First time driving a hybrid
Discussion in 'Prius c Main Forum' started by da chung, Mar 8, 2013.
  1. da chung
    da chung New Member
    Honestly, Im not sure what Im doing...
    Im so confused by the whole EV mode and Eco mode...
    I drive to work and school everyday, local and freeway.
    Would I save more gas by turning on the Eco Mode?
    What should I do?
  2. DoPeY5007
    DoPeY5007 Member
    122
    17
    Eco mode puts less power to AC/Heater so yes, you save a little gas when you leave it in that mode.
    Mine is always in Eco mode unless I hit the button to turn it off by accident.
  3. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I leave mine in normal mode because I don't like the delay "ECO" mode has. Still gets awesome MPG. Just drive it normally until you can study the manual or ask questions here at PC.
  4. da chung
    da chung New Member
    Is that all it does with Eco?
  5. da chung
    da chung New Member
    The dealership guy told me the same thing, but when i drive it normal it says im only getting about 40mpg...
  6. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    If "ECO" is giving you better MPG, then stay in that mode if you need to. In my Prius II liftback, "ECO" only saves me gas in the summer by shortening the A/C compressor cycle, like DoPey5007 mentioned. I also drive the freeway about 90% of the time and "ECO" mode just dosen't make a difference.
  7. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Firstly, forget about EV Mode. The button for that only has a limited role - never in normal driving - any many people will happily never use it at all. Most of all, using the EV mode button is not about getting better fuel economy (its impact is actually the opposite overall). This also shouldn't be confused with the times when an icon comes on the display which says "EV" in a little green car symbol.
    The main question is therefore Eco Mode vs Normal. Eco Mode does exactly two things.
    • It makes the air con logic slightly less aggressive and more adaptive to what the car is doing, which reduces how much energy it uses up.
    • It changes how the main computer interprets your input from the accelerator pedal, although note that the range does not change - it still goes from 0% to 100% in both Eco Mode and Normal.
    The latter becomes mostly psychological. It basically means the initial part of pedal travel becomes less sensitive and you will have to push the pedal further to get the same response from the car. However what also happens is that the further part of the pedal travel becomes more sensitive and small changes to pedal input in that part of travel will have a much larger impact on the car's response. Pushing the pedal all the way down will have the same impact in both Eco Mode and Normal.
    Have a look at this post for diagrams and further explanation of this (look at both the post and the one two posts below it):
    Driving in the ECO Mode? | Page 2 | PriusChat
    Note the above link is for the liftback, so a "PWR" or "Power" mode is also shown, but this function is not present on the Prius c.
  8. PriusCinBlack
    PriusCinBlack Member
    145
    61
    If you're getting 40 mpg, you're probably doing 75, 80 mph on the freeway (or more). Try slowing down to, at most, the speed limit, and you'll likely get 50+ mpg. Slow down further, and you'll start getting into the 60's.
  9. fuzzy1
    10,039
  10. james cook
    james cook Member
    145
    36
    Louisiana
    eco mode makes the gas less responsive.
    turn off eco annd you accelerate faster.
    Just stay out of the PWR zone and you'll get great mpg's.
    I was doing 90 in a 70 dropping down to 85 to pass and my mpg was stuck at 24.7 mpg.
    also, don't drive this car at 90 mph unless you want to die.
    cknfts and B2FiNiTY like this.
  11. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I use EEV mode AS MUCH AS POSSIBLE. I leave ECO mode off. Now that it's getting warmer the car should be going into EV mode more often.
