1. Offline
    Mac Prius Mod Junkie
    Start a Conversation
    Feb 2, 2012
    211
    42
    San Diego
    Your Vehicle Year:
    The recall notice states it could take 5 hours or more to get this done. Taking my v in for its first service and recall taken care of so I wanted to check to see if anyone has gotten this done and how long did it take.
  2. Offline
    hoddy4 New Member
    Jun 8, 2009
    120
    NC
    Your Vehicle Year:
    I had it done yesterday. It took less than 3 hours.
    1 people like this.
  3. Offline
    2sk21 Member
    Oct 28, 2011
    127
    Teaneck, NJ
    Your Vehicle Year:
    I had it done a couple of days ago and it just took a couple of hours once they got the part. It took two trips to the dealer - they first had to determine whether a fix was required.
  4. Offline
    JACoH Enjoying the mileage
    Oct 11, 2009
    151
    Oregon
    Your Vehicle Year:
    Had mine done last week, done in less than 2 hours! Thought I would take a look under there this weekend and discovered, when installing a Mike500 mid chassis brace, that one bolt was missing from the oem brace, and the hole stripped! So, it takes less time when you don't have to replace all the bolts!
  5. Offline
    CPSDarren CPS Technician
    Aug 9, 2009
    499
    77
    Chicago
    Your Vehicle Year:
    I'd be interested to know if people who have had the recall experience any drop in fuel economy as a result.
    The same recall applies to the Highlander Hybrid, but it's listed as a 9 hour repair. Perhaps unjustified, but I'm a bit concerned they will mess up something in the process. I'm pretty happy with the fuel economy so far.
  6. Offline
    Mike500 Interessen-Gemeinschaft Prius
    Mar 1, 2012
    997
    242
    Upstate, SC
    Your Vehicle Year:
    The recall was issued to correct a potential leak and shutdown of the vehicle. So, reduction in MPG is NOT an issue to me. If you're worried about a MPG issue, just don't drive, and you won't be spending any money on gas.
  7. Offline
    Aug 9, 2009
    499
    77
    Chicago
    Your Vehicle Year:
    Sure, if that's an option for you, that's great. Personally, if I have a major repair done, I'd like to know they do it right, such that everything works correctly after the fix, just as before. I see no harm in asking others if they had any issues with their service. The thing about knowing in advance is that it could be something you can discuss with the service manager to make sure they don't make the same mistake.
    Fuel economy is something pretty easily measured and also a major reason most people buy hybrids in the first place. So, yes, I am interested to know if anyone has noticed a drop and if they found the cause of the issue.
  8. Offline
    tanasit Member
    Mar 26, 2012
    290
    43
    Philadelphia
    Your Vehicle Year:
    Thanks for all the posts. I received the notice only a few days ago and it says I have until year 2015! Anyway at first I thought I would wait because I want this to be a routine repair for the mechanic since it is the 5 hour repair so they will get used to the procedure. Now I know it can only be 2 hours so I will take mine in at 5000 services or 6 months.
  9. Offline
    Mar 1, 2012
    997
    242
    Upstate, SC
    Your Vehicle Year:
    You know as well as I do, Tanasit, that corporations don't do anything that cost them money are reduce their bottom line, unless they have to.
    The downside of not doint the recall would be a leak in the valve, the draining of the coolant in the system that cools the engine and shutdown of the vehicle somewhere on the side of the road.
    While Toyota will pay for the reoad service and all of the repairs, the possibility of this happening to my own vehicle is something that I would not like to chance. I had mine done at the first opportunity.
    My thoughts,
    Mike500
  10. Offline
    Feb 2, 2012
    211
    42
    San Diego
    Your Vehicle Year:
    I had mine done along with its 5K service and first oil change. At first the tech told the service rep it would only take about an hour but it ended up being about 3 hours. I have not had any drop in MPG either and I did not expect one. Thanks for the replies folks.
  11. Offline
    JRCurrier New Member
    Mar 31, 2012
    Indiana
    Your Vehicle Year:
    Had mine done 2 weeks ago and everything went great. I dropped it off, expecting not to get it till the next day, but they called me 2 hours later and said it was done.
  12. Offline
    buckaroo Junior Member
    Aug 28, 2011
    64
    Austin TX
    Your Vehicle Year:
    I figure that I will wait until my 10K checkup & oil change & then have it done.
  13. Offline
    Mar 1, 2012
    997
    242
    Upstate, SC
    Your Vehicle Year:
    Getting a good technician, unfortunately, is like a "crap shoot."
    Since mine was the first one done by my dealer, they had the most experience technician trained in servicing the Prius do it. I saw him "religiously" reading the instructions and he took his time to do it right.
    Then, again, a technicia, who has 10 years of experience, could have had 10 years of his "first day" of experience over and over again for 10 years.
  14. Offline
    parnami Member
    Jul 8, 2009
    204
    32
    Philadelphia (ugh)
    Your Vehicle Year:
    Mine was done this morning. They began work shortly before 8 am..and at 9:10, my phone beeped when bluetooth connected as my car was driven up to the customer waiting area to be picked up. All told, it took less than 90 minutes!
  15. Offline
    GARGOYLE58 New Member
    Apr 4, 2012
    NEW JERSEY
    Your Vehicle Year:
    I HAD THE EXHAUST ACTUATOR WORK DONE TODAY TOOK 2 1/2 HOURS ALSO THEY TOOK OFF THE REVERSE BEEPING THANK GOD NO COST.
  16. Offline
    TheBob New Member
    Jun 28, 2012
    Your Vehicle Year:
  17. Offline
    TheBob New Member
    Jun 28, 2012
    Your Vehicle Year:
    I took my 2012 prius V in for the recall expecting 5 hours and it only tookk an hour or so. But prior to this , for the first 5163 miles I was averaging 47 MPG on each tank of gas. I have filled up twice since then and my average for each tnk was 42 MPG. Something changed and it is not the way i drive the car. This is not just coincidence. I love my car and I did buy it, at least partly, because of mileage. But I just lost about 11%. Has anyone else had this experience.
  18. Offline
    Lats118 New Member
    Mar 20, 2012
    CT
    Your Vehicle Year:
    Had my recall done a few weeks ago. Before the repair I was getting 50+ mpg, the first tank after I got about 47. The next back to 50+. On my 3rd tank since the repair and I'm hovering around 50+ again.
  19. Offline
    MarathonMarty Prii 4-timer
    Jun 19, 2009
    32
    Spokane, WA
    Your Vehicle Year:
    2013 Prius v wagon
    Had mine done at the end of May and have taken 2 Spokane to Seattle trips along with the usual amount of local commutes. No noticeable change in mpg usage. If anything my highway mileage may be slightly better.
  20. Offline
    M8s Retired and Lovin' It
    Sep 11, 2008
    597
    97
    Colorado & Arizona
    Your Vehicle Year:
    You got that right. My service writer was great but the tech took 4+ hours to do the work. Now I have an intermittant rattle from somewhere in the rear. Being intermittant, I couldn't get the rattle to rattle when the service writer was in the car.
    Fuel economy is unaffected, though.
    UPDATE: I took it back to the dealer for the rattle. Turns out the rear cross bar was torqued to spec, but needed to be torqued just a bit more. No more rattles means blissful silence again.
Share This Page
