1. Offline
    kammssss Member
    Start a Conversation
    Mar 30, 2007
    201
    45
    Hey Everyone,
    I got about 176-180 charges on my kit. It still works, but I think the battery is already reached its maximum charging cycle. I checked the batteries individually, and they seem to be find, registering 3 volts or higher. I did it twice to double check--might do it again a third time. So, how many charges do you have on your kit before the battery faded? Thanks.
  2. Offline
    ericbecky Active Member
    Mar 12, 2004
    843
    237
    Madison, Wisconsin
    Your Vehicle Year:
    What are the exact voltage of the cells after a full charge and a resting period (so the cells can settle).
  3. Offline
    Floyd2 progressio per sententia
    Aug 23, 2009
    106
    23
    Netherlands, Europe
    Your Vehicle Year:
    Today was a hot day (for our climate) and it turned out this place was the warmest of Europe with 28°C (82 F).
    To my surprise I was able to drive a stretch of 40.6 km (~25 miles) at an amazing 1.0 L/100km (214 mpg or higher) in normal blended mode but I did only drive at speeds of 50 km/h or less and did not use the AC.
    It seems that with high temperatures the current flow out of the batteries a lot more easy. I forgot to insert the SD card so I don't know what the average or highest current was but no DTC.
    I still have not attached the hose on the converter yet, but I better not wait any longer if the weather stays like this. Do I have to lead it out of the car or just away from the enclosure.? I also wonder if additional airflow (extra fans) are needed with these temps. In our climate these temperatures usually only last for a week or three to four a year but since it's so early in the season it could get a hot summer.
  4. Offline
    stefano5777 New Member
    Mar 15, 2011
    380
    46
    St. Petersburg Florida
    Your Vehicle Year:
    You need to flow the hose out of the car. And in warmer weather the kit needs more cooling than kit comes with .90 deg F here today I made some mods to air venting of my kit today that turned out to be a failure :mad: case temp reached 116 deg F. Ill have to go back to the drawing boards !
  5. Offline
    Aug 23, 2009
    106
    23
    Netherlands, Europe
    Your Vehicle Year:
    I'll fix the hose first thing tomorrow. When you figured out how extra fans should be place please let me know.
    I had the car parked in a cool garage before taking off, and parked in the shade before the return trip. I guess I was really lucky today... :)
Share This Page
