1. Offline
    eluo New Member
    Start a Conversation
    Sep 6, 2007
    30
    Commack, NY
    Your Vehicle Year:
    Just want to share my find with everyone. Hopefully this info is worthy of a new thread...
    The programming procedure below enables SKS functionality for NEW SKS key fobs! This is contrary to everyone's post about SKS functionality being non-user programmable. It worked for me and I'm sure it will work for others as long as the Key fob is new.
    http://priuschat.com/forums/attachments/gen-ii-prius-care-maintenance-troubleshooting/23259d1273397060-important-experience-key-fob-programming-issues-d__applications_prius_key-programming_smartkey-pro.pdf
    Thanks to AbuS3ood for providing the document.
    2 people like this.
  2. Offline
    Hytec New Member
    Aug 7, 2004
    236
    MS Gulf Coast
    Your Vehicle Year:
    Thank you for this information. I asked about a replacement fob a few weeks ago and was told that programming would cost about US$125, after paying US$200 for the new fob. :eek:
  3. Offline
    osofast10 New Member
    Jan 10, 2011
    61
    Va
    Your Vehicle Year:
    will try this out once i get home... crossing my fingers that it works!
  4. Offline
    jelloslug It buffed right out!
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    This is just the same procedure for the non-SKS keys. Are you sure that it works for SKS ones?
  5. Offline
    Tw3nty New Member
    Jul 25, 2011
    16
    lexington,SC
    Your Vehicle Year:
    I am tired and my wife has given up. We havevtried all of these thread ideas. Now she is going to the dealer. I feel like I am going to be screwed. I feel lost and scared. Any advice about how to provide being ripped off by dealer. Feel lost and lead astray.
  6. Offline
    2k1Toaster HID Guru
    Feb 14, 2010
    3,195
    761
    Rocky Mountains
    Your Vehicle Year:
    Nothing you can do. Go to the dealer, get it programmed drive home happy with 2 keys.
    The alternative is to buy the Toyota Techstream computers and a subscription to their high end service contract program that allows access to the encryption algorithms used in the keys. For about $4000 and a subscription you too can do it at home. Or just go to the dealer wait a few minutes and drive away $100-$300 poorer.
  7. Offline
    fgoodyear New Member
    Aug 28, 2007
    187
    Tillson, New York
    Your Vehicle Year:
    The whole thing about it costing $125 to get a key programmed is a ripoff. It takes about 30 seconds to program all this. They should do it free whether or not you buy the key from Toyota I owned a 1999 Nissan Maxima. An aftermarket remote start was dealer installed when new. At 130,000 it started causing the keys to lose the program. I had to tow it to the dealer and they charged me an hours labor....... after I watched them take a handheld computer code reader out to the car, hook it up and the car started.. Took it into the shop and less than 10 minutes later I was told it was ready to go...... still got charged for an hours labor:cool:
  8. Offline
    2k1Toaster HID Guru
    Feb 14, 2010
    3,195
    761
    Rocky Mountains
    Your Vehicle Year:
    It's called profit.
    I am sure many of the items you buy on a daily basis all have a markup associated with them as do the ones you buy occasionally and the same with services.
    I gave the solution above. If you find it a ripoff, you to can program your own keys as many times as you want from the comfort of your couch. But when it is all said and done, you have spent much more than just going to the dealer.
  9. Offline
    anthonylokrn Member
    Apr 8, 2011
    109
    Your Vehicle Year:
    Call around if you have a few Toyota dealerships in your area. The first 2-3 dealerships I called quotes a price range of $75-$125, eventually I found one that said that they program it for free, though it does not include cutting the physical key.
  10. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    No one can steal your car unless you give them your key or they drag it on to a flatbed. Either the dealer rips you off, or the car thieves do.
  11. Offline
    ICUL8RG8R New Member
    Jul 18, 2011
    Bonney Lake, WA
    Your Vehicle Year:
    I purchased my 2007 Prius Touring Pkg #6 a few weeks ago and it had only 1 key. I live in the Tacoma/Seattle area and called around and most quotes were around $275 to $350 for the key and programming. BURIEN TOYOTA near the SeaTac airport had the best rates - so low compared to the others, that I thought hmmm...what's the catch? No catch! Only $159 for the Smart Key and $59 for programming (and they referred me to a locksmith who copied the door key for only $4). Tried to get the dealer closest to my home to match their price, but they would not budge. So had to drive a little further - but hey, I'm driving a Prius! I probably burned less than half a gallon of gas!
    SteveWlf and olerox like this.
  12. Offline
    eluo New Member
    Sep 6, 2007
    30
    Commack, NY
    Your Vehicle Year:
    I wasn't expecting SKS to work when i programmed my fob but it did. Also if you read the second sentence of that pdf document, it indicates that SKS and remote door lock will work after going through registration.
  13. Offline
    CharlesJ Member
    Dec 13, 2008
    455
    Monterey
    Your Vehicle Year:
    So, it is possible to find a decent dealer after all. :D
  14. Offline
    fanamingo New Member
    Jul 14, 2010
    Virginia
    Your Vehicle Year:
    eluo, can you confirm that your Prius is USDM? I haven't seen anyone else confirm that this has worked for them, but I'll give it a try and report back as long as your Prius was also sold in the US.
  15. Offline
    comatoes I like power, but frugality trumps.
    Jun 2, 2011
    186
    MD
    Your Vehicle Year:
    I got a second key by way of my used car dealer going through a Toyota dealer. I believe the fob cost $150 and the programming was $50. $200 for a second key ;)
  16. Offline
    Oldwolf Prius Enthusiast
    Feb 15, 2011
    569
    48
    NC
    Your Vehicle Year:
    I would like to know if anyone has tried the steps yet in the pdf file. Will it work?
  17. Offline
    eluo New Member
    Sep 6, 2007
    30
    Commack, NY
    Your Vehicle Year:
    Not sure how i can confirm other than the fact that I bought it new directly from a Toyota dealership in NYC with 3 miles on the odometer. Please do try and post back your result.
  18. Offline
    Jul 14, 2010
    Virginia
    Your Vehicle Year:
    That's all I needed to know. Thanks! I just wanted to make sure you didn't live in Europe or Australia and have a car that might have slightly different programming. I just ordered a new key and will report back once I try to program the car to accept it.
  19. Offline
    smith6806 Junior Member
    Apr 6, 2009
    St. Petersburg, Florida
    Your Vehicle Year:
    Eluo:
    Could you explain step 8 and 9 as to the choosing of a mode? It is unclear to me if, after pressing the power switch, you need to also do something with the lock to indicate which mode is being selected, before removing the master key.
    Does successful completion of the procedure in the pdf also allow for operation of the car, or do you need to complete another procedure?
    Thank you.
  20. Offline
    eluo New Member
    Sep 6, 2007
    30
    Commack, NY
    Your Vehicle Year:
    To preform step 9, press the power button 3 times (slowly) without pressing the break. You will be in "new mode". Do this one more cycle (power button 3 times) to be in "Add mode". When you remove the master key (step 10) your Prius should respond with 2 lock and unlock cycle to confirm that you are in "Add mode" (step 11).
    I just test this with my Prius with "Confirm mode"; 3 cycle of 3 power button (9 presses all together) and removed the key. My Prius responded with 3 lock and unlock cycle.
    Hope this helps.
    1 people like this.
Share This Page
