links.
    Thanks again,
    Dan
  4. Daox
    Daox Member
    196
    58
    US, Wisconsin
    That is definitely doable. However, my videos really don't show me doing a ton. I'll message Ben though.
  5. olov
    olov New Member
    Linköping, Sweden
    You normally get a CD with the kit having the movie and manuals. I also have a car with EV button so I got the IGN/Ready signal from a yellow cable going in to a medium-small white connector near the HV battery/controller and the GND from chassis by that avoiding the trouble and pain required to rip the glove box apart for no use, you only need to run 1 cable along the phone cable to the toggle switch in the panel. You need to make that cable extension. I had the pack cycled some times before installing using 220 halogen lamps as load. Now I run it for a few days and can go btw. home and work EV only and that was my target. I have so far not run the battery down to red light in the car. When charging it´s switch off as a cell goes off in hi voltage and some others are lagging, they are balanced to 3.35 V over night, you may need 40-50 cycles before they work together. Have fun with your plugin. Olov
  6. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    Hi Olov –
    Can you elaborate on your comment - “you may need 40-50 cycles before they work together.†Does that mean you need to charge the pack 40-50 times before it is well balanced?
    Paul
  7. olov
    olov New Member
    Linköping, Sweden
    Yes that´s what the guy that imported the kit I have told me. His first engineer kit he cycled the pack 10+ times before installing in the car and that was the finding that it took about that many full cycles for that pack to balance finally. I will rarely do full cycles so I don´t know if that will take more or less cycles then. On the engineer board there is a discussion on charging weak cells extra. If you have a 4k pack in buddy cell config it´s actually 6 cells in parallel for each cell monitored as each mott cell is built from 3 cells inside so it´s a total of 96 cells so the options for cell variation is endless. Olov
