1. Offline
    JimboK One owner, low mileage
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    I've been reluctant to add an EV switch. I haven't seen many (any?) folks with the mod come out and say with certainty, "It saves me fuel." Therefore I couldn't justify spending the money or the time.
    But as time goes on I become increasingly aware of this remarkable car's subtle -- and sometimes baffling -- nuances. What moved me to finally consider an EV switch is frustration with the ICE running between a string of 4 stoplights, most of which are usually red, in the middle of my commute. They're not far enough into the commute for the car to be in S4 operation. They're too far apart to "pedal-feather" EV without inciting hostility behind me, but too close to hit 35 MPH to get the ICE to shut off.
    (For the uninitiated, 5 distinct warmup stages -- labeled S1, S2, S3a, S3b, & S4 -- have been described. See this paper for more. Though there may be some question as to the exact temperature and time thresholds where stage transitions occur, the behaviors are unmistakable. To the point of this post, until the car reaches S4, it will not do an ICE-off glide unless the glide begins at a speed >34 MPH.)
    As another example, on my morning commute I have a stop light, usually red, about 200 yards before I turn left into the office lot. Again, traffic is too heavy for pedal-feathering EV from the light into the lot. But even at the end of this short commute, the car often doesn't make it to S4. So after I give it the gas at the light, the ICE often stays on until I approach my parking space. I watched the ScanGauge one recent morning during this episode. Trip MPG went from 75.4 (at the light) to 74.3 in about 300 yards.
    I considered the Coastal switch, as I described here. In the midst of that thread Hobbit made an offer to install a "home-grown" model for me at Hybridfest. Frankly I had been a bit intimidated by others' descriptions of installation; I'm somewhat "mechanically challenged." That's why I first leaned toward what others reported as an easy installation routine offered by the Coastal product. But Hobbit got me thinking: If the home-grown approach is simple enough, and if he has time and the willingness, to do it in the midst of all the activities and hoopla at Hybridfest, just maybe I could tackle it myself. So I began studying the approach with its variations described here and elsewhere.
    I primarily used Evan Fusco's instructions, featured (with photos) on CalCars' web site. Thanks to that terrific writeup, installation was a breeze, other than one minor problem of my own creation. More on that in a minute.
    I had previously disassembled the dash to install an integrated XM radio unit, so the prospect of removing a couple of vent panels and the lower glove box never bothered me. Harvesting the pin from the steering wheel was a snap. Evan's instructions suggested using a jeweler's screwdriver or paper clip to release the retainer clip on the ECU plug, but I found needle-nose pliers worked better. No problems soldering the wire to the pin. It was a tight fit to get the pin into the plug, but I got it. Needle-nose pliers helped there too. Rather than splicing the ground wire into an existing wire (I didn't feel quite that adventurous), I attached it to a bolt at a metal attachment point of some sort behind and toward the top of where the AC vent dash panel goes. After attaching the ground wire I tested the assembly by turning the car on and touching the wire ends together. I got the expected beep and no ICE activation.
    From there, no problem using the coat hanger to snake the wire through the dash innards to other side. My self-imposed problem was with the dash plug to which the switch would be mounted. Per Evan's instructions, I had snipped and cut away most of the fins in the middle of plug's backside. My mistake was not making sure enough had been removed to make room for the plastic nut on the back of the switch. I could have easily -- and should have -- tried the nut before soldering the wires to the switch. But now with the soldering complete and the wires smack in the middle of my work area, I had to delicately cut away little bits of plastic until I could get the nut threaded onto the back of the switch. That probably added about 15 minutes to the job.
    But I got it done. The whole job, moving deliberately and carefully along the way and counting the extra time needed to correct my flub, took about two hours, maybe a little less.
    And it works like a charm. It performs exactly as expected in that 4-stoplight stretch described above: I hit the switch as I pull away from the first light, with enough electric-only acceleration to get me from one to the next without provoking road rage behind me. I turn it off after I pass through the last one and move on to normal acceleration. At other points in my travels yesterday it was cool to be able to shut off the ICE at will when it wasn't needed and wouldn't shut off on its own.
    Those who consider the switch should consider the potential for misuse. The clear consensus among current users is that it could cost fuel efficiency if overused, drawing the battery down so much the ICE runs when it otherwise wouldn't. Over the last couple of weeks I've been preplanning when to use it -- and when not to use it -- during my normal travels. That should reduce any tendency for a knee-jerk push of the button just because it seems at the moment like the right thing.
    Who knows how much fuel it saves in the long run. I don't plan any controlled studies. But it's cheap and, it turns out, relatively easy to install. And I'm convinced it will save frustration from seeing the ICE running when I know it doesn't have to. That alone makes it worth it.
  2. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    Jim's finally coming to "see the light"...Can-View ordered and EV mod #1 done (you'll be dreaming about the nice illuminated OEM button soon enough).
    Glad the instructions help.
