1. Offline
    Start a Conversation
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
    Hi Rob,
    Thanks for providing a very detailed writeup about your work.
    The Toyota repair manual is silent regarding the correct fan rotation direction. The exploded parts diagram shows that one fan has seven blades while the other has five blades, but you have to look closely to note this. Prior to reading your posts, I had assumed that the two fans were the same and rotated in the same direction.
  2. Offline
    kohnen Grumpy, Cranky Senior Member
    Jun 13, 2007
    317
    37
    Fullerton CA
    Your Vehicle Year:
    Yikes! One fan goes to the left and the other to the right! Is there some sound technical reason for Toyota to have done this or is this political correctness run amuk?!?!
    Seriously, first place award for troubleshooting above and beyond the call of duty!
    :first:
  3. Offline
    snijd DIY or die
    Jul 5, 2008
    215
    39
    Redmond, WA
    Your Vehicle Year:
    I think it may have something to do with the fact that Japanese fighter pilots held the P-38 Lightning in such high regard in WWII.;) The P-38, of course, had counter-rotating propellers, but in the opposite directions of the fans in the Prius. You think this is far fetched?
    Rob the docent at the Seattle Museum of Flight
  4. Offline
    JHSmith Camry Hybrid Owner
    Sep 30, 2006
    184
    King George, VA
    Your Vehicle Year:
    You surprise me! :evil:
    Do you ever realize that on multi-engine prop planes, they have counter-rotating engines / props to decrease torque so the planes won't spiral out control? :plane:
    Well, Toyota, in their infinite wisdom, used the same engineering analysis and made counter-rotating fans? :doh:
    Word has it, they will follow suit in the 2010, and have the front wheels rotate opposite of the rear wheels! :bounce:
  5. Offline
    Dr_SCIFI Junior Member
    May 12, 2009
    Miami
    Your Vehicle Year:
    I really need your help. My car was involved in a crash... everything was repaired but one of my fan blades got damaged on the right fan so half is broken. I thought it was not important since its only one blade so I tried to cut corners and told body guy to put it on. Now, I regret that cause when you turn on a/c which turns on the 7 blade fan, there is a vibration due to the 1 missing blade out of the 7. Now, I know it is a pain to remove and change... I got the new fan and want to put it on from the bottom. Can you please tell me how to do this?
    How do you remove the shroud so I can change the fan?
    Please help.
  6. Offline
    snijd DIY or die
    Jul 5, 2008
    215
    39
    Redmond, WA
    Your Vehicle Year:
    Glad to hear you sorted it out. The repair manual makes it seem far more difficult than it needs to be--no cooling system or A/C disconnects needed. Just a tight squeeze with gloved hands!
  7. Offline
    fccjben New Member
    Jun 28, 2010
    va
    Your Vehicle Year:
    Rob,
    Thanks for the job description, especially the part about the fan nuts being 8mm. I was able to swap them by just removing the fan housing bolts. I had just enough room to squeeze an arm between the radiator and housing through the bottom. Lost some skin though.
    Fccjben
    John
    Rob,
    • Do the two fan motors have the same part number?
    No--and the prices are different. One turns clockwise, the other turns counter-clockwise.
    • I take it that you personally swapped the fan blades? What does this procedure require? How hard is it to remove the blade from the motor?
    Yes, I personally did the work.
    1. Removed the plastic fairings/covers beneath the radiator (I also removed the inner wheel wells, as it seemed easier than separating the other pieces), and the plastic pieces on top, in front of the radiator.
    2. Removed bolts retaining radiator, on top and bottom.
    3. Removed a couple of electrical plugs to make it easier to maneuver the fan housing so as to make room to reach up between the radiator and the fan housing with a ratchet to reach the nuts on the fan blades.
    4. Loosened fan blades with 8mm socket on 3/8" drive--a long drive handle made it easier.
    5. The fan blades came right off.
    6. Reverse procedure to reinstall fan blades. The keyway is identical on both motors, making it easy to inadvertently reverse their position.
    • Did you need to swap the two fan motors; or did you leave the fan motors at their original locations?
    I left the fan motors where they were. To have moved them would simply move the problem to different locations.
    • When looking at the fans from the rear of the car facing forward, which direction is each fan supposed to turn (clockwise or counterclockwise?)
    Left: clockwise; Right: counterclockwise.
    I am also surprised that this problem did not manifest itself to the original owner. This seems to indicate that the car suffered front-end accident damage and the fans were incorrectly installed?
