1. Offline
    jdcollins5 Senior Member
    Start a Conversation
    Aug 30, 2009
    3,267
    646
    Wilmington, NC
    Your Vehicle Year:
    When I first got my car I had an issue trying to keep the film off of the inside of the windshield. Even with Windex it would leave streaks. I found out that old newspaper worked best.
    I then read where others were just using a damp cloth to clean their dash and not any interior protectant. Ever since I quit using any type of interior dash protectant I have not had any further issues with this film.
    A couple of weekends ago I noticed that the dash part closest to the windshield looked like it was beginning to discolor ever so slightly. I grabbed a bottle of the ArmorAll interior spray, wet a rag and applied a thin film to this part of the dash and then the rest of the dash.
    After the first day of sitting in the hot sun in an asphalt parking lot at work I again have a film on the windshield.
    Does anyone know of a good dash protector that will not give off an oily film but will help with the dash fading ?
  2. Offline
    vvDO New Member
    Mar 15, 2012
    Santa Barbara
    Your Vehicle Year:
    I have the film and I have never used cleaner on the dash just a damp cloth however was going to start using armor all, guess I won't now.
  3. Offline
    Feri Member
    Jun 25, 2011
    298
    Maldon Victoria Australia
    Your Vehicle Year:
    That film was common with older plastics and is a result of the plasticiser evaporating and condensing on the windows. Armour all has a lot of volatiles in it which is why it stays "wet". These also condense on windscreen glass. Prius glass is UV blocking. I'd be surprised if the dash was discolouring due to UV.
    1 people like this.
  4. Offline
    wick1ert Senior Member
    Dec 3, 2009
    1,293
    173
    Delawhere
    Your Vehicle Year:
    I've read that the best way to protect it is just a damp cloth and no armorall. I just wipe it down, and after 3 years don't see any discoloring happening. I"ve heard someone I know likes Blech White (I think that's how it's spelled).
    1 people like this.
  5. Offline
    ataylorracing ataylorracing
    Jan 15, 2012
    152
    27
    Fishers, IN
    Your Vehicle Year:
    Using plain old newspaper should work.
  6. Offline
    d2mini Active Member
    Sep 7, 2011
    521
    100
    Houston
    Your Vehicle Year:
    I usually use a mild, ph balanced interior cleaner.
    I just picked up my first bottle of this stuff. Only used it once so far but seemed nice, and I was able to use it on the whole interior. The softex seats, the dash, the door panels, the steering wheel, etc. But not the display screens.
    http://www.detailersdomain.com/Optimum-Protectant-Plus_p_177.html
    1 people like this.
  7. Offline
    hyo silver Away
    Mar 2, 2005
    14,882
    1,190
    Sunset
    Your Vehicle Year:
    I find something called '303 Aerospace Protectant' does a great job on plastics, without releasing a film that coats the windows.
    1 people like this.
  8. Offline
    tumbleweed Senior Member
    Oct 3, 2005
    3,968
    616
    Eastern Oregon
    Your Vehicle Year:
    I use it also, works great and doesn't leave a film.
    303 Products, Inc.: 303 Aerospace Protectant
    I get it at Ace Hardware.
    1 people like this.
  9. Offline
    32kcolors Senior Member
    Jul 14, 2009
    4,909
    684
    Redondo Beach, CA
    Your Vehicle Year:
    There's no reason to use anything on the dash. The windshield is already tinted 80% and has 100% UV cut rate.
  10. Offline
    car compulsive Active Member
    Aug 6, 2011
    556
    162
    Michigan
    Your Vehicle Year:
    Just say no to Windex and Armorall. Over the past 10+ years, I've been using these products with great success:
    - Plastics: 303 Aerospace
    - Glass: Stoner Invisible Glass - absolutely the best consumer window cleaner for streak-free finish. I've always used the aerosol can, but it's also available in a pump. It comes in a black & yellow container.
    1 people like this.
  11. Offline
    cit1991 New Member
    Apr 5, 2010
    291
    89
    Tulsa, OK
    Your Vehicle Year:
    That film on the window is plasticizer. Armor All is a water emulsion of plasticizer. It's great for replenishing dried plasticized materials, but then it does evaporate, and condense on the cool window.
