Entunes 2014
Discussion in 'Gen 3 Prius Audio and Electronics' started by edsandri, Jul 9, 2014.
  1. edsandri
    edsandri Junior Member
    Gaylord, Michigan
    I have a new 2014 Prius and can't get such apps as Bing and weather working using Bluetooth. Help.
  2. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    What phone are you using?
  3. prizzy
    prizzy New Member
    17
    dallas, tx
    did you download entune app to your phone?
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,605
    4,461
    Texas Hill Country
    IPhones usually have to be connected via USB unless you have a phone with a hotspot then they may work. Androids are no problem with Bluetooth. Apparently an Apple issue or restriction.
  5. Goin2drt
    Goin2drt Junior Member
    Yorba Linda
    Same issue here with my iPhone. Works fine when plugged it, not so much when only via BT.
  6. edsandri
    Gaylord, Michigan
    5s
  7. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    As noted above, unless you have a mobile hotspot set up on the phone the Entune car apps will only work with the phone connected to the USB port.
  8. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Just to clarify, my iPhone 5 works wirelessly with my 2012 AT (JBL nav) PIP, so I assume this is only an issue with the lower level systems.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    That's correct; it's only the Display Audio Entune systems that need iPhones plugged in.
  10. Gary2360
    Gary2360 Junior Member
    Tallahassee FL
    2022 Prius
    And Toyota is being whiney about not supporting Windows Phones
  11. Wilf Brim
    Wilf Brim Junior Member
    Atlanta, GA
    It has to do with what iOS supports and how. For whatever reason, Apple does not support data connection over bluetooth (except bluetooth LE, and only some things, except Apple hardware and any other way Apple can make additional money off you). This effects connecting via Entune and also why Carista only works on Android: the BT OBD readers can't connect to an iPhone via BT.
    With your system the phone can connect as a phone and an BT audio device, both of which are OK on iOS.
  12. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Zephyr7 likes this.
  13. iBimmer
    iBimmer Junior Member
    For those who don't mind or are not afraid to jailbreak their iPhones - just get an app called TetherMe and tether your internet connection to the car forever without limitations. As of now July 20th, 2014 you can jailbreak ANY iPhone on ANY iOS firmware. You don't need sh*tass Entune or whatever else they wanna force you to use.
    Androidiot is another game. I've had a Galaxy S5 Active for about a week and can't figure out how to the same thing. But I will, sooner or later.
    I'm ready to help anyone who has questions about this.
  14. Zephyr7
    Zephyr7 Member
    301
    28
    LOL, go look at Nissan or BMW, do they have Apps that support WP?
  15. Zephyr7
    Zephyr7 Member
    301
    28
    its not with Apple but our carriers.
    Go Europe or Aisa and Carriers do not block or lock PAN connection. U can Tether without jail breaking.
    One need to really understand the root of the issue b4 saying its Apple or OEM issue.
  16. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Did you get it fixed? You need the bluetooth, the Entunes app and the USB hook up to get full use with the iPhones.
    As long as you wait a second for the radio to come up and then plug in the USB (make sure the app is still running) you'll get the "charge" for use of your data, then you are ready to go.
  17. nufan2222
    nufan2222 Junior Member
    96
    2014 Prius Plug-in
    For iphone you need to have private network or tethered option to get it to work
