Entune update 3.1.0
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mark_amdg, Nov 14, 2013.
  1. virtualy
    virtualy Junior Member
    34
    NorCal
    2014 Prius Plug-in
    I see. Since that's exactly what I have, I'll rest easy.
    Thanks.
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    If you want to see everything that has ever been done to your car at any Toyota dealer, just go to Toyota's web site sign in as owner and search your history! It's all there.
  3. virtualy
    34
    NorCal
    2014 Prius Plug-in
    Thanks! Just visited the site. Unfortunately, there's nothing to see because I've done no maintenance. Was hoping to see when the car was manufactured, where it had spent its life...
    Should be useful in the future though. Much obliged.
    retired4999 likes this.
  4. mikenancy1
    mikenancy1 2012 PiP (Base), '10 Highlander Hybrid, '05 Prius
    105
    Geneva, IL
    Does the 3.2 update do anything to bring the maps up to date? I still rely on Waze at times because some of the maps on my PiP GPS are outdated.
  5. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    ^ Nope, 3.2 does nothing to update navigation maps. But it may give back the ability for the nav system to tell you what side of the street your destination is on. Depends on what version you are currently running on the vehicle's head unit. Check out post #74 of this thread for an idea of what the Entune updates can help you with.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Maps are always a (highly) chargeable update.
  7. CharlesH
    2,783
    1,151
    Roseville, CA
    The map software and the map data are two different things. The map software updates (such as these Entune updates) are free. The map data updates are $$$.
  8. mikenancy1
    105
    Geneva, IL
    Darn! It's the updated map I really need. Several years ago I got an update for the map on our 2005 Camry GPS cheaply when someone on Ebay copied the Toyota disk, but I'm most seeing anyone doing that for this version.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I believe there's a lot more security on map updates for the newer cars, and you need a code from Toyota even if you have the media. See this post for more info:
    Map Updates | PriusChat
  10. Seano
    Seano New Member
    Greenfield, MA
    Any chance you can share that file again, maybe privately? The link is broken, and the dealers around me either don't know Entune can be updated, or they want to charge $98 to do it.
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
  12. Markee
    Markee Member
    325
    50
    South Florida Broward County
    I'm confused Can someone explain if its possible for me to update with the particular system below I have on my 2013 level 4 and how to do it ?
  13. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Markee, nope. You don't have the Entune unit. Yours is the DVD based system with bigger LCD screen.
  14. Markee
    Markee Member
    325
    50
    The screen on my unit is only 6.1 inch It has Entune apps on it I don't get it
    Are you saying it updates from DVD like my older 2010 level 3 ?
    The older level 3 didn't have any Entune apps on it
  15. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Hmm.. Perhaps UI was updated in 2014 and up. I am not familar.
    Someone else will need to chime in.
  16. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Entune is worthless. And now that the 3-year subscription through Sirius-XM is over for most early buyers, traffic mapping won't even work unless you cough of more money to Sirius-XM.
    This was a piece of crap from the get-go. The inability to use a cellular signal for anything other than the Entune Apps - particularly when they don't include a traffic app - is simply mind-boggling. This is my last Toyoter, that's for sure - for far more than this reason. Count me as a particularly dissatisfied customer.
  17. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    This update is not applicable to you.
    Traffic works through the Entune app on my smartphone for free and not Sirius. It's functioning fine. I do agree with you that Entune is worthless.
  18. CharlesH
    2,783
    1,151
    Roseville, CA
    In the 2014 model year, Toyota switched around the head units. Now, depending on which Toyota model you have, there are different combinations available. The display size is no longer a differentiator. This is what confused me when I followed the thread I mentioned in an earlier post. Some get the Entune apps, some don't. Some are HDD based, some flash, some DVD. Some get traffic info over the user's smartphone Internet connection, some from XM Data, some from HD Data. You have to know the specific model and model year, to know what is available on that particular configuration. By specific model, I don't just mean "Prius". The various trim lines on the non-PIP Prius have different options, and the PiP has it's own set of options.
    Very confusing. :unsure:
    #238 CharlesH, Jun 18, 2015
  19. Markee
    Markee Member
    325
    50
    I have Model ID: 11TSANNA-AZ01 ??????
  20. bfd
    659
    172
    Maybe you could detail how you're doing this. I have 12 options in Entune and none of them are a traffic app, and "Traffic Incidents" needs an "Active XM Subscription".
    Another question, do you have a Base or Advanced PiP? I have a feeling you might have a Base model. And that would make this even more infuriating…
    lensovet likes this.
