1. Offline
    grand total New Member
    Sep 9, 2007
    Message Count:
    121
    Ontario, Canada
    Your Vehicle Year:
  2. Offline
    ggood ggood
    Jan 17, 2004
    Message Count:
    1,917
    276
    Houston, Texas
    Your Vehicle Year:
    Actually, this version seems to have corrections to the earlier version posted by Prius team; such as correctly referring to turning radius, rather than turning circle, and no longer having the tire size error.
  3. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    MPG is also corrected. No need for the deletion.
    A 34.2ft turning circle w/ 15" tires, and a 36ft turning circle w/ 17" tires. One more reason not to go big ;)
    One of the specs appears to be a bit misleading though:
    Front Disc Rotor Diameter: 10.0"
    Rear Disc Rotor Diameter: 10.2"
    While the rear discs would appear larger, what is the overall swept area between the two? From one of the photos of the rear suspension on the engine/suspension display, it would appear we have a lever operated drum brake within the rear discs for e-brake or parking brake. After seeing some of the design flaws surrounding a cam-actuated parking mechanism on rear discs (they would corrode, then stick in the engaged and burn up the rear pads/rotors on some cars).
Share This Page
