Faraday Bag for Smart Key (SKS) Break-in Protection
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HGS, Aug 30, 2015.
  1. HGS
    HGS Member
    307
    122
    After reading many stories about smart key cars being broken into, I bought two Faraday bags. One key fob size one for me and one cell phone size one for my wife. They work great. After putting a key fob in a Faraday bag, all communication with the car is stopped. With a Faraday bag, no one can boost the key fob signal from far away and unlock your car door.
    I bought mine at Amazon. Here is the link. Cheers!
  2. HGS
    HGS Member
    307
    122
    Here is a picture of my two Faraday bags.
    48,972
    cool! have you tried unlocking the door or starting the car with the fob in the bag?
  4. HGS
    HGS Member
    307
    122
    Once the bag is totally sealed, the fob will not unlock or start the car. I've tried it. It's as if the key fob battery is dead. But, the slightest opening in the top of the bag and it still unlocks the car.
    The equipment to "boost" the key fob signal can be bought online for $17. It will allow someone to unlock your door when your key fob is a 100 feet away, maybe more. Not good if you are at a restaurant or hotel and your belongings are stolen, or even in your driveway while you are sleeping (as in the following video).
    It cannot start the car, just boost the door unlock signal.
    Spending $16 for a Faraday Bag is very cheap insurance against a break-in.
    Read these articles:
    http://www.nytimes.com/2015/04/16/style/keeping-your-car-safe-from-electronic-thieves.html?_r=0
    Putting keys in freezer could prevent car break-ins
    Watch this video of a break-in:
    Cheers!
    #4 HGS, Aug 30, 2015
  5. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I'd be interested to see a link for this.
  6. HGS
    HGS Member
    307
    122
  7. bwilson4web
    15,394
    Let me suggest this needs to be shared across all Prius models and other non-Prius models. That is why I posted my note in Fred's House of Politics.
    Truth be told, I'm not sure what is the best way to 'get the word out'.
  8. HGS
    HGS Member
    307
    122
    Thanks Bob,
    I'm still new to PC and don't know all the ins and outs.
    This faraday bag is the coolest thing ever. I just hope no one locks their door with the key fob in the faraday bag in the car. I can and will happen if one is not careful. I put mine in the bag after I'm out of the car.
    Training my wife to only lock the door with the key fob or the outside door handle, not the inside door lock.
    #8 HGS, Aug 31, 2015
  9. bisco
    48,972
    signs in dealership windows?
  10. ETC(SS)
    6,493
    Walmart.
    $2
    Candy included.
    usnavystgc likes this.
  11. Mendel Leisk
    38,240
    Just tried with aluminum foil wrap, a double layer. First time around I had some keys attached to the fob, and was a little sloppy in my wrapping: fob still worked. Then I disconnected the physical key (and extra keys), made sure it was more tilghtly enclosed, and the fob was then dead: no response from the car.
    Still, this is gonna be a pain. so much for the low maintenance aspects of the fob.
  12. mrbigh
    3,686
    699
    Long Island, NY
    It is going to be and aluminum burden.............
  13. HGS
    HGS Member
    307
    122
    Altoids tin does not work. I already tried it.
    kathoderayblue likes this.
  14. HGS
    HGS Member
    307
    122
    I tried the freezer for a couple of days while waiting for my faraday bags. The key fob gets frosted over. I think long term it will leave too much water inside and one day ruin the fob.
    Spending $16 for a faraday bag is the most secure and easiest option. It's very quick and easy to use.
  15. mrbigh
    3,686
    699
    Long Island, NY
    I will try ESD certified bags from work, we have tons of them.
  16. HGS
    HGS Member
    307
    122
    Not sure if this option will work. I need to wait for my wife to return with the car. I just read this option for putting a key fob in standby battery saver mode. I tried it on my key fob, but it never flashed 4 times. Maybe this for a different model.
    Solution to prevent hacking of Toyota's Smart Key System - Toyota Nation Forum : Toyota Car and Truck Forums
    "I have found a solution to this problem. Car thieves are able to break into the car by extending the range of the car door sensor so that a key that is further than 2.3m away is detected allowing the car to unlock. Encryption of the key isn't a solution because the thieves are using a legit key to unlock the car.
    Toyota does not have any settings to disable the Smart Key unlock feature but I have found a solution to temporarily disable Smart key unlock on the key fob itself thereby thwarting the hack above.
    You can place the smart key into battery saver mode by holding lock and pressing the unlock button twice. Watch the fob light flash four times to confirm that you are in battery saver mode. once the fob is in battery saver mode, it no longer wirelessly sends out a ping for the car door sensor. Without the ping, Smart Key unlock is disabled. You cannot walk up to the car and unlock it by touching the handle.
    To reactivate the fob from battery saver just use any one of the buttons (press lock, press unlock, or hold down the tailgate button)
    Since battery saver mode affects the keyfob only you do not need to be near the car to enable or disable battery saver mode on the fob. The car doesn't care at all so you can re-activate the fob before you are in range, walk up to the car and then use the smart key unlock feature as normal.
    I plan to send this to Toyota as well because I think it should be in their manual as added security to the smart key system."
  17. mrbigh
    3,686
    699
    Long Island, NY
    Lock + Unlock wait for 4 LED blinks. Easy enough
    Very interesting procedure, I will try it later.....
  18. Mendel Leisk
    38,240
    Seems effective, albeit more fussy:
    The concept and the execution are two things tho. It's 99% cargo cult, and the one time you need it you won't (Murphy's Law).
  19. HGS
    HGS Member
    307
    122
    The following comes right out of an Avalon manual. I don't think it works with a Prius. I can't get the light to flash 4 times.
    ■ Electronic Key Battery-Saving Function
    When battery-saving mode is set, battery depletion is minimized by stopping the electronic key from receiving radio waves.
    Press unlock twice while pressing and holding lock . Confirm that the electronic key indicator flashes 4 times.
    While the battery-saving mode is set, the smart key system cannot be used. To cancel the function, press any of the electronic key buttons.
  20. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
