Forget Global Warming, Prepare for New Ice Age, Says Scientist
Discussion in 'Environmental Discussion' started by fairclge, Apr 23, 2008.
  1. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    LMAO!
    Chogan2, great info as usual. I'll check out the second set after I get home from classes. I have Entomology tonight (6:30-9:30pm) so it's gonna be a loooooong day. :(
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    3 hours of Bug Science. Better you than me. :D
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    posted on news last night...18% increase in CO2 over past YEAR.... also an increase in methane...(a green house gas that is many times more potent) no figures released on the increased levels detected.
    so does that mean we break even?
  5. spf
    spf Junior Member
    70
    Hey everyone, I know virtually nothing about the science behind global warming, other than it's related to co2. I read something the other day about a "force factor" or "co2 forcing" that is a key factor. Can someone please explain what this is, and is the amount of "forcing" an assumption or has it been proven, or is it a non-issue among global warming advocates and skeptics?
    Thanks for your input.
  6. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    with Earth Day rapidly approaching, it seems that TV has dubbed this week "Earth Week"... besides extra green segments on the "Today Show" and "NBC National News" several cable stations are focusing on environmental topics centering on global warming and climate change.
    so a lot of good updated info available. the amount of info is a bit overwhelming, so i have Tivo'd much of it so i can watch it at my leisure.
    having already seem a few good shows on the History Channel, its obvious that "Global Change" is what we need to concern ourselves.
    for the first time in history, the Earth is changing and not because of what we want it to do, its changing because of what we are not doing.
    climate, weather, food, energy are all on precipitous brink of a major change and that direction is not looking good.
  7. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    If you really do know virtually nothing about it, then accept this brief definition, from realclimate.org.
    Climate forcings are the changes that affect the energy balance of the planet.
    Examples would be changes in greenhouse gas concentrations, in atmospheric aerosols, in the earth's albedo due to (e.g.) changes in ground cover, changes in solar intensity, changes in the earths orbit and inclination (over the very long run), and so on.
    If you want a list of forcings considered in most models of short-run climate changes, along with their estimated relative importance, you can look here:
    RealClimate
    For all intents and purposes, "first order" as used there means "large".
    It's a nice article because it focuses you on how subtle all of this is. The imbalance caused by man-made C02 is not huge, in the overall scale of things. It's a small, persistent change. But it's enough to nudge the temperature up, just a bit. And that's enough to change (e.g.) what land is and isn't inhabitable.
    If your ultimate question is whether the increased C02 is manmade, the answer is very clearly yes, as had been discussed on several threads here. We have good records on fossil fuel burning, cement production, and deforestation. The total C02 released by those activities, each year, is larger than the increase in the total C02 in the air, each year -- so Nature at present is absorbing, not releasing CO2. We are definitely doing the "forcing" in this area. We have the receipts to prove it.
    If the question is, is there agreement on how much temperature rise you'll get out of a given amount of CO2, then the answer is that is some disagreement there, but not a huge amount, as far as I can tell. The estimate is based on both modeling (theory) and comparing the projections to the current data (empirical evidence, though not experiment in the classical sense). From what I read, the level of greenhouse gas increase is sufficient to explain the current increase in temperatures, and that you can't explain the current increase in temperatures by any known factors without including the manmade increase in greenhouse gases. (IE, GHGs are more or less necessary and sufficient to explain the current increase in temperature). Which is what is bizarre about a lot of denialist alternative explanations -- to believe some alternative, you have to forget everything you know about the obvious (the theoretical and apparent empirical impact of C02 and other greenhouse gases). In other words, almost all denialist explanations are incomplete -- they'll put up some theory du jour about something else that is warming the earth, but they never get around to explaining, in addition, why greenhouse gases are not warming the earth, which is what you'd have to have in order to have a complete alternative explanation. Otherwise, you'd get a higher global temperature than we currently have.
    Anyway, my reading is that the consensus these days is that doubling atmospheric C02 will eventually lead to 3 degrees centigrade increase in surface temperature, ignoring any further feedbacks (e.g., ignoring the potential for rapid methane release as the permafrost melts, for changes in albedo if we lose the polar ice cap, and so on.) I could be wrong on that but that's the value and the definition that I think I've seen most often. People may reasonably disagree about that. For scale, atmospheric C02 now is about one-third higher now than the pre-industrial-revolution equilibrium.
    I don't mean to sound harsh here, but if you actually know quite a lot, and are using this as a seemingly-innocent opening to sow confusion around the difficult topic what, precisely, is and is not a forcing, then I'm done.
