Enginer PHEV Technical Information
Discussion in 'Prius PHEV Plug-In Modifications' started by krousdb, Aug 13, 2009.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
    I tripped some codes again. Cleared them this time by disconnecting the negative lead on the 12V battery.
  2. Fibb222
    Fibb222 New Member
    1,499
    99
    Oh and Jack is sending me a 16 cell balancer! Whoo!
  3. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I have just received today my 4kwh kit from Jack and I have to say I am very glad to have the 16 cell balancer, I have connected everything up and on my first charge and already 0.06v between highest and lowest cells. Can't wait to have it up and running. I hope yours works as well ;)
  4. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Ah, cool, another UK owner! be interested in how you get on.
  5. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I'll let you know, I will be fitting it next weekend :)
  6. Flaninacupboard
    1,297
    213
    Midlands - UK
    Well i hope you get some better weather, at least when i installed at -3 in december it was dry!
  7. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    All installed and all went well, but the next day I did get a couple of glitches including a red dash triangle but no codes on the scan-gauge and I am convinced it is due to harmonic noise from the inverter, this also makes radio reception erratic. I have rewired the ferrite which helped but I have another idea I will post on if works.
  8. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    Quick update for all interested, the red light turned out to be due to me installing the kit with brackets insulated with rubber pads and not being earthed properly. If you don't bolt down, install an extra earth strap and make sure your brackets could hold the kit down in the case of an accident.
  9. rwiggins951
    rwiggins951 Junior Member
    Cleveland OH
    So, I recall seeing that Lithium Ion batteries should not be charged when they are below something like 35 degrees Fahrenheit. (I am not 100% clear on the temperature, but it was not a number that was all that unusual during Cleveland winters)
    What are folks doing to charge their Engineer PHEV equipped cars in the winter time?
    I haven't seen mention of this, so there must be a simple option. (I do not currently have a heated garage space for my C).
    Thanks!
    Rod
  10. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    I can't speak for other Enginer users, but for me, I had two options:
    1. Remove the batteries during the dead of winter since they weren't usable at those temps and were just plain dead weight, or
    2. Since I had room in the battery case (2KWH unit), I put two 40W lightbulbs in there and plugged them in each night. this kept the battery pack warm enough to be able to charge and use.