    Although my comments when people ask about FE are "no, don't expect it to help", I am certain that I use it in such a way that it helps my FE...in the conditions you describe and a few others... But that's definately more of a nuance of hypermiling, not a solution for those getting 40mpg and wanting a magical fix and thinking extending battery use will do it.
  3. Offline
    philmcneal Taxi!
    Jan 16, 2006
    281
    Burnaby B.C
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(efusco @ May 26 2007, 07:46 AM) [snapback]450384[/snapback]</div>
    yeah the only reason i'd install ev mode is to truly pulse engine ev glide when in stage 3 or higher,
    when having a block heater, your immediately in stage 3 (after idling and letting the engine run in its enrich fuel mode), so in theroy the ev button can help your mileage if you pulse with the engine, then coast and kill the engine immediatly , reaping the benifits, even if your trip is only 1 mile, you can pulse for .2 of that mile and coast the rest, still giving you a good mpg score despite the enrich mode the prius runs in when the ICE first comes on... even when the engine is hot!
    why it goes into that mode i have no idea, its truly a waste of fuel. I have can view but no EV MODE, so in theory if i just tap into switch 27 in the ECU, then can i just use CAN VIEW EV button and skip making a button for myself??
  4. Offline
    jstack New Member
    Jul 28, 2005
    211
    38
    Chandler Arizona
    Your Vehicle Year:
    I
    I also bought the EV mode option for about $39 from coastal technologies. Just 3 wires connected and I can now force EV mode anytime below 35 mph. It really makes me want the PHEV plug-in hybrid option. They will be available with in a year and I'm ready to get it. 100+ mpg will be sweet.
  5. Offline
    Rangerdavid New Member
    Jun 13, 2006
    1,314
    Boone, North Carolina
    Your Vehicle Year:
    thanks for the review Jim, your efforts may give some of the rest of us courage enough to try this ourselves. Meanwhile, enjoy!! (and if you ever come to the mountains down my way, let me know!!)
  6. Offline
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(philmcneal @ May 29 2007, 09:50 PM) [snapback]451797[/snapback]</div>
    Hmm, you got me there. I just got word from Norm yesterday that my Can-View was shipping, so it will be a few more days before I get it.
    Rangerdavid, my sister lives in Boone, so if I get down there to visit her I'll give you a shout.
  7. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    I'd forgotten about CAN-View's ability to enable EV mode....that may be your best option while you're into everything Jim.
  8. Offline
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(efusco @ May 30 2007, 08:58 AM) [snapback]452013[/snapback]</div>
    I just reviewed Norm's site, and from what I can make of it, this is an option only with the optional relay board for PHEV conversions. Am I missing something?
    Regardless, I think I'll leave the EV button as is. I'm sure I'll be fiddling with Can-view enough as it is.
  9. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(JimboK @ May 30 2007, 08:22 AM) [snapback]452018[/snapback]</div>
    Hmmm, I don't know... I've gotten lost in all the various iterations of CV. All I know is that I have a button on the CAN-View screen that shows what EV mode/stealth, ICE spin, whatever and that supposedly there's a place to connect a wire to the CAN-View that makes that button functional for enabling EV mode. I may need an extra circuit or something though...I don't know.
    Frankly, I like the dedicated EV button on the dash...it doesn't move and I don't have to change screens to tap it or anything.
  10. Offline
    markderail I do 45 mins @ 3200 PSI
    Sep 13, 2006
    2,260
    152
    Pierrefonds (Montreal) Quebec Canada
    Your Vehicle Year:
    My 2006 Prius is rented 4 years. The service manager said not to install the EV, it would void my warranty, and he would refuse to service the car for warranty paid-for repairs if installed.
    Not a happy camper.
    I am glad that "kits" have been coming out specifically for the Prius (EV-15, EV-30), so when I buy outright the car in 3.5 years I'll simply continue the same monthly payment to pay for the batteries.
    From my house to my office is about 4 miles one way, with stops & lights. The EV mode would save me lots of gas...if I could install it.
    :unsure:
  11. Offline
    Cheap! New Member
    Apr 3, 2006
    1,157
    <div class='quotetop'>QUOTE(Mark Derail @ May 30 2007, 11:28 AM) [snapback]452131[/snapback]</div>
    It looks like you need to find a new place to have your warranty work done. He might refuse it but another shop right down the road might like to get the work. Then again, what are we talking about, a Prius battery going bad because of an EV switch? You have a better shot at winning the lottery.
    BTW, you can probably find Toyota dealership that will install it for you if you look hard enough.