  8. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    And as usual with these sorts of ridiculous claims, Chapman's column was originally published as ...
    an opinion column.
    Sorry to ruin the fun, but an ice age cometh | The Australian
    So as oppossed to peer-reviewed research, he instead publishes in the part of the newspaper that doesn't even require basic fact checking.
    And even as recently as 2002, Chapman says:
    "Pending a much better understanding of the climate, we should thus encourage and not curb anthropogenic emissions of CO2."
    'nuff said.
  9. spf
    spf Junior Member
    70
    chogan,
    Thanks for your explanation....I really do appreciate it. Yes, what I read was related to do with how much temperature rise you'd get out of a given amount of co2. And no, I really do know very little about the arguments, both pro and con. And, at the risk of sounding defensive, I would not deceptively use this forum or attempt to sow confusion. My ethics and value system are above that, I would hope. I am simply attempting to obtain objective info, do some anaysis, and eventually come to an objective conclusion without bias, preconceived notions, or false assumptions. I'll check out the website.
  10. chogan2
    1,066
    756
    Virginia
    I apologize. Sometimes my paranoid inner economist takes over. As noted earlier in this thread, Realclimate.org is the best place I've seen for reasoned discussion. It's run by climate scientists. And the site Alric brought up earlier in the thread has a nice collection of the key graphs.
  11. chogan2
    1,066
    756
    Virginia
    Just in passing, rice futures hit a new all-time high, and two large US chains imposed restrictions on the number of large bags of rice you could buy at one time. There have been rice riots in poorer countries, due to high prices, which are most due, I think, to the near-total failure of the Australian rice crop, due to the recent drought. That hardly gets noticed here in the US. But it's unusual to see even mildly disorderly markets in the US.
    Sam's Club, Costco limit rice purchases as prices rise - Apr. 23, 2008
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ya i saw that... pretty pathetic when the economy is so uncertain that corporations feel its necessary to prevent people from hoarding staples such as rice.
    the price of rice has increased 141% since Jan in some places making speculation a possibility despite the rice industry saying there is no shortage. a huge chunk of that price increase has to be fuel.
    lets face it, we think of ourselves as free-thinking individuals but in reality, we are just mice following the piper.
  13. Devil's Advocate
    922
    Las Vegas, Nevada
    Food shortages are being caused by the diversion of food crop fields to ethanol producing crops, for use as ethanol. It may not be the only cause, but it is surely making the situation worse.
    Very few countries in the world are net food exporters, and it is those countries where ethanol is being pushed hardest.
    IMHO - Ethanol was a failed idea from the outset, even worse than what others claim H2 would be. Ethanol costs more to produce, yields at best equal energy to what it produces, is no cleaner than other fossil fuels, and would require the diversion of significantly more crops to satisfy current let alone future energy needs. (and yes if we cut down a couple of hundred thousand acres of rain forest we too can produce ethanol like Brazil)
  14. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    It will be interesting to see what happens with the biofuels. The EU has already started pulling back from biofuel targets. I'm not sure if it's because of environmental degradation and food prices or what, but they are doing it.
    here in the states I think it will be interesting to see what happens with biofuel legislation.
    Somebody in the economist was arguing that developing nations need to adopt industrial agricultural practices and let western mega corps run them. That sounds like a recipe for disaster to me.
  15. dogfriend
    7,512
    1,185
    Carmichael, CA
    There was a woman on the Today show just a day or so ago that claimed that it is much better for the environment to buy and eat locally grown food to minimize the fuel burned to transport it. She was advocating buying from Farmer's markets and coops. Seems to make sense to me.
  16. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    In most cases that is true and we preach the same thing but for some items one must consider the types of foods grown and the energy input that goes into it. I.E. if you try to grow tomatoes in Alaska in the winter then the energy required to grow them is less than what would be epended in shipping them up from Mexico or South America. This doesn't take into account human rights issues or pesticides though.
    I support our Placer Grown (local food and market group) members up here and we always invite them to our Earth Day events and such. :)
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    get it from an organic farmer and double your benefits. produce grown without pesticides, etc. taste better, are better for you...
    get past the look of them (naturally grown produce is not waxed for appearances) and you are doing a BIG part to save the environment and benefit your family. we buy produce from a place just around the corner from in-laws... plan to pay up to 250% more for the food (although certain times of the year, sales bring prices down nearly to grocery levels) since its hand cultivated AND HAND WEEDED (the cost of not using chemical... a cost i am willing to pay) produce is expensive to grow.
