Faint buzzing/rattling noise driving me nuts
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by elmofongo, Apr 12, 2012.
  1. elmofongo
    elmofongo Member
    251
    SF, CA
    I am experiencing a buzzing rattle coming from the left corner of the dashboard in the area near the horizontal speaker. It's not loud but it's annoying. It only happens when the car is moving. It doesnt seem to be affected by the audio system being powered on or off. The best thing I can think of to describe it the sound a Geiger counter makes, but not as loud.
    Anyone experiencing a similar noise? Any suggestions to diagnose it?
    Thanks
  2. hmcgregor
    hmcgregor New Member
    34
    Tucson AZ
    Could this be the 2012 noise maker that is mandated by law?
    -Harry
  3. pfile
    pfile Member
    319
    35
    bay area, ca
    do you have a cellphone in the car? your description sounds a little like the "gsm noise" that older speakerphones, etc. would couple in when a gsm phone started communicating with the cell network.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Is it continuous or intermittent?
    Tom
  5. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    Like a small buzz or rattle, coming from somewhere between the air vent and speaker? I have it too!!!
    It is at highway speed... Not the noise maker and not gsm noise, very familiar with that.
  6. elmofongo
    elmofongo Member
    251
    SF, CA
    It seems to be continuous as long as the car is moving on pavement.
    Mine seems to occur at sub-freeway speeds. When cruising at 25mph, I can hear it. No phone. It sounds like something loose vibrating.
    :confused:
  7. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Try to get the dealer to fix it. Maybe record it with your cell phone, if it's safe.
  8. I922sParkCir
    I922sParkCir Junior Member
    31
    Orange County, CA
    I have it too. I think that it's that corner panel right below the corner window. When I hold it secure, that noise goes away. I'm going to buy/make small rubber shims to keep it from rattling.
  9. SCDrJ
    SCDrJ New Member
    120
    Orange County, CA
    That's where mine is too.
  10. krishkal
    krishkal New Member
    Fremont, CA
    I heard the same kind of noise from the same general area once too. If the music is loud enough, I don't hear it ;) I will drive with music off for a while to see if it keeps recurring.
  11. elmofongo
    elmofongo Member
    251
    SF, CA
    Getting a service technician to hear it is going to be a challenge.
  12. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Check the mirrors in your sun visors. Make sure they're either full closed or full open. It's one more possibility to exclude...
  13. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Could it be the Plasmacluster?
  14. elmofongo
    elmofongo Member
    251
    SF, CA
    I just confirmed the location of the noise source.
    Putting horizontal pressure on plastic corner defrost vent (aimed at the triangle window) quiets the noise.
    Does anyone know how to pop that piece of plastic off?
    Or at least where in the parts catalog it is located, or its name, so I can look at an illustration of the way it is fastened?
  15. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    You need to remove the side pillar garnish first. Its in the PDF I've attached here. Pay close attention to this section:
    There's an illustration of it. But if you yank on the garnish hard enough and far enough away from the pillar, it may snap that clip. When I removed my pillar garnish (for the homelink mirror), I popped all the clips, then pulled it back far enough to look bheind the garnish to see that special clip that you need to turn 90 degrees. Its like a lock.
    Also, you need to first pull down the door weather stripping to expose the edge of the pillar garnish. That just slips off my hand.
    The defroster vent panel looks like it just pops off (see the attached image)
  16. elmofongo
    elmofongo Member
    251
    SF, CA
    Wow, it's a little more involved than I thought [​IMG]
    I thought the corner piece just pops out by itself!
    PS: Thanks for the info!
  17. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I think the corner piece sits under the pillar garnish, doesnt it? I think thats why they tell you to remove the pillar garnish first.
    Removing the pillar garnish isnt that bad. Once you start popping the clips off, they all start to come off. Just be sure to reach behind to twist that one locking clip 90 degrees. You should be able just to reach it with your hand once the garnish is semi-removed.
    Anyhow, good luck. Just remember if you took it to the dealer, chances are the tech wouldnt be as careful as you would be with your own car :D.
  18. elmofongo
    elmofongo Member
    251
    SF, CA
    I picked up a spare corner piece on eBay for $25 just in case I gouge the original. :D
