1. Offline
    NEPrius1 New Member
    Jul 24, 2009
    Message Count:
    Northeast
    Your Vehicle Year:
    I am new to the forum after having just purchased a 2010 Prius III. So far, I can honestly say it is the greatest car I have ever owned. I use EZPass daily and need to mount the transponder in my new Prius. I was thinking about mounting the transponder above the rearview mirror in the area of the windshield that has the black dots.
    My fear is that if I use the velcro strips that come with the EZpass transponder, upon removing the velcro strips at a latter date, it may damage the black dots on the inside of the windshield. Does anyone have experience with this and where have others mounted an EZpass transponder on a 2010 Prius?
    Thanks in advance.
  2. Offline
    MaggieMay New Member
    Apr 6, 2009
    Message Count:
    528
    67
    Gloucester, MA
    Your Vehicle Year:
    This should help: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/65508-ez-pass-placement.html
    1 people like this.
  3. Offline
    NedRob New Member
    Apr 19, 2010
    Message Count:
    New Jersey
    Your Vehicle Year:
    Hey, if you are concerned about how your car looks with the EZ Pass transponder properly attached to the inside of your windshield, check out Logo Toll Tags (dot) com Some people don't like the looks of their EZ pass in their windshield, so they either wave it at the tollbooth or let it slide around on their dash. This can cause accidents as people search for their ez pass transponder and can cause the EZ Pass transponder to be read incorrectly or not at all. The EZ pass Holders from LogoTollTags have sports team logos on them from the MLB, NFL, NHL, some colleges and some NASCAR teams. I think they look better than just a blank white spot, but most importantly it is safer for you and the other drivers on the road to have the EZ Pass mounted properly.
  4. Offline
    wick1ert New Member
    Dec 3, 2009
    Message Count:
    1,159
    147
    Delawhere
    Your Vehicle Year:
    I mounted just below that area (I also have the strip of window tint across the top of my windshield) and the transponder is mostly blocked from my view by the rear-view mirror. Works out nicely!
  5. Offline
    walterm New Member
    May 17, 2007
    Message Count:
    243
    31
    Your Vehicle Year:
    For a different approach I didn't mount mine at all - I keep it in the upper glove box, and I haven't had a problem with it being read yet.
    Depending on what roads you frequent be sure to look for discounts in the EZ Pass program for hybrid vehicles (GREEN pass) - the NY Thruway and PA bridges&tunnels have them, as does the Garden State Parkway/NJ Turnpike (off-peak discount only).
  6. Offline
    Judgeless New Member
    Jun 30, 2009
    Message Count:
    1,489
    149
    Cleveland, OH
    Your Vehicle Year:
    I use my EZPass 2-3 times a day. I found this the most effective mount for me.
    [IMG]
    Both glove boxes are lined with felt. That is why they are so dark.
  7. Offline
    Joe166 New Member
    Dec 19, 2009
    Message Count:
    721
    95
    South Florida
    Your Vehicle Year:
    That's great, but what about when you don't want to use the pass. Do you have to leave it at home, sit on it, put it under the seat?
    Actually, our local turnpike authority gives away metallic envelopes that you can put your transponder in and it won't read it, even in that top box. Thank goodness because we get the high occupancy toll lane gratis with the hybrid.
  8. Offline
    Jun 30, 2009
    Message Count:
    1,489
    149
    Cleveland, OH
    Your Vehicle Year:
    If I am in the car I use it. I also have a Sun Pass that I only use in FL. That stays at home.
  9. Offline
    brandonpa New Member
    Dec 18, 2009
    Message Count:
    50
    Pennsylvania
    Your Vehicle Year:
    I mounted on the dots without problem. There since december and works fine.
