Fastening the license plate
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dr_rock, Jan 16, 2012.
  1. dr_rock
    dr_rock
    Expand Collapse
    Junior Member
    28
    Pennsylvania
    :(Hi. I'd like to install 2 screws in my new Prius to hold the lower edge of the plate. Is there any precaution I should be aware of concering drilling into the rear door? What about potential for rusting? Not sure why Toyota doesn't have 4 holes prepared for this already.
  2. Judgeless
    Judgeless
    Expand Collapse
    Senior Member
    1,825
    234
    Cleveland, OH
    I would not drill into the metal. That is asking for rust.
    I put fake bolts on mine. It is nut and a bolt. The back of the bolt is cut off. This is a bad pic because of all the salt in Cleveland.
  3. dustoff003
    dustoff003
    Expand Collapse
    Blizzard Brigade #003
    1,350
    328
    Waianae, HI (Oahu)
    Why? Precautions dunno once again, why do you want to make holes in your new car?, The hatch is made from Aluminum there could be a potential problem of dissimilar metal corrosion unless you use Aluminum fasteners. If you look at the top the hardware they thread into threaded inserts covered by the tape in the picture below. Why not four holes because it is not necessary. You should have two foam bumpers shown in picture below and if the existing two fasteners are tightened correctly your plate should be secure and rattle free.
  4. xs650
    xs650
    Expand Collapse
    Senior Member
    4,524
    1,388
    Northern California
    That panel is aluminum so rust won't be a problem. Toyota didn't put 4 holes there because it would have cost a few cents more.
    Here's one way to add two tapped mounting holes.
    http://priuschat.com/forums/gen-iii...-rear-license-plate-installation-gen-iii.html
  5. dustoff003
    dustoff003
    Expand Collapse
    1,350
    328
    Waianae, HI (Oahu)
  6. Judgeless
    Judgeless
    Expand Collapse
    Senior Member
    1,825
    234
    Cleveland, OH
    Here is a much better pic of the same plate with out all the salt.
  7. dustoff003
    dustoff003
    Expand Collapse
    1,350
    328
    Waianae, HI (Oahu)
    Your lower hardware is only securing your cover to the license plate, not actually securing the plate and the cover to that hatch right?
  8. Judgeless
    Judgeless
    Expand Collapse
    Senior Member
    1,825
    234
    Cleveland, OH
    Correct. It is more cosmetics then to secure it.
  9. tumbleweed
    tumbleweed
    Expand Collapse
    Senior Member
    4,067
    651
    Eastern Oregon
    Super Glue
  10. stream
    stream
    Expand Collapse
    Senior Member
    2,977
    445
    Long Island, NY
    Agreed--not necessary.
  11. Rebound
    Rebound
    Expand Collapse
    Senior Member
    2,262
    741
    SF Bay Area, California
    Disagree. With only two screws, the license plate rattles significantly. I solved this by attaching adhesive felt pads to the bottom area of the plate. These pads are commonly sold for placement on chair legs to prevent scuffing hardwood floors.
  12. 32kcolors
    32kcolors
    Expand Collapse
    Senior Member
    5,728
    934
    124
    Redondo Beach, CA
    There should already be two form bumpers on the license plate area from factory. Didn't your car come with them?
