Front wheel/tire vibration on 2013 Prius v (lowercase v for the Prius v wagon) wagon
Discussion in 'Prius v Main Forum' started by KEELFOOT, May 30, 2015.
  1. KEELFOOT
    KEELFOOT New Member
    Loudon, TN
    My 2013 v (lowercase v for the Prius v wagon) has just under 45,000 miles on it. About 1000 miles back I began to notice vibration at low speeds (starts at 15 mph and fades away at 25-30 mph). Tires have lots of tread left. Just did another front to back rotation and no change. I'm thinking it may be a wheel bearing. Any ideas?
    Thanks,
    Tom C.
    PS: Nothing to do with the vibration, but my mpg guage has never been reset for the primary odometer, and it still reads 45 mpg, fwiw. No, I haven't checked against an actual "fill'erup and measure it" yet.
  2. WilDavis
    WilDavis Senior Member
    2,489
    2,153
    49
    Any strange wear-pattern (feathering, uneven, fluting) on the tyres? Have they wheels ever been balanced, and are all the weights still in place? At what pressures are you running tyres? Have they ever been kerbed? Loose wheel lug-nuts? - hope this helps - Wil
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,612
    4,466
    Texas Hill Country
    Possible damaged cv joints if the tires are known good. Sometimes a vibration from the back can transmit through to the front, so rotating tires is not always a good diagnostic. Have them check on a balancing machine.
  4. mikefocke
    3,645
    1,628
    Sanford, NC
    A good tire shop will also check to see the wheels themselves are true.
    I actually had to replace 3 "mag" wheels from a Honda car a while back because they were the cause of noise and uneven/rapid tire wear.
