1. Offline
    mcmoyer Junior Member
    Start a Conversation
    Mar 26, 2008
    66
    Fort Worth, TX
    Your Vehicle Year:
    I've got 127k on my 2008 Prius and I finally had to have something fixed on it. Was driving along when the triangle exclamation symbol popped up followed by almost every other light on my dash, which was then followed up by complete shutdown. Figured out that if I let it sit for a few minutes, I could drive it for a few minutes. Doing the repeatedly, I was able to make it to the dealer and drop it off after hours.
    Waited for the call in the morning. First call came around 10am when they told me they were trying to track down parts to finish the estimate. Got the real estimate around 12pm. It was a little over $1000. This is what they said "needed" to be done.
    1. Back brakes needed to be tightened
    2. Tune up
    3. Air Filter replaced
    4. Cabin Air Filter replaced
    5. Throttle body cleaning
    6. 12v Battery replaced
    7. Invertor pump replaced
    8. Serpentine belt replaced.
    Interestingly enough, I had just cleaned my cabin air filter 2 days previous. I asked what all they did for a "tune up" and he replied, "we change the spark plugs" -- and they charge $156.00 for this! I asked why I needed a throttle body cleaning and he told me that it was really dirty and was contributing to my poor performance and decreased mpg. I hadn't complained about poor performance so I asked him, "Do you mean that I should be getting better than 57mpg?" --- he had no reply.
    I told him I'd call him back. So I went online and did some research and figured out the only thing setting those codes was the invertor pump. Given that my battery is 4 years old, I decided to let them replace that also.
    Total bill was $610, $229 for the battery and $381 for the invertor pump. On the way home, stopped and got an air filter ($14), 4 bosch iridium spark plugs ($28), serpentine belt ($8). Changed the air filter & spark plugs in about 30 minutes last night. Old plugs didn't show much wear at all. Also, although it looked pretty darn clean to me, sprayed down the throttle body with carb cleaner.
    Still feel like I overpaid, but at least I said quite a bit from the stealership.
  2. Online
    SageBrush Senior Member
    Jun 4, 2008
    7,421
    1,231
    New Mexico
    Your Vehicle Year:
    Inverter pump or Engine pump ? IIRC the inverter pump is covered by Toyota in a TSB or recall notice.
  3. Offline
    Mar 26, 2008
    66
    Fort Worth, TX
    Your Vehicle Year:
    Invertor pump, but I think the recall ended with the 2007's...at least that's my understanding.
  4. Online
    Jun 4, 2008
    7,421
    1,231
    New Mexico
    Your Vehicle Year:
    Ah, right you are. I tracked down the SSC, it indeed is for 2004 through some of 2007 MY cars.
    Anyway, kudos for avoiding the dealer junk additions.
    Hopefully your new pump will last for many years, but be aware that a DIY replacement is pretty easy. I define 'easy' as something I performed, so just about anybody else can too. ;)
    The pump on my car never acted up, but I replaced it around 120k miles when it was time to exchange the coolant fluid. Similarly, I plan to replace the engine pump as preventive maintenance when I exchange the coolant for that circuit. This works out to cheap insurance (about $125 for both pumps.) I avoid inconvenient downtime for the car, and so far as my wife is concerned, the Prius NEVER breaks down.
  5. Offline
    Mar 26, 2008
    66
    Fort Worth, TX
    Your Vehicle Year:
    Yeah, if I hadn't needed my car so quickly, I think I would have attempted this myself. I've always done all the repairs on my previous vehicles....but between the intimidation of working with the hybrid tech and the time crunch, I punted and let the dealer do it.
  6. Offline
    usnavystgc Die Hard DIYer
    Jul 29, 2011
    1,360
    375
    Bowling Green, KY
    Your Vehicle Year:
    Just like I alway say, your plugs showed virtually no wear at all. I would have cleaned them with a wire brush and reinstalled for another 128,000 miles of worry free driving @ 57 mpgs.
  7. Offline
    Britprius Senior Member
    Jun 14, 2010
    2,584
    591
    Herefordshire England
    Your Vehicle Year:
    Sorry Usnavystg wire brushing plugs is a no no. Doing this leaves particals of metal from the brush embedded in the insulator of the plug, providing a path for the ignition high voltage to the metal side tube of the plug. This can be seen after brushing as a discoloration of the insulator. Light sand blasting is ok followed by a clean air blast to remove any sand particles trapped in the plug. Fitting new plugs is better.
    HaroldW likes this.
  8. Offline
    PNorth Junior Member
    Oct 29, 2008
    23
    Toronto, Canada
    Your Vehicle Year:
    Where did you learn how to replace the inverter pump?
  9. Offline
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
    I suggest you write to the Toyota Customer Experience Center, provide a copy of your repair invoice, and ask if they will be willing to provide you a refund for the inverter coolant pump replacement. Cite the LSC (Limited Service Campaign, do a search for that on PriusChat to get the details) and point out that the problem apparently continued to persist with the 2G newer model year production. Good luck.
    richard schumacher likes this.
  10. Offline
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
  11. Offline
    kenoarto Member
    365
    52
    Chicago, IL
    Gap on those old plugs needed to be adjusted. But that age, it's probably wise to replace with new ones.
  12. Offline
    kammssss Member
    Mar 30, 2007
    204
    46
    Damn! That inverter pump is expensive, and that is Texas rate. I wonder how much it cost in Los Angeles?
  13. Offline
    Jun 14, 2010
    2,584
    591
    Your Vehicle Year:
    Interesting to note how short the insulator is on the Bosch plug compared to the NGK.
  14. Offline
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
    Which shows you the plug is probably in the wrong heat range and may not last as long as the original equipment plugs.
    usnavystgc likes this.
  15. Offline
    Jun 14, 2010
    2,584
    591
    Your Vehicle Year:
    Knowing the Bosch part number is the only way to tell the heat range as other factors such as depth and dia of insulator and, dia and material of central conductor. Bosch often use copper for the center conductor because of it's heat conducting capabilities.
    If it is in the wrong heat range the life of the plug would be the leased of my worries. Pre ignition due to over heated spark plugs can be very damaging to pistons, and the anti knock censer in that situation is of no help raising combustion temperature by retarding the ignition timing.
  16. Offline
    Mar 26, 2008
    66
    Fort Worth, TX
    Your Vehicle Year:
    Well, as of Friday, it's not a worry for me anymore...took the plunge and got a Prius V! Wanted one as soon as it was released and ended up getting a decent deal on the new one.
Share This Page