  10. Offline
    Jim05 Occasional Quasi-Hypermiler
    Aug 22, 2009
    Message Count:
    112
    Culpeper
    Your Vehicle Year:
  11. Offline
    radiocycle New Member
    May 10, 2007
    Message Count:
    473
    63
    Morro Bay, CA
    Your Vehicle Year:
    Well, we have a dash mat and the hook-and-loop material on the transponder sticks like glue to it, so there's no sliding around. We just keep the FasTrak in the glove box and set it on the dash mat, in the middle of the dash, whenever we're going up north where we cross all the bridges.
  12. Offline
    drash New Member
    Jan 5, 2005
    Message Count:
    424
    34
    Upstate NY
    Your Vehicle Year:
    And of course I don't have to tell anybody who lives in NY to get a green E-ZPass for your Prius? It saves 10% off the regular E-ZPass rates.
  13. Offline
    Boo Boola Boola Member
    Feb 13, 2007
    Message Count:
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    And being green colored, they look a lot better too (none of that pasty white stuff). Here's a pic of mine in a black plastic suction-cup mount holder:
    [IMGLINK]http://priuschat.com/forums/members/boo-albums-prius-picture816-green-ezpass-in-black-ezpass-holder.jpg[/IMGLINK]
    The Green EZ Pass can give you a greater discount on the NYS Thruway at all times, and on the NY-NJ Port Authority bridge and tunnel crossings during off-peak hours. But you have to make sure to specify that you want both the NYS Thruway and the NY-NJ Port Authority Green Passes, and both discounts will be programmed into your green colored EZ Pass transponder.
  14. Offline
    stevemcelroy New Member
    Jan 25, 2009
    Message Count:
    601
    88
    Wallingford, PA
    Your Vehicle Year:
    The other thing you could do is swap your conventional tag for one of the exterior ones - it gets mounted just above the front licence plate using the same screws that hold the plate to the car - it is available for a few cars that have funky front windshields but when I got my ez-pass (New Hampshire) I got to choose.
  15. Offline
    flbntz My First Toyota
    Dec 12, 2009
    Message Count:
    49
    Elizabethtown, PA
    Your Vehicle Year:
    Ditto.
  16. Offline
    Penny's Dad New Member
    Dec 2, 2009
    Message Count:
    422
    43
    Orlando Fla
    Your Vehicle Year:
    Colored mine black with a sharpie...took a while but worked out fine.
  17. Offline
    hobbit New Member
    Mar 23, 2005
    Message Count:
    4,089
    443
    Bahstahn
    Your Vehicle Year:
    I'm in the process of doing a little research into this. It is
    worth keeping the thing shielded between tolling locations, as
    there are some other, uh, "uses" cropping up that want to read
    the transponder. According to the folks at Mark IV, who make
    the units, they are less sensitive along the bottom edge [as
    typically mounted in a vehicle] and thus that's the right place
    to handhold them if you're going to do that instead of mounting
    it. What's not yet known is how effective a small metal box
    to drop the unit into between uses is with regard to actually
    shielding it against trigger pulses, but now I've got a thread
    to post results into once that's determined.
    _H*
  18. Offline
    djasonw New Member
    Jul 13, 2004
    Message Count:
    812
    Belle Harbor, NY
    Your Vehicle Year:
    Hey... that is really good information!! I had no idea that the EZ PASS would pick up by being in the upper glove box. I live in Belle Harbor in Rockaway and use the Marine Parkway Bridge daily. I have my pass mounted behind the RVM. I think I'll try and see if it works tomorrow.
  19. Offline
    gbarry New Member
    Feb 2, 2010
    Message Count:
    70
    S. California
    Your Vehicle Year:
    Do you all get to stop and wave it around to see where it works? In California (FasTrak) you drive under the sensor without stopping. That's a heck of a way to "test" a theory. I'd love to be able to keep it in the glove box, but it's not like I get a second chance.
  20. Offline
    Feb 13, 2007
    Message Count:
    5,086
    602
    Flushing, NY
    Your Vehicle Year:
    I have that same fear about keeping the transponder in the top glove compartment. I don't know if the transponder would be read at those tolls that you drive under at highway speeds.
Share This Page
