Flat tire
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by theiding, Mar 30, 2012.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,795
    Undisclosed Location
    If your area has a local "U-Pull It" junk yard, I have found you can usually scavenge original vehicles scissor jacks and flat changing equipment sets for really cheap.
    The slight advantage being they usually are designed to be very small and take up as little room as possible.
    I bought an older used vehicle once, and only discovered after purchase that it was missing it's original OEM provided jack and tire changing tools. The cheapest way to replace it was a U-Pull It, junkyard where I was able to find the exact tool-set and get it for just a few bucks.
  2. Mike500
    Mike500 Senior Member
    2,593
    763
    Have you been to a "U-pull-it, lately?
    The jacks and tire tools are taken aou and sold with "fixed" prices in the check out room.
    With the lack of spare "donut" tires in new vehicles, they. too, will be taken out and sold individually.
    As more cars come without spares, the wrecking yards are going to realize that there will be greater demand for them.
    It;s called capitalism. The price will go up, just like the cost of gasoline.
    Since I purchased my "v' on Super Bowl Sunday, there is a $500 "premium" over MSRP for them.
    I got mine $460 below the MSRP sticker and got nearly $900 of "port installed" "add ons" with mine.
    Don't count on the donut spares going down or being "cast offs," like years, ago, when vehicles had space for full sized spares.
  3. The Electric Me
    9,083
    5,795
    Well this was a few years back. That's too bad. At least at the one near me, they used to leave them in. You had to be quick, agressive and a little lucky, but you could find them.
    I'm saddened to hear it isn't an option anymore.
  4. Mike500
    2,593
    763
    While "corporate welfare" under the Cash for Clunkers Program helped new car dealers and manufacturers, it really hurt the owners of older cars and those who can only afford oder used cars, as well as wrecking yards.
    Those vehicles turned in during the program could not be scrapped for parts or be resold.
    Paying a little for a spre tire right now means not paying a lot later, when the wrecker or the dealer has you over a barrel.
  5. Mike500
    2,593
    763
    The PIP takes the same spare as the 16x4 Celica and Corolla (2003 and up) 5 bolt pattern. There are a lot of them around that are 6 years or more in age. I wouldn't trust a 10 years old spare, even unused, that has resided in a hot trunk.
    Her's another good deal on eBay;
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    $60 delivered for a 2011 spare from a vehicle that had 3867 ODO miles on the car is probably the best deal around.
    Again, I am not affiliated with this eBay vendor.
  6. ernda
    ernda New Member
    43
    Beverly Hills, CA
    It isn't clear to me from the ebay listings of this vendor whether or not they are only selling the wheel sans tire.
  7. Mike500
    2,593
    763
    I've never seen the "donut" spare sold without the tire. It would not be worth his time to disassemble it ans sell it that way.
    Then, again, I havent seen everything. I'd call or email them, to be sure.
  8. theiding
    theiding New Member
    31
    Alameda, CA
    They said the hole was so far to the outside that it couldn't be patched. Given the wait I would have definitely gone for changing the tire had I had a spare.
    I was actually right next to an air pump when I noticed the hole (plus I own a little compressor as well) and this is the first time in my life the hole was too big to make it to a store.
  9. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    Again, really sorry for your experience theiding.
    Now we just have to wait for some unfortunate to discover any additional costs associated when using the factory supplied slime as well (wheel?, TPMS sensor?, ect...?).
  10. skyrunner777
    skyrunner777 New Member
    San Ramon
    This might seem like a silly question but for the prius plugins, where do you guys put the spare? There's obviously no room under the trunk carpet due to the battery. Do you just place it expose in the trunk?
  11. bisco
    48,862
    there is no spare.
  12. HaveNoCents
    HaveNoCents Conservative Tree Hugger
    299
    46
    Crystal Beach, Texas
    I'm sure he is asking those that choose to carry a spare.
  13. bisco
    48,862
    i would just lay it down in the back. where else can you put it, rear seat? roof?
  14. cwerdna
    cwerdna Senior Member
    12,544
    2,122
    SF Bay Area, CA
  15. HaveNoCents
    299
    46
    Pretty cool, but what I can't figure out is if it can fit there why didn't Nissan just make a deeper well in the trunk?
    iPad ?
  16. Mike500
    2,593
    763
    The easiest solution would be to position the tire over the trune panel in the position where you'd want it and place a piece of tape at the center. Go to the wrekhing yard and get a "j" hook and top hold down knob or nut. Bolt a strap through the top trunk cover for the stap. Yo'd have to reinforce the top trunk cover with a backing plate of some sort on the bottom. That way, you can remove it ans still have very little eveidence, except the strap that it was there.
  17. bisco
    48,862
    that's a great idea, i wondered if it was possible, but don't know how much clearance there is on the pip.
  18. Mike500
    2,593
    763
    Won't work. The bottom of the campartment is already one of the lowest points on the Prius.
  19. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Definitely not the easiest. The easiest would be to use the tire straps that are included with the Prius Plug-in in conjunction with the hooks in the trunk that are specifically for this purpose.
  20. Mike500
    2,593
    763
    That would not be very practical, as the tire will be in the center of the trunk area.
    Mine is the "easiest," if you wanted it neat and dicrete.
    Easiest by your defitition would be to wedge it between the front and back seat. No straps or almost no effort is needed.