    Plasticizer makes hard plastics soft. The classic is vinyl, which is plasticized PVC. PVC is a very tough plastic, but it's also hard as a rock. Think of PVC pipe. That's pure PVC. The plasticizer comes as a thick liquid. You melt the PVC and mix in the liquid. Then when it cools, you have a soft, flexible, but still tough plastic (you call it vinyl). Over time the plasticizer evaporates and the soft plastic becomes harder and it also shrinks (as part of it's volume disappears into the air).
    Other plastics also can have plasticizer. I had a nice window shade for the car, but the silver coating over the fabric must have been plasticized, since it always left that blue haze when I used it.
    1 people like this.
  12. Offline
    BruceInOKC Junior Member
    Jul 29, 2009
    92
    Oklahoma City, OK
    Your Vehicle Year:
    I agree. The Stoner Invisible Glass is the best window cleaner I've used. A lot of detailing shops use wet newspaper. However, newsprint leaves ink on your hands and Stoner cleaner contains strong chemicals. Either way, try to wear protective gloves. I buy powder-free latex gloves in Walmart's pharmacy area.
    The 303 Aerospace Protectant sounds promising, although it's a new one to me. Their website says it's recommended by manufacturers and fights UV rays. The reviews I found on the product were positive. Some people said it can be difficult to find locally, so it might require an online purchase.
  13. Offline
    stream Senior Member
    May 12, 2008
    2,977
    442
    Long Island, NY
    Your Vehicle Year:
    I've been using 303 for a long time with great results. Although I haven't used it--or anything else--on my Prius interior. Dusting with a California dash duster is all that's ever needed.
  14. Offline
    phoenixgreg Senior member
    Apr 7, 2010
    671
    118
    Phoenix
    Your Vehicle Year:
    I've been using 303 for years, but on my hot tub vinyl top. It's a great product also for those black rubber seals around the doors and hatch of the Prius. Keep in mind that it might leave a high luster if you use it on the dash plate which could generate reflections.
    303 can be found at your local pool and spa supply store.
  15. Offline
    Jul 29, 2009
    92
    Oklahoma City, OK
    Your Vehicle Year:
    Thanks, I never would have thought to try a pool supply store.
  16. Offline
    WE0H My 1st Prius & my 17th anniversary present
    Mar 25, 2010
    2,409
    341
    Your Vehicle Year:
    Got my vote for 303. I have been using it for years on my paddling dry top latex gaskets. They stay like new with 303 worked into them. Add a paddling shop for a source of 303. I would not hesitate to use it on any rubber or plastic material that you really care about.
    Something else I have used in the past on plastics is aerosol furniture polish. Lemon Pledge or any other brand name spray on polish. It keeps plastic from drying out. It does leave a very slippery surface and shiny so be aware using it on the top side of the dash.
    Mike
  17. Offline
    Aug 6, 2011
    556
    162
    Michigan
    Your Vehicle Year:
    While 303 works for door seals, it doesn't last very long and doesn't cure noisy, creaky seals very well. (Common problem on my old Lexus LS430) The best product I've found for door seals is Shin Etsu grease available at the Honda parts counter. You will likely need to have them order a tube (about $20) as they often only have one in stock which is used by all of the mechanics when needed.
  18. Offline
    richsc New Member
    Jun 29, 2009
    59
    Washington DC
    Your Vehicle Year:
    I will have to try that 303. However, I found a microfiber cloth on a stick wipes all the film off and keeps me from straining to get into the far reaches of the windshielf.
  19. Offline
    Mar 25, 2010
    2,409
    341
    Your Vehicle Year:
    Would that be one of those green cloths on the plastic stick? Sprayed with a mist of water? I use one of those, works great.
    Mike
  20. Offline
    wjtracy Senior Member
    Sep 19, 2006
    2,515
    313
    NOVA
    Your Vehicle Year:
    We have a dust brush we use on the dash as needed.
    Also we started using the Invisible Glass cited above (got at Walmart) on the windows to help minimize the inside film.
Share This Page