    Yes, this is very likely the result of maintenance performed on the vehicle, rather than an assembly line error. I wonder if the previous owner sold it to me because he was stumped at the vehicle's strange behavior--he certainly made no mention of it when showing me the car. It was surprisingly tolerant of the backwards cooling arrangement. The primary manifestation was the intermittent air conditioning. I only saw a high temp warning once, and only for a few seconds. I have no idea why he didn't get it fixed, since it was under warranty. Maybe the dealer was stumped, too? Seems difficult to believe.[/QUOTE]
  8. Offline
    snijd DIY or die
    Jul 5, 2008
    215
    39
    Redmond, WA
    Your Vehicle Year:
    [/QUOTE]
    Did you experience the same anomaly--fan blades on the wrong sides?
  9. Offline
    fjamesa New Member
    Jan 18, 2010
    Australia
    Your Vehicle Year:
    Hi all,
    Yes I bought a 2006 Prius from a dealer late 2009 here in Australia. It turns out that there are some telltale signs to this issue, but more than likely it's a factory fault on the 2006 model!
    The front RHS foglight on mine was smashed - I thought it was a rock and didn't even notice it when I bought the car, but the reason it was broken was simple - all fan related.
    The first I knew there was a problem, was in a Perth 42deg Celcius day where the Airconditioner just stopped working after a while. Sitting idle, sometimes it would start working again. Very strange considering there was a sticker under the bonnet (or hood?!?) saying that it had been regassed recently.
    As it turns out, the airconditioner was the only real noticable issue - as it stopped working randomly - and then started again just as randomly after I had overheated inside the vehicle.
    It turns out the fan blades on mine were reversed also - the 7 blade fan where the 5 blade was supposed to be and vice versa! This caused air to be blown at the wrong rate and in the opposite direction to the normal airflow when the car was in motion at 70KM/hr. The NET airflow through the radiators when moving was almost zero.
    The fact that the fans were on full blast (parallel accross the 12v instead of the low speed series operation) meant that things were getting hot, but I wouldn't have noticed if it weren't for the A/c. Also the HOT air coming out the front of the radiator grill tended to superheat the RHS foglamp - so a splash of water one day probably just shattered it's glass. Now I know why.
    The Toyota dealer was TOLD to swap the fans in a service and they only believed me after they saw the issue.
    The vehicle has been running fine ever since and the A/C runs full time and now can freeze the passengers solid even in hot weather.
    Looks like a common issue to 2006 Gen II prius cars - I don't know how long mine was like that but it looks like from new.
    I found a picture on google and numbered everything, then emailed it to the dealer so they knew what I was on about.
  10. Offline
    snijd DIY or die
    Jul 5, 2008
    215
    39
    Redmond, WA
    Your Vehicle Year:
    Yours is the only other car I've heard of having the same problem I experienced. Although it is possible it came from the factory this way, the fact that your A/C has been recharged points to some kind of repair having been done that led to installing/replacing the fan blades. In my case, I also discovered that the inverter pump had been recently replaced. Since these tend to fail following extended operation at high temperatures, I suspect the fan blade reversals also caused premature pump failure.
  11. Offline
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
    This is indicative of a bad design, where it is possible for the fan blades to be swapped. I'd expect the fans to be designed so that the wrong blade won't fit on the wrong fan motor.
  12. Offline
    snijd DIY or die
    Jul 5, 2008
    215
    39
    Redmond, WA
    Your Vehicle Year:
    No doubt about that. There are myriad examples of these kinds of mistakes being made as a result of poor engineering. I once had a mechanic swap my left/right magnetos on a Lycoming aircraft engine. When I told him why I thought it wouldn't start, he refused to believe me... at first. An F-15 fighter crashed at Bitburg after the flight controls mechanic reversed the aileron actuator connections. The pilot and ground crew **should** have noticed during preflight, but didn't. Moving the stick right rolled the aircraft left, and he didn't figure out what was going on quickly enough. At least the Prius fan design fault didn't kill me!
  13. Offline
    eric chow New Member
    Jul 2, 2012
    Your Vehicle Year:
    My 2005 Prius also had overheating issues during hot days in the summer and the AC would run warm. I had some front-end damage repaired a few years ago in the Spring and didn't put the two problems together until I did some research on PC. Sure enough, the autobody shop had the fan blades swapped. I turned on the car and AC and held a piece of tissue in front and behind the radiator and the airflow was forward instead of backwards.
    Thanks for Snijd for his walkthrough. It turned out all I need to do was remove the top and bottom shrouds and then loosen the for bolts that hold the fan assembly to the radiator to access the fans.
Share This Page
