1. Offline
    Mike500 Interessen-Gemeinschaft Prius
    Start a Conversation
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    I'm glad that I did it, today, and didn't wait until 10,000 miles.
    It was pretty dirty for 3k. I've posted my setup with Race Ramps, held the door down with a length of 10 gauge solid insulated copper wire hooked to the bottom of the door and the front of the plastic bottom cover. I used a screw on funnel that came with a Wedco drain container that I got over 10 years, ago from Ace Hardware. I don't use the drain pan container any more. That funnel screws to an anti-freeze or windshield washer fluid bottle, and has ribs that keep the drain plug from falling into the bottle. Unscrew the funnel, cap it, and I'm done. The funnel even work for the oil filter cap with minimal spillage. The filter cartridge drained nearly all the oil into the USED Go Jo hand cleaner bottle.
    I used Mobil 1 and installed my Custom neodymium rare earth magnet drain plug.
  2. Offline
    xliderider Active Member
    Apr 19, 2012
    857
    152
    Honolulu
    Your Vehicle Year:
    Nice setup. See anything in the filter media?
  3. Offline
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    Thanks,
    Not really. The oil was darker than I thought. The dipstick didn't say it all.
  4. Offline
    n0na Junior Member
    May 3, 2012
    88
    WA
    Your Vehicle Year:
    Keep in mind that, if the additives in the oil are working properly, the oil is going to turn dark very quickly. That's the additives at work. You can't tell the condition of the oil by its color.
  5. Offline
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    I already know that. Clean and NEW oil with the full additive package is always better than OLD oil.
    It's cheap insurance. I just wanted to get the metal "flash" and assembly lune out of the oil.
  6. Offline
    plsinger Junior Member
    Feb 19, 2007
    49
    Los Angeles
    Your Vehicle Year:
    Toyota synthetic actually has better stats than Mobil 1 and starts out darker than dyne or Mobil.
    It is specifically designed for vehicles with Atkinson cycle engines.
    Take a look at the Toyota video on that....you may want to rethink Mobil 1.
  7. Offline
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    Mobil 1 has a long track record of reliable service. I've used it for nearly 35 years. Mobil has done many many more lab test over the years than Toyota.
    Toyota has a self-serving interst in promoting their own oil.
    As long as Mobil 1 0W20 is approved for use in my Prius, I'll keep on using it. Competition is good.
  8. Offline
    Adam H Junior Member
    Jun 3, 2012
    60
    Your Vehicle Year:
    What about having oil changed at shops like Jiffy Lube?
  9. Offline
    Apr 19, 2012
    857
    152
    Honolulu
    Your Vehicle Year:
    I doubt that they would carry 0w-20 synthetic oil.
  10. Offline
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    They might NOT even have the cap wrench to take off and to install the composite oil filter housing cap.
  11. Offline
    Apr 19, 2012
    857
    152
    Honolulu
    Your Vehicle Year:
    Good point! (y)
    Mike500 likes this.
  12. Offline
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    Yeah, over the past 50 years, I've seen a lot of that "wipe clean" service, where the part was NOT replaced.
  13. Offline
    sURFNmADNESS Prii Family
    Jul 22, 2012
    68
    Omaha, NE
    Your Vehicle Year:
    You did not get the free 2 years service with your new V?
  14. Offline
    Mar 1, 2012
    953
    222
    Upstate, SC
    Your Vehicle Year:
    I did, but no oil change at 3k. I will take advantage of the 12 months service oil change as well as the 24 months.
  15. Offline
    KK6PD _ . _ . / _ _ . _
    Mar 24, 2008
    3,578
    616
    Los Angeles
    Your Vehicle Year:
    Only after HELL freezes over!
    Last time I used the Jiffyheads, they left oily rags on the manifold of my 4Runner, about a mile from the Jiffy shop I had smoke pouring out from under the hood!
    I quickly "U" turned right back to the Jiffyheads, pulled in and let them know in no uncertain terms,....gets the rags out, if anything is burnt, your paying for repairs.
    Two weeks later I got a coupon for a free oil change, I lightly burned the edges of the letter, mailed it back to them, with a note letting them know this is what happened last time, there will be NO next time!!!
    Mr Incredible likes this.
  16. Offline
    twoturnin New Member
    Jul 23, 2012
    Wilkesboro, North Carolina
    Your Vehicle Year:
    Got a youtube link "HOW TO" change oil in PRIUS V5 ??----2500 mile is going to be my first one. Took several cars past 200K---88 Suburban 252k---1999 LHS 203k--97 Cummins Dodge 381K all on Mobil One. Thanks Two
  17. Offline
    blisspacket Junior Member
    Aug 5, 2009
    26
    StAugustine FL
    Your Vehicle Year:
    Changed the oil today on our v, at 3310 miles. No signs of any "stuff" or flakes, and didn't expect any. I did find, as I found on our 2010 when we got it 3 years ago, that the dipstick is rough around the tip and I can conceive it chiseling into the dipstick tube as you slide it down the curved portion. You can feel that. So as I did with the 2010, I buffed that tip, and the feel is smooth now. I'd imagine this doesn't amount to much, and any particles would quickly embed themselves in babbit or get attracted to your magnetic drain plug.
    Chazz8 likes this.
Share This Page
