1. Offline
    alfon New Member
    May 17, 2009
    Message Count:
    925
    126
    seaside, oregon
    Your Vehicle Year:
    I live in Oregon where this state mandates all year long a mixture of 10% Ethanol in gasoline sold in the state.
    I would like to know if there is actually a winter formula with this gas as it is already thined out with Ethanol. Any more blending to thin it would give you even less MPG.
    alfon
  2. Offline
    Mark57 New Member
    Aug 14, 2009
    Message Count:
    1,033
    134
    OKC
    Your Vehicle Year:
    I don't know if Ethanol is part of the mix for you when talking about winter formulated gas but I don't believe it is here since we can buy non-ethanol winter gas. I do know for reformulated winter gas, lighter, low-boiling-point components are added to the gasoline to increase volatility. This makes your car easier to start and accelerates converter light-off, thus lowering emissions.It's all about lowering emissions in the colder heavier air. In my real world measurements, winter gas provides lower mpg's and that's in every vehicle I've ever owned.
    We also get winter formulated gasoline here and also have an ethanol choice.
    Edit: Check out this article on Gasoline Blending
  3. Offline
    drpoehls New Member
    Jul 31, 2009
    Message Count:
    Milwuakee, WI
    Your Vehicle Year:
    Should I buy premium unleaded for my prius or will regular suffice?
  4. Online
    Apr 14, 2009
    Message Count:
    3,988
    937
    Greenwood MS USA
    Your Vehicle Year:
    From a MPG perspective, neither Gen I nor Gen II Prius got any better mileage on Premium, with some tests indicating a minor drop off compared to Regular. From a Horsepower perspective, Premium offered some advantage in hill climbs.
    I am not aware that these tests have been run on Gen III, it is a new (to the Prius) engine.
    I am happy with Regular.
  5. Offline
    Mark57 New Member
    Aug 14, 2009
    Message Count:
    1,033
    134
    OKC
    Your Vehicle Year:
    I'd stick with the recommended 87 octane.
  6. Offline
    Apr 13, 2004
    Message Count:
    14,718
    519
    South Puget Sound, WA
    Your Vehicle Year:
    ya, there is still winter formula gas. in WA, we have same all year e-10. track your mileage. you most likely went to winter fuel sept 30 or soon thereafter. it varies from region to region. Sept 30th is our "first official frost day" here.
    all summer long, i was averaging (mind you this is the MFD) 62-64 mpg. current tank is 59.5. so i have definitely lost some mileage here.
    driving patterns have changed slightly due to the fact that i am using 2010 to commute to work, but that only means i am using gas faster. the type of driving has not really changed much.
    now, the change in weather i feel accounts 2-3 mpg, the rest is change in gas. we still have some days that are very mild, but still not getting the mileage i was before.
Share This Page