  12. Offline
    figmentor New Member
    Aug 9, 2005
    22
    East Lansing, MI
    <div class='quotetop'>QUOTE(Cheap! @ May 30 2007, 03:51 PM) [snapback]452252[/snapback]</div>
    For what it's worth, I just took my EV switch out! I am trying anything possible to get my mileage over about 43 including new tires, Mobil 1, 42/40 tire pressure (despite the extra wear that nobody talks about), the block heater and pulse and glide practice. 35,000 miles and I've only done better than 45 a few times. Maybe it's the place I live and all these %^$$ stop lights and short trips. If there are any hypermilers within 100 miles of Lansing, MI, let me know so I can come visit you for a roadtrip, PLEASE!!! contact me at figmentor@yahoo.com
  13. Offline
    • Moderator
    efusco Troll Slayer
    Nov 26, 2003
    19,635
    881
    Nixa, MO
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(figmentor @ Jun 5 2007, 11:48 AM) [snapback]455749[/snapback]</div>
    Taking the EV out won't help anything and eliminates it for potential benefit later. You didn't say anything about your commute so it's a bit difficult to make suggestions. By 35k you should know the car quite well, so it's very odd that your mileage is so low...I have to assume it's your driving style and commute that are the major factors since you seem to have tried everything else.
  14. Offline
    Sep 13, 2006
    2,260
    152
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(figmentor @ Jun 5 2007, 12:48 PM) [snapback]455749[/snapback]</div>
    When, I'm in litres/100km, six months driving and have done 8800km so far.
    Using the eForeCourt converter, my winter mileage is (8.5l/100) 27.6 mpg.
    This last month has been warm, my average is (5.7) 41.2 mpg.
    For next winter I plan on getting the block heater & blocking the grill. I noticed when "warm" in the winter time, coming out of an underground indoor parking in winter, my avg was 7.2 or 32.6 mpg.
    The biggest change for me to get good mileage above 40mpg was quick start-ups to speed then coasting + feathering to the next stop.
    Life is short - why worry about breaking the 40-45 mpg barrier? A 50mpg'er is only doing 14% better than you.
    :unsure: um that's alot more :eek: How do they do it?
    Only thing that explains it is 2 or 3 stops to the highway and driving below 50 MPH daily trips of 20+ miles.
    I had to go to downtown Montreal a few days in a row, during traffic hours. My average shot way up to 45.5 MPG.
    Also funny how using the A/C gets better MPG than two windows down on my trips. Less drag.
  15. Offline
    Apr 23, 2005
    3,840
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(efusco @ Jun 5 2007, 09:54 AM) [snapback]455758[/snapback]</div>
    I rarely use the EV mode; mainly to move around in a large parking lot. If it were me, I'd leave it in and not try to use it for commuting.
  16. Offline
    Rest New Member
    Aug 13, 2005
    1,168
    CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(jstack @ May 30 2007, 02:29 AM) [snapback]451950[/snapback]</div>
    This is why I haven't bought this product yet. The Prius can do EV mode up to 41mph, why would I want to reduce this speed down to 35mph just to do it more often? I don't understand why the reduction in speed is even there with this product.
  17. Offline
    KD6HDX New Member
    Oct 30, 2005
    256
    Chino Hills,CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Rest @ Jun 5 2007, 04:54 PM) [snapback]456105[/snapback]</div>
    ...young grasshoppah, soon you will be able to snatch the pebble from my hand....
    EV Shmevee, oy vay EV
    Best just to drive it with a very light foot and save save save.... IMHO
  18. Offline
    May 1, 2006
    2,817
    170
    Chesterfield, VA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Rest @ Jun 5 2007, 07:54 PM) [snapback]456105[/snapback]</div>
    I'm not exactly sure what you're suggesting, but you don't "reduce speed" just to use the switch. The switch doesn't dictate how you drive; it simply enables more efficient driving at lower speeds. It's one tool of many in the box.
    Part of the idea is to enable ICE shutoff at lower speeds where, somewhat paradoxically (IMHO), it's more difficult than at speeds of 35-40. In particular, you cannot do an ICE-off glide from speeds of less than 35 MPH while the car is in S3, which may linger for a considerable time during warmup. Many times during S3 I've either accelerated to 35 just to allow the ICE-off glide or resigned myself to the ICE running during the glide. Either way fuel is wasted. Now at lower speeds I shut the ICE off at will after a brief S1.
    I've described other low-speed applications in the original post.
  19. Offline
    Kestrel Bird geek
    Dec 28, 2005
    59
    SF Bay Area, CA
    Your Vehicle Year:
    There is no change to what the car can do. The software will kick you out of EV "mode" when you go above 34 mpg, but that doesn't mean that the ICE turns on at that point. Rather, instead of you telling the car how to run, the computer makes the battery/ICE decisions again. I've had no problems continuing to run only on the battery at speeds above 34 even though I get the beeps that indicate I'm out of EV mode. The switch only means that you can override the computer and force it to stay in EV mode below 34.
  20. Offline
    Jan 17, 2006
    6,034
    345
    Northern CA
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(Mark Derail @ May 30 2007, 09:28 AM) [snapback]452131[/snapback]</div>
    Well, he can't legally do that. I suppose he can refuse service to anybody, but the warranty cannot be "voided" if nothing is damaged by what you do. Federal law.
    Unlikely. It may save you a tiny bit at best. Will use more at (the more likely) worst case.
Share This Page
