1. Offline
    finiyon Re-Member
    Mar 25, 2005
    66
    Philly, PA
    Your Vehicle Year:
    I am selling off my used EV Switch and Housing for a 2004 or 2005 Prius on eBay. $.99 to start. The auction ends 06-MAR-2009 at 3:34 p.m. PST. I'm now driving a 2008 Touring.
  2. Offline
    JimboK One owner, low mileage
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    Why are you selling it?
  3. Offline
    finiyon Re-Member
    Mar 25, 2005
    66
    Philly, PA
    Your Vehicle Year:
  4. Offline
    jtlytle Caution: Prius owner
    Dec 21, 2008
    89
    Your Vehicle Year:
    I have a 2004 Prius and how do I know if I have EV switch?
    Bear with me, I'm learning!!
  5. Offline
    finiyon Re-Member
    Mar 25, 2005
    66
    Philly, PA
    Your Vehicle Year:
    The programming is already in your car. The EV Switch is a way of activating the programming. There are volumes of info on the EV switch in the forums, just do a quick search.
  6. Offline
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    Ah, good reason. Hurts to see the crunch, though. Sorry for the loss.
  7. Offline
    • Moderator
    May 11, 2004
    13,922
    1,217
    Far-North Chicagoland
    Your Vehicle Year:
    No Prob, it's a valid question. In the 2004, there are two spots for buttons to the left of the steering wheel:
    http://www.calcars.org/images/felix-car-display2-full.jpg
    In the 2007 - 2009 there are three:
    http://lusciousgarage.com/images/uploads/EVmodebutton.gif
    The EV button looks like a car with the letters "EV" in it. You can see it in the second link.
    This button is standard in most places around the world but not in the US. So we have them imported.
    As they said above, the programming exists in the car already. It's just adding the button to activate the programming.
  8. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    Here's my '04 w/ the EV button visible to the left of the steering wheel.
    [IMG]
  9. Offline
    Genoz World ZEN-style living
    Feb 21, 2008
    797
    La Canada
    Your Vehicle Year:
    TO ALL - here's a question...........does the EV button work like the one on the 2010 model? for example, when i hit the EV mode, it works on the electric motor, but the minute i use too much acceleration, the EV mode kicks off and the ICE kicks in. is this the same?
    then, there's the question of the efficiency of the EV mode. does it drain the battery so much that later on, the ICE kicks in and does NOT stop running for an extended amount of time, taking away the disadvantage of using the EV mode in the beginning?
    if i've asked some obvious questions, bear with me. i just want to learn.
  10. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    Does EV also cut off the Traction Control?
    Does EV mode also work to cut off the Traction Control?
    If it does, then it sounds like it would be good for those 04-05 owners who lose or have experienced the loss of all power while climbing a slippery incline due to the operation of the Traction Control.
Share This Page
