EV vs HV % and Miles Between Oil Changes
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lukerey933, Aug 16, 2014.
  1. lukerey933
    lukerey933 Junior Member
    Coos Bay, OR
    If one uses a PIP for short commutes and has, say, half of their milage in EV… does this mean one could go double the milage recommended for an oil change? I realize you can always look at the dip stick and get a good sense, but I'm curious about the heart of the question: how much does EV mode reduce ICE wear and tear?
    Thoughts?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    If I did not value having a warranty on my car, I might ignore the vendor's recommendation.
    Comparing the cost of 3.7 quarts of oil to the cost of a 4 cylinder engine, I am happy buying oil every 10,000 miles.
    rxlawdude likes this.
  3. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)I took my 2012 Prius Plug In for the 10,000 miles service this week. It took me eighteen months to get that many miles. Being a plug in, I had less than 2500 HV miles. I checked the oil prior to the service and was surprised at how clean it looked. I passed on the free 5,000 miles service since I had no problems with my car and there was no actual servicing done on that check. Most manufacturers state change the engine oil at X amount of miles or every year. I think it's fair to change the engine oil at least once a year, but there's a little latitude there, in my mind. Always smart to use your two year free service schedule provided by Toyota.
    48,936
    i took the free oil change at 5,000 and 15,000 miles. now, i'm at 28 months old and 22,000 miles. but only 7,000 hv miles, and figure only 3,500 miles with the engine running. i may never change the oil again, haven't really decided, and there's no good info to base anything on without an oil analysis. i don't care about the money, it's the hassle of taking it for a change and removing the extra oil they put in. and also, why waste valuable oil and filters if not needed?
    3PriusMike likes this.
  5. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Considering the warranty what are your thoughts on every 6 months or 5000 miles whichever comes first? I almost never drive 5000 miles in 6 months, its often 8 months. However, I don't want to get on the wrong side of the warranty rules.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    So far as I know, no current Toyota has a 6 months or 5000 mile OCI in the US.* (Canada does)
    If you are asking would I double my OCI to twice what the warranty calls for, no that does not preserve anything I know of. You either meet the recommended service interval or you don't.
    10,000 miles is about 4 months for me. (30,000 miles a year)
    *Some models do warn you that if you CAN'T find synthetic oil and use conventional oil it MUST be removed in 5000 miles. But that is not a recommended solution.
  7. CaliforniaBear
    1,179
    289
    Northern California
    Jimbo, I'm afraid I don't understand your answer. What's OCI? My concern is if I go 8 months between service because that's my 5000 miles will Toyota say that invalidates my warranty?
  8. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    How'd you get the dealer to do an oil change at 5,000 miles? Did you state you're under the "severe operating conditions" maintenance schedule?
  9. bisco
    48,936
    no, i told them i was leaving and i wouldn't be back... ever. they did the whole, 'i'll check with the manager' thing, then said okay, but remember, you only get two, boa, blah, blah. i guess they lose the money if you don't use it or go somewhere else. hard nuts to crack.:rolleyes:
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    We do seem to be talking past one another, sorry. OCI is Oil Change Interval
    All current Toyota Prius have a 12 month/10,000 mile OCI, only Gen 1 and Gen 2 were 6 month/5000 miles OCL.
    You do the oil change which ever comes first, 12 months or 10,000 miles. (for me 10,000 miles is 4 months, so I only think of mileage)
  11. CaliforniaBear
    1,179
    289
    Northern California
    Right... OCI is 10,000 miles. So now I'm talking about maybe 16 months instead of 12 months and how that might affect the warranty.
  12. bisco
    48,936
    change it every 12 months.
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  14. CaliforniaBear
    1,179
    289
    Northern California
    Why?
  15. bisco
    48,936
    because you don't want to exceed a year, or 10,000 miles. a year ecause the oil deteriorates over time (supposedly) or 10,000 miles because it has picked up too much contaminants by then (supposedly). nobody really knows why we change the oil.
  16. CaliforniaBear
    1,179
    289
    Northern California
    Actually that isn't nearly the problem it used to be. And the contamination is mostly due to engine miles resulting from the internal combustion process not a 30% increase in "storage" time.
  17. bisco
    48,936
    agreed, that's why i'm done changing mine.
  18. CaliforniaBear
    1,179
    289
    Northern California
    I've asked Toyota.com the warranty question. It will be interesting to see the answer which I will report here.
  19. bisco
    48,936
    you may want to check the california warranty laws as well. some states won't allow limitations to warranties.
  20. CaliforniaBear
    1,179
    289
    Northern California
    That's interesting and probably a major undertaking :eek:
